Question about HP PSC 1510 All-In-One InkJet Printer
Scanner glass missing
Need to find a place to get a piece of glass for scanner of hpc3180
    New Friend:
  • 159 Answers
You can find it in any Hp partner
Or you can take the glass size and let any glass maker made it to you
Posted on Mar 22, 2008
We have this machine at our church purchased a three yr. warrant with it and it expired 5 mths. ago, but during the warm up it begins to make sort of a grinding noise, then display says scanner error #...
Scanner error 5 indicates that the scanner head is not moving. This is most often caused by a bad scanner motor. If you open the ADF top, you should see the main scanner glass and then a small piece of glass. This smaller glass is held in place by one screw and a plastic retainer. Remove the screw and retainer, pop the glass out and smell the inside of the scanner. If you smell burned elecrical then that motor has definitely failed and you either have to try and find another scanner or find a donor motor. (the HP 3380, 3330 and M2727 all use the same motor).
May 13, 2011 | HP LaserJet 2840 All-In-One Printer
Two black lines down the side of the paper when fed from the top feeder.
Most likely dirt on the glass for the ADF scanner, but try making a copy from the glass first by lifting the lid and placing the document directly on the scanner. If that is clear, then it is definitely dirt on ADF glass. The ADF glass is the smaller piece of glass you see when you lift the lid. Use window cleaner and a soft cloth to make sure that you have all traces of dirt, liquid paper, post it note glue. Look at the glass from very carefully because even the slightest bit of goop can cause scan defects.
May 04, 2011 | HP LaserJet M1522nf Multifunction Printer...
HpC3180 wont scan. I press the
if its not scanning and the power button is blinking then there is some hardware problem...clean the scanner bed..and try..if still doesnot work then its need s to be replaced..
Mar 23, 2010 | HP Photosmart C3180 All-In-One InkJet...
I get a black line on my faxes or copies - i have a sharp UA260. i even cleaned the roller and scanning glass per manual.
Your problem is most likely something stuck on the scanner glass that is blocking that part of the scanner glass, causing the black line down the sheet. Open up the machine and remove the roller to get to the scanner glass. Look very closely at the glass and see if anything is stuck to it; even a small speck might cause this problem. The black line on the page will be the same place to look on the glass for any . If alcohol on a cotton swab doesn't help, try using a small piece of paper and wipe off the glass with it. You can also use a fingernail to scrape off that part of the glass. Don't worry, a fingernail won't harm the glass.
Hope that helps!
Mar 08, 2010 | Sharp UX A260 Plain Paper Thermal transfer...
A line appears when photocopying
Check the glass for a piece or dirt. When you use the doc feader it runs the paper over the scanner instead of the scanner running over the paper when you put it on the glass. There should be a strip of glass that the doc feader uses. A small piece of white out can make a line. If the line apears when you place a piece of paper on the glass then it is your photo drum and you will need to replace the tonor cartrage,
Hope this helps
Sep 15, 2009 | HP LaserJet 3030 All-In-One Printer
Lines on copy/scan/fax
You have something on your "scanner glass", the narrow piece of glass that the scanner "looks" through during adf use. Get some window cleaner or rubbing alcohol and clean it with a damp cloth. Often, it's correction fluid (Liquid Paper). A little dot is all it takes because the paper is traveling across the dot, effectively drawing a line down the length of the page.
Aug 04, 2009 | HP Office Equipment & Supplies
Broken scanner glass
You can go thru Xerox possibly but they would probably have you send it in and charge you outrageously.
If you knew how to take apart the scanner I would suggest taking a tape measure and measure the exact size of the glass and then maybe go to a glass place and have them cut one to size for you.
Not sure what the costs would be but if this scanner is one of those where you like it alot and can't do without it then at least this could be an option and you can then put the new glass in and put the scanner back together.
I know this might seem weird but at least its worth a shot and maybe getting a piece of glass is less expensive then sending it in to xerox to get serviced.
Ben
May 20, 2009 | Umax AstraNet E5470 Flatbed Scanner
Underside of document table needs cleaning
Hey! I've just find the solution. The only thing you need is a multi-screwdriver to take out the two screws sitted on the backside, then use a screwdriver with a plain point to separate the dark grey plastic piece from the light grey one (use a few toothpicks to keep every flap open). When you get all the flaps open just pull the light grey piece (the bottom one) and separate the dark one with the lid and the glass. Now you can clean conscientiounly the glass. Be sure to put in its right place the back little plastic piece that covers the power connector before closing your scanner when it's clean. Close it introducing the front side before and pressing over every flap. Work done! enjoy you Epson scanner!
I apologize for my english, maybe I've used any unconvenient word, but I think you'll understand it.
Regards,
Jordi (Terrassa, Spain)
Aug 07, 2008 | Epson Perfection 1260 Photo Flatbed...
Line prints down page when you copy
No promise that this will work for everyone, but I just fixed one with the same problem. I figured either there was something on the scanner sensor itself or on the glass. If you look to the left of the large glass scan area, you will see a smaller glass strip. When you use the auto document feeder, the scanner stays under that piece of glass. To narrow the problem down, I tried copying a sheet on the large glass (not using the ADF). No line. So, it wasn't the sensor itself, it had to be something on the small glass. That piece of glass is held down with double-sided tape. Dell tries to keep dust and dirt out of the interior of the unit, but it isn't hermetically sealed. So, when something gets underneath the glass, it can stick and create a permanent spot where the sensor only sees darkness. First, try cleaning the top. Look very carefully at the glass about where that line is appearing on the paper (if the line is 2 inches from the side, look about two inches in on the glass. If you are lucky, there's some whiteout (famous for screwing up scanners) or something else stuck to the top. Clean it. Gently. If you scratch it, you're going to hate your scans and copies forever. If it's on the bottom, prepare to void your warranty if Dell finds out, but carefully and slowly pry the piece of plastic holding the small piece of glass out of the machine. It's just sticky tape, but it is on all sides of the piece and it covers the large piece of glass, too. That's where I started, using a very small knife edge to slowly pry up the plastic from the large piece of glass. Little by little, the piece came up. Again, be careful. If you pry too hard, you can break the large scan glass or the piece of plastic you are removing. Once it's out, don't get any dirt on the tape that held it in place - it needs to work when you finish. Now, gently clean the glass. I used a lintfree cotton rag and some glass cleaner. In about a minute, I was able to remove all traces of dirt from both sides and put it gently back into the printer. I haven't had a problem since and hope you have the same luck!
Sep 18, 2006 | Dell 1600n All-In-One Laser Printer
Adf issues
one usefull thing to try - Place a blank piece of paper on the glass. Next, put your hand on top of the piece of paper and slide the paper back and forth across the glass. If you feel the paper sticking, you need to clean the glass with a glass cleaner, then polish the glass with a glass polisher(consult the manual first on this). You also need to clean the plastic between the glass and where the paper enters the glass. if it still doesnt work try to reset the machine, sometimes it takes some rest to reset such problems.
Jan 19, 2006 | Xerox DOCUMATE 510 Flatbed Scanner
HP PSC 1510 All-In-One InkJet Printer Logo
26 people viewed this question
Seeker5211
Seeker5211
