Question about Philips Magnavox 51MP392H Rear Projection Television
No color red
I have no color red.
  • Philips Master
  • 8,617 Answers
You either have a bad red drive circuit or a bad red crt. try switching the crt socket from the green to the red crt and see if the red crt will light up. If it doesnt you will need a new CRT. If it still doesnt light up then you will need to troubleshoot the red drive circuitry. Let me know if you need more assistance.
Posted on Mar 22, 2008
SOURCE:
Color code on isuzu rodeo 2002 ls
You should have a plate or sticker under the hood on the firewall on the drivers side that lists the color code. With many manufacturers there may be several variants to the stock color throughout the model year so it's possible that even with the color code your final color may not match exact, but it will be close. If you're still not able to find the color code on your vehicle, try removing the fuel filler door and seeing if your paint supplier can camera match it for you.
Apr 02, 2014 | Isuzu Rodeo Cars & Trucks
My pokemon red won't let me see it in color everything is red and people and pokeballs are green
You do not have a problem with your game or system. The original release of both Pokemon Red and Pokemon blue came with very limited color palettes. As such, your Game Boy Color can only render certain objects in a different color. For clarification purposes, both of these titles were released before the launch of the Game Boy Color so wouldn't have been given the color palette upgrade. Hope this helps.
Nov 23, 2010 | Nintendo Pokemon Red
Can't red and green colors
This usually means the red or green or both primary color module is bad. Monitors come with 3 primary color module controllers and they use them in various combinations to make the other colors. The primary colors are blue, green, and red.
Sep 17, 2010 | NEC AccuSync 900 19" CRT Monitor
Red color cannot print
I presume the LCD screen on the printer also shows that there is toner. Take the toner out and reinsert it. If that doesn't work use the hp software to troubleshoot it may give more information.
Apr 04, 2010 | HP Color LaserJet 2600n Printer
No red color printing
Possible nozzle blockage, usually solved by physically squirting cleaning fluid into nozzle and letting soak for a while.
Printers are so cheap nowadays perhaps it might be worthwhile investing in something new!
May 27, 2009 | Office Equipment & Supplies
Will not print true colors especially red and blue and green
replace the two ink caterage to a new one. it could be from the ink you refill that is if you refilled. bye
May 22, 2009 | Compaq Inkjet IJ600 Printer
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
My webcam shows only red
basically we use RGB color system so it contains color like red green and blue....in ur web cam settings u only increased the content of red color and u decrease the content of green and blue...so pls take ur settings and put all three colors to a same number...it means u have number from 1 to 100 and u can give the red green and blue colors up to this limit....so put green in 32 and red in 30 and blue in 32......then it will b corrected
Sep 20, 2008 | Logitech Webcam
One of the primary color is absent
Hey Kuld.. Just asking... since both, your TV and your monitor have the same color issue...??.... have you been to the optometrist lately... (My Dad had this color issue with his eyes!).. he was red color blind..
Good luck,
Jun 20, 2017 | LG Studioworks 700B (White) 17 in.CRT...
Picture color
have JVC AV-32F702 TV. It's picture color is very red. unable to adjust colors through menu. Channel numbers are also in red now instead of normal green. any suggestion? please check red color cathode circuit 1 check red output from ic to red cathode ckt 2 check voltage on r output ckt& ic or tr. 3 check loose contact in red cathode ckt 4 check crt base for loose. 5 loose connector 6 chroma ic thanks
Sep 09, 2007 | JVC AV-32F702 32" TV
Philips Magnavox 51MP392H Rear Projection Television Logo
85 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
