Question about Toshiba TLP S30 Multimedia Projector
Oh my god what have I done and where on the internets can I find a replacement fan?
So my cat knocked my Toshiba off my bed as I was projecting Who's Afraid of Virginia Woolf onto my refrigerator. "What a Dump!" indeed, right? I refilled my glass and turned the machine back on and it started to make a horrible clucking noise then the little fan icon flashes in the top left and the whole thing shuts off. Perhaps it was more of a chunking noise. Well then, I really wanted to get to the dance scene in the bar where Elizabeth Taylor does this awesome chicken move with her arms so I decided to take the whole thing apart. Fast forward five drunken hours later where I'm re-assembling it for the second time - this time without all of the extra screws. I plug it in and... same thing. Or probably worse. Which is better because rather then hearing the floppity clanks I could now feel the floppity clanks. OK. I decided to empty the ashtray and open the projector up again to get my third look at the fan. Which sort of looks like this:
I guess... I stole this image off eBay because I didn't have the foresight to take a picture of it before I butchered it and put it back in the projector. Which brings me to the next part: the butchering. Under closer inspection it appeared that the fan was not spinning so much because it somehow got all bent up after Mr. Werner knocked it off the bed. I did the only thing my delirium tremen-ed up fingers could muster. I grabbed a pair of nail clippers and cut the tips off the fan so they had the clearance to spin around in their little bakelite cages. I clipped all but one - which snapped when I pressed too hard. C'est la vie.
This did the trick. Unbelievably enough, I popped the fan in its pocket, stuck the cord in the socket and presto no more little fan icon. With my successes laid bare before me, I called it a night and put my little device away.
The next evening I developed a terrible thirst for the Garfield live action movie so I popped that pup in the dvd player and aimed ol' Toby back at the 'fridge. I got about five minutes or orange furry heaven when the bulb fades and the temperature light glows to life. If I unplug my machines and then plug it back in it turns on but dies almost immediately. Son of a bubble gum. No whisky for me.
So I know my problems, the foremost is finding the replacement fan and ordering it from the the tubes. However, despite my most rigorous google research, I can't be certain of the make or model - let alone the place to find my tiny whirling dervishes. Oh please Lord of teh Internets, help me find my fan.
Yours Truly,
mlle. Francos.
    Novelist:
  • 155 Answers
The good news is that cooling fans tend to come in standard, off-the-shelf shapes and sizes. If someone like Toshiba needs a cooling fan, they don't set about designing and building one from scratch, they just make the hole in the projector the right size to fit what's already available.
I know the picture isn't actually of your fan, but if yours does look similar, then this is a standard cooling fan and not some special Toshiba item.
How many wires has the fan got?
If it's 2, then it's a simple, constant speed fan. You should be able to use any fan as long as it is the same voltage - this should be written on it somewhere. Try an electronics supply company, e.g. RS, Maplin etc. You don't say where in the world you are so I can't suggest the best place to try. Try Google for 'electronics cooling fan'. Here is just one example of what's out there.
If it's 4 wire then it's probably a vari-speed of some sort. These tend to be the type used in computers so I would also try some computer component shops as well.
Hope this helps,
Matt
Posted on Mar 22, 2008
6ya staff
SOURCE:
Nissan online mechanic
code p 0432 is main cat converter bank 2 --efficiency below threshold ===causes -- cat converter---wiring heated oxygen sensor (HO2S ) in the bank 2 manifold before the cat converter
ave a compression test done to determine inlet valve seat insert loose
if you have a problem with it there should be a bit of a miss, or it should change with rpm
could be a cam lobe failing and the noise should change with rpm
Aug 07, 2017 | 2003 Nissan Maxima
What features should I look for when buying a bed for my cat?
Before buying a bed for your cat, make sure the bed meets the following standards: - The bed is big enough for the cat to stretch out comfortably. - The bed should be easily accessible for the cat. This means that the sides are not too high and the cat can get in and out of the bed easily. - The materials of the bed should be comfortable. - The materials of the bed should be durable and withstand the sharp claws of the cat. - The bed is washable (machine or hand-washed).
Aug 30, 2012 | Allied Precision Cats
I live in Ottawa and during the winter months it gets extremely cold. My cat needs a warm place to sleep. Can anyone suggest a type of bed that would be best suited to by situation?
I have the perfect solution for you - a radiator hammock cat bed. This bed connects to the radiator in your home giving your cat a comfortable and warm place to rest.
You can buy one at most specialty pet stores or online at one of these locations:
http://www.amazon.co.uk/tag/cat%20radiator%20bed/products
http://www.alphapetonline.co.uk/radiator-hammock-cat-bed/
http://www.ebay.ie/sch/sis.html?_nkw=New+Cat+Bed+Radiator+Hammock+Cats+kitten+Pet+beds
Jul 23, 2012 | Cats
About an hour ago, done a Toshiba Tempro BIOS upda...
Oh dear that's the worst thing that can happen during a bios update. the bios chip is probably now useless rendering the laptop useless. You will need a new motherboard I am afraid to say.
Jul 25, 2017 | Toshiba Satellite Pro L300D-EZ1002X...
How to replace power supply?
Toshiba model 57H93 worked perfectly last night. Turned off and went to bed. Turned on this morning, and nothing, it won't turn on. Checked all cords and cables, pushed reset button, and still won't turn on. What could cause this to happen?
Dec 14, 2009 | Toshiba 57H93 57" Rear Projection HDTV
Fan cuts in for several seconds several times a minute
When you use your laptop, do you usually put it on your lap or on a bed ?
The reason for this question is quite simple. Toshibas have variable speed cooling fans
that are designed to elevate RPMS to compensate for elevated temperatures. If so,
try using your laptop on hard surfaces so the botom of the laptop recieves proper ventilation.
Another known issue is that they tend to gather dust inside the heat sink so you should try
inspecting it to see if it is clogged.
Good luck...
Mar 21, 2009 | Toshiba Satellite P105-S6227 Notebook
I have a ruined Toshiba Remote Control thanks to my Cat!
Hi redead,
I am sorry to hear about the accident!
Our PartSearch department may be able to locate a replacement remote for you. You may either visit http://bestbuy.partsearch.com or call 1-888-Best Buy™ to see if we have a remote that will meet your needs.
Thank you,
Jason,
Go Ahead. Use Us.
Jul 15, 2008 | Toshiba CZ27T31 27" TV
Toshiba TLP S30 Multimedia Projector Logo
99 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
digivisionm
Level 1 Expert
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
