Question about ViewSonic E70 17" CRT Monitor
Monitor problem when i shut my pc and restarted it after sometime the screen became ditorted and it was curved. i tried to set it by changing settings but was unsuccesful. H-Size is not working i mean no changes are done when changing H-Size and when i press recall the settings are not going to factory settings instead just going back to previous wrong settings. how to get out of it
  • 348 Answers
There is a mosfet inside the monitor IRF630 it may short replace it from technical person or replace yourself if you are technical problem will be solved if not then check dry solder correct it otherwise
some boost capacitor may faulty (nearest the yoke coil )replace it
Posted on Nov 22, 2008
My screen on the monitor all the sudden became strechted.I have already adjusted resolution and set restore points.there is still no change
reset your screen settings to center your wall paper. run this command: Control.exe desk.cpl and set your wallpaper to none or centered.
Sep 21, 2014 | Computers & Internet
Out of range 64.0 KHz / 60 HZ
It might be because of wrong screen resolution. This problem can occur because of hardware as well as software change.
To rectify this issue you will have to set your screen resolution to lowest visual settings. For this purpose you can try restarting your PC to safe mode and then modify your screen resolution.
Sometimes setting your monitor to factory defaults can also rectify this issue.
You can view http://www.techyv.com/questions/why-do-i-get-out-range-message-my-monitor for more information.
I hope this would be of some help.
Feb 05, 2012 | LG Flatron L1515S 15" LCD Monitor
I have set the screen resoloution to high for my monitor and now get a message saying "screen resoloution to high set to 1680 x 900" but cant reset it as all i get is the message and a blank...
First try shutting system down, unplug tower for 1 minute and restart. Give it time to come up and if that doesn't work, shut it down again and try to start in "safe mode" do you get any screen at all? If you can start in safe mode try going to "control panel'", "device manager" then "personaliztion", and adjust your resolution. If you can't adjust your resolution in safe mode do a "system restore" back to when monitor worked.
Apr 04, 2011 | Computers & Internet
My monitor has a hourglass screen and not a full screen please help
Look in your monitors menu screen. You will see a setting to change that. On mine it is labeled "Pincushion", it bends the middle of the screens image to compensate for the curve of the glass
Sep 22, 2009 | HP Computers & Internet
Cannot get by dell screen to come back on once it hibernates
sounds like a power scheme setting is shutting off your monitor after a time-out period. sometimes monitor will not return without re-boot. change your power options settings in control panel.
May 16, 2009 | Dell Inspiron 6400 Notebook
Blue tint on computer display monitor
Try
1. Unplugging the video cord from the back of the computer (and screen if it comes off) and plugging it back in. Sometimes it can become loose and cause a screen to have a abnormal color contrast
2. Updating the drivers to your card
3. Trying a different monitor on the computer. Mind you, if you plug in a differant monitor and the color stays the same. Check the videocards pins on the back of the card. I dont know if you gave all the info on how it became like this, so maybe it got undone and plugged back in forcably and one of them got bent? I
Also if the pigment goes away. Plug the normal one back in and if its gone, great!, if its back. Try the OSD settings on that monitor. Still no luck. The monitor is junk.
Hope that helps
Nov 30, 2008 | ViewSonic Computers & Internet
Freezing then blank screen
Have you tried pressing F8 on boot-up and log into safe mode under administrator, no password, and right click on any empty space on the desktop, left click on properties, left click on settings, select a lower resolution,( e.g. 1024X768 ) select apply, select ok, reboot, log in as normal
Mar 26, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Screen shutting down
Well, Gestion Alim is French for "Power Management." It means that your computer is shutting off power to the video using the ACPI power settings, probably stand-by or hibernation. Bring up the Power Management settings in your operating system (in Windows, it's the Display icon in the Control Panel) and change them to something more reasonable. If you want to disable them completely in Windows, change to "Presentation" and make sure that hard disks and display are both set to "Never" shut-off.
Nov 08, 2007 | LG Flatron L1750S 17" LCD Monitor
Dell 2407 a04 Turns on (for 2 seconds) then off
your pc may be set to a resolution that is out of range for the monitor. Boot into "Safe mode" reset the Display settings to 640 x 480. reboot into normal mode then change the screen settings to your desired resolution.
Sep 07, 2007 | Dell UltraSharp 2407WFP 24" LCD Monitor
ViewSonic E70 17" CRT Monitor Logo
56 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
