Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Fridge freezing Problem with Side by side kenmore fridge, started to note that the bottom compartment in the fridge was developing ice on the inside edge, top of compartment warmer, adjusted settings but then freezer developed alot of frost building up, took lower cover off and pulled out and vacuumed all dirt and dust from it. i have left unplugged to thaw out for 24 hours. Why did this happen? could it be the evaporator?
  • Anonymous Mar 22, 2008
    The crisper area in the fridge keeps icing the food stored there.
    President:
  • Kenmore Master
  • 2,651 Answers
A defrost problem, is gonna cause excessive ice build up in hte frezzer lower compartment. for somereaon the hdefrost heater was not energized. most common reason is a bad defrost thermostat, clipped on one of hte evaporator coils has gone bad,
Posted on Mar 22, 2008
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
My refrigerator stop producing ice even though the filter is new.
Check the tube that goes to the Ice maker mold tray from the back of the freezer compartment.If this tube is filled with ice, then the fill valve for the ice maker is not sealing completely. The very slow flow of water freezes in that tube. It requires that you replace this with a new valve. The valve is located in the bottom section of the rear of the fridge. You will need to remove the cardboard cover to get to it.
The valve assembly on side-by-sides is a combination part that also has the valve to the ice water dispenser on the door. When doing this repair yourself, make sure that replace the cardboard backing on the fridge, as it will not cool properly without it.
Hope this helps,
Best, Mark
Dec 28, 2010 | Kenmore 57029 Side by Side Refrigerator
Side by side thermostat set low seems like it runs a lot more than it use to freezer and fridge are boyh cold
Check your coils underneath the fridge to be sure they are clean.
Check your condensor fan (bottom rear of fridge) to make sure it is blowing air freely.
Make sure you have a good supply in the freezer, All of your cooling comes from the freezer section and a mostly empty freezer will result in more frequent running as ther is not enough stock to help maintian and hold freezing temperatures.
Check your freezer section to make sure there is no visible frost on the back wall of the freezer (down low on the panels behind and slightly above the lowest freezer basket. If you see frost starting to develop it means you have a defrost issue starting and will want to adress it rather quickly. Either a problem with the defrost control board (inside fridge/freezer control compartment) or the defrost thermostat (behind the freezer back panel on top of the evaporator coils).
Hopefully this helps!
Jun 14, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Kenmore Elite Side by Side about 6yrs old. It is working (fan is running, lights are on) just not producing chilled air. Any Thoughts?
Check that the condenser is not iced up and check that the air ducts are not iced up. Easiest way is to deforest the s/s entirely. If the Fridge is the problem and the freezer is OK then also check the electric shutter valve at the rear top of the fridge compartment on the side next to the freezer. This is where the cold air is sent into the fridge compartment by the cooling fan and air ducting. These do have a tendency to ice up and then breakdown so they stay shut and the Fridge keeps warm or they stay open and the fridge ices up and freezes the contents. Contrary to beliefe these types of FF are not totally frost free.
Nov 04, 2009 | Kenmore Elite HE4 Electric Dryer
Ice maker makes ice then water dripps and freezes
water valve not working properly needs to be replaced ... located on bottom back nof fridg
Aug 11, 2009 | Kenmore 21.9 cu. ft. Side-By-Side...
Fridge does not keep cold, but freezer is over freezing, icemaker not making ice also.
You should be able hear, and feel the air from, a running fan inside the cabinet, in either side. The common arrangement is having the coils located (behind the wall) in the freezer section and then the fan moves a controlled amount of the frigid air to the refrigerator section via openings located in the rear of the compartment. The vents are normally adjustable so the temperature can be balanced between the two compartments.  If there is no noticeable air coming from this vent, then the fan has died.
May 25, 2009 | KitchenAid KSRS25ILSS Side by Side...
Top freezer Freezes/ Bottom not cold
defrost problem. advance defrost timer to defrost (till it shuts off) . remove freezer panel, check voltage and amps to heater,if heater is hot, replace timer, if heater is cold and no voltage, replace defrost limit switch. defrost all ice, carefully! with hair dryer, no poking with screwdriver.
Oct 26, 2008 | Kenmore 53642 / 53644 Side by Side...
My Kenmore Fridge (bottom freezer type) not freezing
Look for problems you can see. Check for frost on the back wall of the freezer, If you find frost on the back wall locate the defrost timer and rotate the clutch head screw clockwise SLOWLY until you hear one click. With the timer now in the defrost position you will hear sounds in the freezer compartment such as expansion, sizzling, after a few minutes. If after say 25-30 minutes the system does not return to cooling mode ( Compressor starting) rotate the timer again SLOWLY until you hear a second click. This would indicate a bad defrost timer. If you get no defrost your problem could be a defect in the heater circuit such as an open heater or defrost thermostat. Normal defrost time would be 18-22 minutes.
May 20, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore elite fridge crisper drawer freezing stuff
If you have a side by side model you need to look at the refrigerator compartment wall on the left of the bottom drawer and move the slide control to the warmer/fruit/vegitable setting instead of the meat setting.
I hope this helped. Please rate my help or ask for more help please. supertechks
Apr 05, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
161 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
