Question about Whirlpool MH7135XE Microwave Oven
Nothing works, blank touch pad
I was attempting to undo the under side lights and the bulb seemed to separate from the base and all of a sudden the unit died. I tested the outlet for power and it was ok. I left unplugged for awhile and replugged but still nothing. Another site sounded as if I have blown a circuit board. Any help would be appreciated.
Jack
    Problem Solver:
  • 8 Answers
Before you replace a circuit board check the inline fuse on the unit if you take off the the front panel you usually can see the fuse it is a 20 amp fuse you will need an meter to check resistences across the fuse it should read read 1 to 2 olhs on the meter if that does not work then you need to check tstat on the megatron itself or the the cavity tstat more than likely it is the fuse
Posted on Mar 22, 2008
How do I replace lamp?
Yes, the light bulb base needs to come out so that you can replace the whole unit (bulb & base.) These lamps are known for separating when you try to remove them. I would recommend a needle-nosed pliers to get the base out. If you need to unscrew it and can't get ahold of it with pliers, you might try using a carrot! Cut the carrot a short ways down from the stem, then push the cut end into the socket and unscrew it.
Sep 28, 2015 | Danby DMW1146SS Microwave Oven
I am having a problem with the under unit light not working. new bulb, no help. Interior light is good
If you are sure bulbs are good then problem is usually the main control board. This is an expensive fix just for lights but the relay that turns the lights on/off is mounted on the main board that also does everything for the microwave. Some older microwaves had separate switches for the lights that were not attached to the main board but almost all newer units have everything on the board and work through the same touch pads on the control panel.
Mar 29, 2015 | Microwave Ovens
I shorted out the counter lights on my frigidair microwave. The microwave works but not the lights. I've replaced the bulbs. What next?
The metal base may have fused together from electrical arcing when the old bulb was removed. The entire bulb receptacle (socket) will have to replaced. If you cannot do that yourself, the cost would be excessive. Just live without the light as long as the microwave gets the job done.
Dec 10, 2014 | Frigidaire FMV157GB Over-the-Range 1.5 Cu....
On my GE Profile Microwave the led is lighted and shows the time correctly and displays the led buttons. When I press on the led buttons nothing seems to happen. Also, after some idle time, the led panel...
The touch panel has malfunctioned, Suggest replacing microwave unless you want to attempt repair. If so you will need a replacement touch panel for it.
Jun 14, 2017 | GE Microwave Ovens
Kenmore microwave nights light don't work.
That's a problem on the circuit board which can be repaired simply and inexpensively.
A YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes, is here.
Nov 30, 2012 | Kenmore 62622 Microwave Oven
Hello, I have a Panasonic MMT573SBBPQ microwave oven. 1. The turntable table stopped working. 2 Tested motor all OK 3. Noticed bulb had blown - replaced this (as was on same circuit as motor) 4. result :...
Check the door switch and once the door is shut the board must be active. If there is no clock or display then the processor board is faulty. Also if there is no action from the touch pad then it must be checked. Since the turntable works as you start the processor seems to work but the output to the magnetron is not active. So you need to check the relay to the magnetron switching, check the temperature cut off unit and the main capacitor.
All the above seems to be suspected.
Attempt with care/caution as there is high voltage present.
Aug 09, 2011 | Panasonic NN-H764 Microwave Oven
I have the GE profile spacemaker microwave oven installed over my stove. One of the lights burned out on the left lower portion of the unit. I removed the screw, lowered the metal cover, and tried to...
You could try the potato trick. Take a small to medium potato. Cut off an end of the potato. Press the cut end into the broken lightbulb and unscrew the rest of the bulb out.
May 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave touch pad work light doesn't work
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 29, 2007 | Microwave Ovens
On replacing nite-lite/under hood bulb, 1 lead broke off in the socket
Be sure to disconnect the oven from the power line before removing or installing bulbs or working on it. You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383 We have critical safety & disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Apr 22, 2007 | GE JVM1490 Convection/Microwave Oven
Surface lights
I also have had a problem with the glass part of the surface light bulb separating from the metal base when trying to change the bulbs under my G.E. Spacemaker Microwave.. I see someone used a carrot or potato but I had not seen this suggestion before I whittled one end of a wine cork small enough to insert into the metal part of the old bulb stuck in the socket. It also worked great and in no time I was able to get the old base out and replace the bulb. I'll save the cork for next time because it seems to happen to at least one of the bulbs everytime they need to be changed. DON'T FORGET TO UNPLUG THE MICROWAVE FIRST!
Sep 05, 2006 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool MH7135XE Microwave Oven Logo
132 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
