Question about Sony PlayStation 2 Slimline Console
Sony PlayStation 2 - Does not read CD
I have read your posts about the PS2 Slimline laser replacement and I appreciate your information. My PS2 is not a slimline, but will not read the CD. It just spins and tries.
I am not experienced with small electronics, but I opened it up and it looks to me like the laser is trying to focus. It is moving in and out, over and over.
Additionally, the plastic clip that attaches the laser to the spinning screw to move it horizontally appears to be failing to grip the screw and move the laser. When I turn that screw by hand, the laser does not move, except sometimes the laser "jumps" like it is trying to move with the screw.
Do you have any suggestions?
Thank you,
Eric
Well i have just pulled a mates ps2 apart as he has had the same problem No Read Cds, i have found a component from the cd rom within the case. Soldered it back on and its back up running again...
Posted on Oct 24, 2008
  • 67 Answers
Im guesing you have the original ps2 , so all you need to do is replace the laser arm , its not expensive at all .you need to do is unscrew the white plastic arm with a phillips or a small screwdriver be gentle and keep screw and lift the white arm off.You need to buy a laser arm either from ebay or http://www.quantronics.com.au/products/ps2/lasers .Make sure get the right one its different from each model of ps2 , you can determine your model by looking at the warrenty sticker and compare it to the table in the link (at bottom) http://www.ps2cover.com/ps2-modchip-model-number.shtml .When you buy the part get some oil (very light eg lithium grease or olive/vegetable oil and use a paint brush and try to brush over the bronze gear (where the clip is).Then align the two slanted groves to the gear screw (laser) then gently put the original screw back
Sorry for the late reply
If you need further help feel free to ask
Tech_PC
Posted on Oct 14, 2008
    Genius:
  • 1,175 Answers
Replace the DVD/CD drive. Reasonable costs if you look online.
Posted on Mar 24, 2008
IT IS THE EYE. the eye th the little shiny piece that you can bairly see once the tray comes out.you might have put a disk in at a wrong position and scratched the eye. replacing it might be what to do, but i would check first.
Dec 21, 2008 | Sony PlayStation 2 (PS2) Console
Ps2 slimline
It should work,but don't be surprised if bugs from games and incompatibility happens.There's always a risk.
Sep 27, 2008 | Sony PlayStation 2 Slimline Console
Metal spacer inside ps2 slim
Maybe it is placed under the laser???????????
Jun 17, 2008 | Sony PlayStation 2 Slimline Console
PS2 Slimline read error
ps2 slimlines had as problem with doing the lasers .this was a fault of over voltage to the laser lense.sony did bring out a mod for this.you would have to replace the laser .they are not all that dear.make sure you get the right one for your model
Apr 26, 2008 | Sony PlayStation 2 Slimline Console
Disk read error on slim ps2 scph 75003
hello pauldonp...if this is an early version of the slimline they had a problem with over voltage which inturn took out the laser.your only option may be to replace the laser . sony did bring out a mod for this..i preferr the real old version of the ps2 as they had all separate boards and if one went faulty you didnot have to replace the lot ,also the lasers were a lot cheaper than the later models .in the slim lines the lasers are not all that expensive .they do take a bit of setting up as you have to know the ohms setting on the laser for each model..hope this helps
Feb 08, 2008 | Sony PlayStation 2 Slimline Console
Laser Wont fire
I had the very same problem with my ps2. What I had found was that I had indeed gotten a nonfunctioning laser. After I installed another new laser, the system functions without any problem. I hope this information helps you.
Jan 05, 2008 | Sony PlayStation 2 Slimline Console
Sonyplaystation2 model scph 70002
Check you 1st posting and please check Solved on this one. The solution I placed on your first posting will work. You gave me a Almost there vote on the last posting and it cut my rating. You cannot change it. By Clicking solved on this one will counter your almost there vote.
Nov 09, 2007 | Sony PlayStation 2 Slimline Console
Sony slimline ps2 NO DATA
the ps2 slim gets disc read error alot. this issue can be fix by replacing the laser in the system. make sure you get the correct laser
Nov 03, 2007 | Microsoft Xbox 360 Console
Ps2 slimline disc reading error
HI Heytev,
Three things.
  1. The laser could be melted from extended attempts at reading an unreadable disc. If so, You need a new laser.
  2. The Disc is not spinning which could be a motherboard failure. If so, you need a new motherboard
  3. Dust has infiltrated the laser and contaminated the Mirrors or Pickup. If so, you need a new laser.
Ok now that you see the reasons, it is more likely you need a new laser. go to Ebay and buy you one. They are fairly simple to change. Call or email me when you get a New laser.  My information is at www.playstationclinic.com  Hope this helps you.
Oct 23, 2007 | Sony PlayStation 2 Slimline Console
Disk wont spin
First of all the new laser lens will not allow your Slim to read NTSC UC games if you have a PAL european Console.
There is no reason the New laser should have not read the disc unless it Came to you damaged. It sounds like you know how to replace a laser.
Sep 13, 2007 | Sony PlayStation 2 Slimline Console
Sony PlayStation 2 Slimline Console Logo
100 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
