The color on the top left hand corner of my tv is distorted kind of looks like the color flapped down over itself
You should keep away your crt from magnetic field. You can use strong magnetic field to pull out the color distortion
Posted on Mar 22, 2008
Samsung LCD TV colour distortion
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1300 posts to different brand TVs now. Pull up older posts there.
Nov 26, 2012 | Samsung Televison & Video
The color is distorted on the lower left hand side of the TV, or maybe distorted is not the correct wording. It looks like there is a yellow haze in that corner...
hello my name is rico, i work on tvs sometimes. The model of tv you have is very common bad light engine, because you mention there is yellow haze on lower left corner, if you need more help please feel free to call me anytime, i live in mesa az at 602-810-7149. And is not worth to get fix because the L.E. will cost you between $500.00-1000.00.
Dec 29, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Wavy colored line at upper right corner of set seems like something is pushing from top left and distorting picture from that direction.
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 13, 2010 | Hitachi 51F500 51" Rear Projection...
Top left hand corner has a crooked picture on my sony wega 32". It just kinda dips down and is distorted.
THERE ARE MANY WAVEFORM CORRECTION CIRCUITS IN THIS SET. COMPONENT FAILURE IS UNCOMMON HOWEVER. CRACKED CIRCUIT BOARDS AND BAD CONNECTIONS ARE COMMON
Dec 26, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Panasonic PT 47WX53 CinemaVision TV
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Mar 21, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Color separation
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Mar 03, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Arching color wave on bottom left corner & also on top left corner(color changes)
Convergence amps are failing which is very common. Several hundred dollars for a repair.
Dec 26, 2007 | Philips Magnavox 51MP392H Rear Projection...
Bottom of projection tube is another color
Yes, worth fixing, sounds like convergence is out on the tip ends. Check papers for Convergence controls. See if have auto fix.
Aug 12, 2007 | Philips 60PP9202 60" Rear Projection...
Televison & Video Logo
98 people viewed this question
Top Televison & Video Experts
