Question about HP LaserJet 2420dn Printer
Hp laser jet 2420d printer
Print blank pages change out with new toner still prints blank pages
    New Friend:
  • 159 Answers
Check the scan unit or change it
Posted on Mar 22, 2008
SOURCE:
The pages are not printed
sometimes in this case the dram needs to change (
Mar 01, 2015 | Samsung CLX 3185FW - multifunction fax /...
Magenta toner spots pages
Step 1:
Print out about 10 blank (all white) sheets and see if the spots clean off.
Step 2:
Check to see if the toner is Dell type brand, if not try installing Dell brand and run 10 blank copies then run color test print using menu key.
Press menu, press arrow down key till 'print reports' is displayed, Press 'check key' then press down key till 'color test print' Press check key to print color copy.
Apr 10, 2013 | Dell 3010cn Laser Printer
Printer prints blank pages
This is almost certainly an issue with the toner cartridge. I would recommend running off 30 or so prints and contacting whoever the cartridge was purchased from if the toner doesn't pull through.
Nov 18, 2012 | Brother HL 2140 Laser Printer
Hp corol laserjet cp2025 printing blank pages even on printer itself
Mine blank pages where caused by bad black toner, replace with OEM when in doubt.
Oct 01, 2012 | Office Equipment & Supplies
We changed the toner on the printer and it prints a blank page. What do we do
If new toner was installed and it prints blank pages, please try to print a menu settings page to determine if the problem is part of the printer or an issue external to the printer.
If the menu settings page prints correctly, the source of the problem is external to the printer. To find out if the problem is only with a program, try printing from a different software program. To find out if the problem is only with a particular computer, try printing from a different computer.
If the menu settings page is blank as well, this will narrow the source of the issue to a part on the printer. Please contact Lexmark Technical Support for further assistance.
Aug 12, 2011 | Lexmark E260dn Laser Printer
Infoprint 1512 prints blanks from int. and ext. print source
How to get on software to setup for printer , infoprinter 1512 ( Ibm ) .
tha for kind wondows ( wondows vista )
Aug 14, 2009 | IBM Infoprint 1512 Laser Printer
Printer prints blank on paper
Open the door half way through a page print and pull out toner cartridge. The page should be in the toner cartridige. If you can see the printed image then the fuser is the problem if you see nothing then the toner is bad or has a protective sleeve inside that needs to be pulled out from one of the ends.
Jan 08, 2009 | Canon LBP 800 Laser Printer
Ghost printing
Hi Phillip,
If you have changed the drum and toner, then check the fuser unit. The teflon coating on fuser film could be worn.
S88
Dec 16, 2008 | Brother MFC-8460N All-In-One Printer
Not printing (paper comes out blank)
it is possible that is has problem on your printer's memory... try printing below 30 pages see if problems still persist.
Mar 07, 2008 | Samsung CLP 300 Laser Printer
HP LaserJet 2420dn Printer Logo
151 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
