Question about SanDisk Sansa e250 MP3 Player
Micro sd 4gb card problems.
Recently bought sansa player and a micro sd card 4gb. wont recognize the card. Dont know what is the problem....Need help?
  • 1 more comment
  • Anonymous Mar 22, 2008
    Same problem here. Vista creates a drive letter, but can't access the drive in MSC mode.
    Further more some folders (Music) are hidden in MSC mode, but not in MTP mode.
    Tried to reformat the sd card, et does not work, not on XP either.
  • Anonymous Mar 23, 2008
    I am having the same problem. Needed space but wont work.
  • Anonymous Apr 05, 2008
    Same as above, I bought a new Sandisk 4GB Micro SD HC card. The drive comes up on xp but it is not accessible. On a seperate note, the main button keeps falling out. I contacted Sansa tech support and they basically told me "too bad so sad". Nice support Sandisk. Looks like iPod is getting my money from now on!
  • 8,596 Answers
Check the Sansa tutorials at http://www.sandisk.com/Retail/Default.aspx?CatID=1468
to make sure you have followed all the steps first.
In my experience, every mp3 player/photo frame/etc with a card reader has a MAXIMUM memory limit for the type of card that it can read. It is possible that the Sansa player can only read 2GB Micro SD cards or smaller - and thisi nformation may not have been available when they printed the manual. If you have followed all instructions, and it still will not read the card, try switching to a 2GB Micro SD card.
Posted on Apr 08, 2008
SOURCE:
I added a 2gb mirco SD card to my Sansa e270 6.0gb player, but the memory is still only showing 10mb of the original 6.0 gb available for use. How do I get the Sansa to recognize and use the 2 gb mirco SD...
Hi,when you purchase a new micro SD card before use, youwill need to format the memory card so that you will be able to know the actual size of the Micro SD card by checking the details after formatting it.
After formatting the micro SD card and checking the details, if you still do not see the accurate size which is about 1.88mb or the about, that means the micro SD card you bought needs to be replaced. Not a good one.
Have a nice day.
Feb 18, 2011 | SanDisk Sansa e270 MP3 Player
Installing Micro SD card to Sansa e260R
The Sansa e260 Rhapsody (e200R series) supports:
1. micro SD cards ( not the HC type )
2. micro SD cards up to 2 GB of memory capacity
See next site:
http://kb.sandisk.com/app/answers/detail/a_id/200/related/1
Jan 10, 2010 | SanDisk 4GB microSD High Capacity Memory...
Sansa c240 and a 4 GB Micro SD HC card.
Sansa C240 can only read SD cards that are NOT SDHC - that means it can only read up to a 2gb Micros SD card.
Jun 05, 2009 | SanDisk Sansa c240 MP3 Player
I have a sansa e260, 4gb capacity, that has a spot for micro sd mini chips. I recently puchased a 4gb mini sd ghip that is 4 gb and loaded it up with about 3.89 gb of music and the sansa will not detect...
The Sansa, in common with many devices which have been around for a while, will only recognize standard micro SD up to 2 GB, not the SDHC (High Capacity) variety.
Feb 18, 2009 | SanDisk Sansa e260 MP3 Player
My Sansa WONT read my micro and wont upload songs
You should try to copy your music/files to your computer and format your SD Card. After that, copy your music/files back to the SD Card.
Feb 09, 2009 | SanDisk Sansa e200 MP3 Player
SD card wont let me add anything
I don't think that the sansa e250 supports sdhc cards these cards 4gb and up are only compatible with newer electronics
Jan 28, 2008 | SanDisk Sansa e250 MP3 Player
4 GB micro sd and the Sandisk Sansa e250R...
If the 4gb micro SD is a high capacity SD (it will say micro SDHC on it) your player may not be able to read SDHC cards, my sansa can't because it's the 'older version' it will read 2gb and below micro SD cards though (it sucked when I found out because I had just bought a 6gb micro SDHC)
Nov 22, 2007 | SanDisk Sansa e250 MP3 Player
4GB micro sd card.
According to what I've read, you can double the original memory, but no more than that, so the max you can have on a Sansa e250 would be 4 GB (2GB internal memory and 2GB external memory). I also read that the micro SD cards holds
music only-no video.
Nov 13, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250 using micro sd card
Go to the knowledge base on the Sansa site and find this (chances are you have an SDHC card in an incompatible unit):
Sansa e200
 - verify the version of the player.  To check, go to SETTINGS > INFO
For 01.xx.xx firmware (e200 version 1) - up to 2GB microSD cards
For 03.xx.xx firmware (e200 version 2) - up to 16GB microSDHC cards
NOTE: Firmware is not interchangeable.
Sansa e200R - up to 2GB microSD cards
Sansa e100 - supports SD cards up to 2GB
Nov 12, 2007 | SanDisk Sansa e250 MP3 Player
Micro SD
What you do is get a micro sd adapter and plug it in try that!
Mar 30, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
277 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
