Question about Cameras
I have a Minolta sr7 and the timer is stuck the shutter will not work can you help
    New Friend:
SR-7's Shutter is fully mechanic, battery is only for light meter, I advise you to get it repaired on a camera repair workshop.
Posted on Dec 22, 2009
    Master:
  • 619 Answers
Hi , try to replace new battery and then press for shoot pictures.
Posted on Mar 22, 2008
SOURCE:
Minolta x500 shutter arm stuck
A Minolta X500 is a 15+ year old camera. The shutter arm is stuck in the winding position is an indication that the shutter mechanics are broken. Repair would be way more expensive then picking up a used model. Minolta has dropped out of the camera business, some older Sony digital cameras can use their lenses if you have a number of them. Zoom lenses are usually what comes with most camera kits.
Jan 09, 2017 | Minolta Photography
Minolta 700 film advance lever was working, then it wouldnt wind, now it is stuck.
Use or buy a brand new battery from store that sell lot of them.
Do not get from store that only has a few, meaning they have been sitting there for years.
[email protected]
Feb 14, 2014 | Minolta X-700 35mm SLR Camera
I have a Minolta XG-A camera, and i can take a picture but the shutter is stuck?
My shutter does that when there is low light, or just slow shutter speed. You could try changing those settings, otherwise, last time mine got stuck, I loosened a screw on the bottom right under the shutter release button and the shutter just snapped back into its place.
Jun 09, 2012 | Minolta XG-A 35mm SLR Camera
I have the timer set for 10 sec, how do I make it work?
Once you have the self-timer set, start it by pressing the shutter release button as usual. The camera will focus, meter the exposure, then delay for ten seconds before firing the shutter.
Mar 21, 2011 | Konica Minolta DiMAGE Z6 Digital Camera
How do you find and use the self-timer setting?
Hello.
Turn the function dial to the drive mode position.
Press the function button in the center of the dial.
Turn the front control dial to select the self-timer drive mode.
Use the rear control dial to to switch between a ten-second and a two-second delay.
Press the shutter-release button partway down or press the function button to set the mode.
When you are ready to take the picture.
Press the shutter button partway down to set the focus and exposure.
Press the shutter button all the way down to start the timer.
Hope this helps.
Feb 16, 2010 | Konica Minolta DiMAGE A1 Digital Camera
Need to set self timer
Press the MENU button, select "Drive Mode," then select the self-timer (one-handed clock). To start the self-timer, press the shutter release button.
Sep 06, 2009 | Konica Minolta Dynax 5D / Maxxum 5D Body...
Film Advance lever stuck
When you press on the shutter release does it "click"? A few hard taps with the end of your finger onto the shutter reelase button may unjam it if it is stuck...
Jun 15, 2009 | Minolta X-370S 35mm SLR Camera
Stuck shutter, and I can't advanced the film
There are one or two capacitors which go bad and cause the shutter not to work. Just google "Minolta shutter problem", and you'll find details instructions on how to replace these...I believe the defective capacitor on your camera is accessible by removing the bottom cover.
Jun 10, 2009 | Minolta X-370S 35mm SLR Camera
Cant figure out where the shutter release cable hooks up oncamera
Sorry my friend, but the HTsi model lacks facility for a cable release. Use the self timer on a tripod instead to eliminate camera shake
Here's the link to a user guide if you don't already have one:
http://www.mediacollege.com/cgi-bin/equipment/manual.cgi?model=HTsi
Dec 03, 2008 | Minolta Maxxum HTsi Plus 35mm SLR Camera
Minolta Maxxum 5000
I had the same problem with a maxxum 7000. Traced it to a bit of corrosion in the battery pack. It let just enough power through to run the computer, but upon releasing the shutter, it shut off.
You might check that. corrosion can be cleaned with vinegar.
-John
Oct 07, 2008 | Minolta Maxxum 7000 35mm SLR Camera
Cameras Logo
358 people viewed this question
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
