Question about Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive
Tryi8ng to install portable 120GB hard drive (seagate)
Have a FreeAgent Go Data Mover (portable HD) purchased this morning but it will not install as a plug and play ... OS xp pro.
Light keep flashing on new drive. "After your data mover lights up, a dialogue window will appear and tell you what to do next." THIS does not happen. NOT a 250 GB but a 120GB
Jack
  • 3 Answers
If your USB ports do not supply enough power (older computers) then the drive may fail to show up in My Computer.
The Seagate should have a special Y cable. There are two USB connectors on one end that must both plug into your computer - one for data and power - the other for power only. The other end of the cable has the mini USB which plugs into the Seagate.
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=External_Drive_Troubleshooter_-_Windows_Error_Messages_-_Common_External_Drive_Errors&vgnextoid=14d24a3cdde5c010VgnVCM100000dd04090aRCRD#clicks
Posted on Jul 09, 2008
Seagate goflex 500GB portable hard drive deleted or currupted system files so windows won't detect it.
Try a remote access data recovery service like http://FreeDataRecovery.us
They do online data recovery via the internet and also offer do-it-yourself data recovery assistance.
Oct 18, 2012 | Seagate 500Gb Freeagent Goflex Portable...
Hi, My Seagate Freeagent 500GB Go HD (Hard Drive) has switched to Raw format. I want to convert it back to NTFS so I can retrieve my data. The drive shows up in My Computer or Computer, but I can not...
click start run type cmd then type chkdsk/f which will automatically fix any corrupt files on your hard drive then defragment your hard drive
hope this helps
Sep 19, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How can i partition my 320gb sea gate ext harddisk
you can partition your hard disk while installing windows xp
and if you want to parition your hard disk after installing your windows,you will need third party softwares called parition magic which are free to try,but you will have to buy those softwares to use it,so its better to paritiyion your hard disk while installing windows
Jul 22, 2010 | Seagate 320GB FreeAgent Pro FireWire 400,...
My computer doesn't detect my FreeAgent Pro 750GB (seagate)!!!
Do not despair - check out the documentation on page 3 (you'll need Adobe Reader to open this PDF file):
http://www.seagate.com/support/freeagent/FA_Pro_15_QSG_US.pdf
Hope this helps
Sep 20, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have a freeagent go 500gb portable hard drive. Can I partition?
YES YOU CAN YOU CAN INSTALL AND USE ACRONIS DRIVE PARTITION OR CONTACT SEAGATE TECH SUPPORT AND THEY WILL ASSIST YOU.RICHARDM69
Mar 10, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent Pro Desktop 250GB - no power
go get a external drive enclosure from computer supplier
compusa
best buy
circuitcity
Feb 04, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My external hard drive is unreadable
Does you drive make any sounds like these? If yes you have a mechanical problem and you should get a specialist to work on it. If not - try to remove the drive from USB casing and connect it directly to your PC or put into another USB enclosure. This should help if the problem is with the enclosure itself and not with the drive.
Dec 30, 2008 | Seagate FreeAgent Pro 1TB External USB...
Freeagent go 120GB drive
go to seagate.com and type drivers in serach box , select your operating system and download and install the drivers.
Oct 28, 2008 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
Reformat seagate 120gb portable harddisk - freeagent
Hi johnsil,
If the drive shows up in MY COMPUTER then the easy way to format the drive is right-clicking on it then choosing FORMAT. This will erase everything in the drive, so make sure to back up everything in the drive before formatting it.
Now if the drive doesn't show up in MY COMPUTER you may have to goto the Control Panel click on Administrative Tools then select Computer Management then click on the category of "STORAGE", you should see there Disk Management. Carefully look there for your Seagate 120GB Freeagent drive, right-click then choose format, and that should format the drive.
Hope this helps!
Peace! :)
Oct 20, 2008 | Computers & Internet
Seagate FreeAgent  Go 250 GB USB 2.0 Hard Drive Logo
236 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
