Hitachi 55VF820 My tv turns off and then on agian, the red lights will blink in between. I replaced the lamp about three months ago. what could be the problem
  • reelttooper Mar 22, 2008
    It stay's on for about five minutes or so before it shuts back off. It can go on like that until I get tired of it.
  • 13,434 Answers
Shuting down with the red temperature light blinking means it is overheated and needs to cool down a bit.
Make sure if your model has aircooling fans that they are clean and the air goes throught easyly.
Posted on Mar 22, 2008
  • 4,889 Answers
The protection circuit is shutting the set down. The reason it comes back on in 15 minutes or so is because the protection circuit resets itself after a while but detects the same fault when it is ON for a few seconds.
It is the protection circuit that is causing the set to shut down. Unfortuately we don't know which of the many sections of the tv is the one causing the problem in the first place.
Can you tell me how long it stays on and how long does it take before it comes on again?
    Genius:
  • 3,587 Answers
Well..the control board has this sort of issue. sometimes, if you turn if off long enough to reset itself, this may clear..otherwise, it's a replacement of a non inexpensive component..
what's your technical ability like?
SOURCE:
Bought a Hitachi 55VF820 at a garage sale and they said it wont turn on even after replacing the lamp.
I dont know the model but general trouble shooting might work. See it you can download the manual and or look at the web site for the trouble shooting section. Check the power cable for breaks, some can be hidden inside the insulation. Look especially at the ends where the wire gets flexed the most. Check if there is a fuzz and it is good. See if there is a removable panel and look inside for bad, burnt, of exploded parts. Read the bulb replacement section of the manual and remove and replace the bulb as instructed. Read turn on instructions and or break-in instructions. Give it some time to warm up.
2 notes; Do all this with out plugged into wall (for safety).
Be sure to try to not touch the bulb and clean it with a lint free clean towel. They are very sensitive to oil or dirt from handling. .
Nov 21, 2016 | Hitachi 55VF820
Hitachi tv LCD blinking red light tv wont' turn on. replaced lamp model 60V500A
I have hitachi lcd rear projection tv model 60v500A at first I was getting a red spot on centar of tv with in two mounths the spot got bigger. I chanched the lamp but now i don't have a picture, the red indicator on tv is now blinking.
Aug 10, 2010 | Hitachi Televison & Video
The power light is red and the bulb light is blinking red
OK...Did you replace the lamp with a Sony original? If you did, then carefully check that the door is closed properly.
May 28, 2010 | Sony KDF-E55A20 55 in. LCD Television
Sony model#kdf50e2000.turned it on a few days ag0 heard a few clicks, green light come on a few times then it gives me three red blinks stops then three red blinks again and again.no sound no picture.i...
Your lamp door switch or lamp switch (there are 2) may not be fully engaged or one may have failed. Try seating the lamp again, you may not have it fully installed.
Mar 17, 2010 | Televison & Video
My hitachi 50vs69a tv wont turn on and after afew blinking red li
Have you replaced the lamp? Unplug the set remove the lamp and see if it's blown
Sep 20, 2009 | Hitachi 50VS69 50" Projection HDTV
Hitachi 50VF820 (LCD projection)randomly turns off, all three lights (temp,lamp,power)blink then the set turns back on after approx. 30-45 seconds. Lamp was changed approx. 4-5 months ago. Cleaned out all...
I believe I may have solved this problem by putting a small fan blowing on the intake of the Lamp fan. I put the fan in place and the TV has not turned off randomly since. That was only a day ago so I'll see if it is a permanent fix. If so I will probably try to mount the fan on the back of the TV out of sight.
Jul 16, 2008 | Televison & Video
TV shuts off
I would suggest that you guys turn the unit off when this happens, unplug the unit for 30 seconds, plug it back in, and see if this helps. If this does not solve your problem, you should call 1-800-448-2244, so a service center in your local area can be found for further assistance.
Nov 08, 2007 | Televison & Video
Televison & Video Logo
103 people viewed this question
Top Televison & Video Experts
Ekse
