Question about Smeg SE399X/5 Stainless Steel Electric Single Oven
Smeg Oven Hi, we have just moved into a new place and all the appliances are Smeg and i don't have any of the manuals.  My problem is that my oven has three dials on it and around the dials they had print on it to indicate the  tempreture and  around the third dial it had symbols on it. Because the print has came i cant really use my oven to its full potential. I think my oven is a Smeg SA365X1. I know the first dial to the left is the timer. Can somebody help and tell me what print does it have around the other two dials?  Thanks  Caroline
  • cazza30 Apr 11, 2008
    Thank you soo o much!!! Your the best!
  • Anonymous Mar 23, 2014
    When trying to set the temp on the oven. The temp jumps all over the place. Dial seems to skip all over
    Genius:
  • 1,665 Answers
SOURCE:
Daniela appliances DAN6FCS oven manual/guide
Google (Daniela)(DAN6FCS)(manual) without parens.
Sep 30, 2018 | Ovens
Help! I have a Smeg oven Model Number: SA410X-5. All of the symbols have come off. I have just moved in to a new place with this oven and have no idea what the symbols are meant to be! Im urgent need of...
here is the manual
Smeg Multi Function Built In Oven Operation Manual
specs
Description
Smeg 60cm Stainless Steel Single Oven. Model: SA410X-5
  • RRP: $1,490. The RRP is supplied by the manufacturer and is based on a brand new item, not used. It is accurate as at 1st April 2010
  • Dimensions: 595mmh x 596mmw x 567mmd
  • Smeg thermosealed, fan forced, six function, 60 minute timer
  • Capacity 66.4 litre gross, 56.1 litre net
  • Installation underbench or wall (column), fascia: flush or proud mount
  • Thermostat variable 0 -250 Celsius
  • Multifunction five cooking functions plus defrost, timer 60 minute max, variable count down timer
  • Part number: 9842 (SN:SA410X-5) (145924-2)
Spares and schematic
SMEG SA410X 5 Parts List BigWarehouse Spares
New Fascia Stickers for 15.00GBP
Smeg SA410X facia stickers for worn fronts
Apr 03, 2018 | Smeg Ovens
Where can I purchase a new door for my smeg oven. SSA91MFP1 sn 80929 1812. The glass shuttered.
Hello Corlia;
My name is Peter. I am a retired field service appliance technician in the USA.
I do not know what country you are in, so go into your computer search engine and search, "Smeg Oven Parts SSA91MFP1".
To purchase an entire oven door will be expensive. Just purchase to glass and install it yourself.
Mar 11, 2016 | Smeg Ovens
I need new one. THe glassl has broke.
They are fairly simple to replace couple of screws google it and you will find places online to buy the glass and ship it to you or try sears for parts for appliances
Dec 16, 2010 | Smeg S351X/5 Electric Single Oven
Smoke come up from bottom of 3-month new smeg oven SA702X when try to heat up
Hi.
Smoke coming from the oven is not normal. Ensure that the smoke is not vapour coming from the food inside the oven.
If there is vapour coming from the hinge area, then ensure that door and hinges are installed properly.
If you get smoke from the oven, try cleaning the oven cavity, follow the instructions on manual to clean the oven.
If after cleaning the oven, there is still smoke coming from the bottom side, then call Smeg and have the oven replaced. There is one or two years warranty on the appliance.
Smeg support and service phone number is listed in the oven manual.
Regards.
Mar 09, 2010 | Smeg Ovens
Hi, I am in the process of installing a new kitchen. I was recommended to buy Smeg appliances- an oven and ceramic hotplate by a salesperson stating they are very good aplliances, however another...
From experience I have found Smeg appliances to be very reliable.
It is difficult to judge reliability of appliances but generally these days NO appliance will last without some form of brake down. They are not made to the same quality as appliances of a few years ago.
If you stick to german made appliances (Bosch, Neff, inc Smeg ) then they tend to be built to a higher spec.
Regards
Aardvark Repairs
Nov 16, 2009 | Ovens
Smeg oven
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Dec 08, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Smeg oven model 280X
Found the local agent for this cooker and they have supplied a copy of the operating instructions.
Thanks anyway.
Sep 08, 2008 | Smeg SE280X Stainless Steel Electric...
Oven smoking
I am pretty sure this is just the steam escaping. Smeg ovens seal so evenly that the steam stays in the oven.
Nov 12, 2007 | Smeg SE399X/5 Stainless Steel Electric...
Smeg SE399X/5 Stainless Steel Electric Single Oven Logo
1,912 people viewed this question
Top Smeg Ovens Experts
Jason Harris
Jason Harris
svoorhees
Level 1 Expert
Are you a Smeg Oven Expert? Answer questions, earn points and help others
