Question about Epson LQ-2180 Dot Matrix Printer
Paper Thickness Lever
When i try to print out my documents by using the 3-ply computer form paper, i adjust the paper thickness lever to no.2. The 3rd ply of the computer form comes out to be very blur. So, i try to adjust it to no.1, the 3rd ply is clear but the problem now is the 1st ply of the computer form paper becomes very dirty with the drag ink line accross the paper. Then i try to adjust it to no.0, the thing is getting better and the drag ink line is not there. I'm just wondering, does it mean that it's time to change my printer head or the paper thickness lever got problem already? How should i solve the problem then?
I think there's a problem with the pin of your print head. it becoming worn-out. so replace it, or you buy the head print new one...
Posted on Apr 18, 2008
    New Friend:
  • 159 Answers
There is a part we could it mask its piece of metal in front of the head clean if the problem dos not solved tray to change
Posted on Mar 22, 2008
Can I use thick paper to print on Epson DX 8400? Is there any way to adjust the thickness of paper?Thank you.
There is a Paper Thickness lever on the left hand side of the front of the printer. If you go to the following website:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?infoType=Doc&oid=58606&prodoid=56291067
You can get the Product Information Guide, or the User's Guide. Both of these will describe which setting you should use for a wide variety of paper. For normal single sheets of paper the lever should be in the down or "L" position. If you are using envelopes the guide instructs that the lever should be in the up or "H" position. They give you a complete table with the appropriate settings to use depending on the thickness.
Thank you for the opportunity to assist you in resolving your issue. Should you need further information or assistance please do not hesitate to let us know.
Feb 19, 2011 | Epson Stylus CX4800 All-In-One InkJet...
How to install paper in oki microline 320 turbo printer
Paper Loading
Rear Feed, Continuous Forms
Use the rear-feed path for printing on single-thickness,
continuous-form paper.
Use the single-sheet path (top feed) for graphics or charts.
! If you have paper in the paper path, be sure to remove it
before installing rear-feed paper.
1 Lock Lever
2 Upper Tractor Cover
3 Pins
4 Lower Tractor Cover
32T-26.eps
1 Move the paper lever to the position marked "REAR."
32T-11.eps
2 Grasp the tabs lift off the paper separator.
3 Pull up on the lock levers and open the tractor covers.
Then, move the right tractor to fit the width of the paper.
32T-27.eps
4 Place the first two holes in the paper over the tractor pins
on either side. Close the tractor covers.
32T-29.eps
5 Move the left tractor to align the edge of the paper with
the appropriate reference mark (1). Then, push back the
lock lever.
32T-29A.eps
6 Adjust the position of the right tractor to center the holes
in the paper on the pins. Then, push back the right lock
lever.
32T-29.eps
7 Install the paper separator. Place the wire guide (1) on the
pull-up roller assembly (2).
32T-31.eps
8 Press FF/LOAD. The paper feeds into the printer.
! The factory default setting for the Top of Form (where
the printing should begin) is one inch down from the top
of the page. To change the setting, see "Using Your
Printer, Top of Form (TOF)."
Top Feed (Single Sheets)
Use the single-sheet path for letterhead stationery, memos,
and individual envelopes.
! If you have continuous-form paper in the path, press
PARK to remove it before loading single sheets.
1 Make sure the printer is on and deselected (SEL light off).
2 Place the paper lever in the position marked "TOP."
32T-12.eps
3 Open the carriage cover. Raise the paper separator to the
single-sheet position.
4 Make sure the wire feed guide (1) is secured in the sheet
guide.
5 Adjust the paper feed guides (1) for the width of the paper.
Place a sheet of paper in the separator. The paper will feed
into the printer.
32T-15.eps
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
Jan 04, 2011 | OKI MICROLINE 320 Turbo Matrix Printer
Im just getting a "paper thickness lever position" error. I tried adjusting it as described in the manual, but am still getting the error
the thickness of your paper does not match the setting of the paper thickness of the Printer. try and reset the thickness setup.
Oct 27, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
The print is only clear on the left side of the forms...
Platen Gap Adjustment (Figure 35)
IMPORTANT Only do this procedure if the original equipment shuttle frame assembly or platen has been replaced by a new or
refurbished unit.
1. Prepare the printer for maintenance (page 338).
2. Remove the shuttle cover assembly (page 357).
3. Loosen the platen open belt (page 415, steps 2, 3, and 4).
4. Raise the forms thickness lever (1) to the fully open position.
5. If you are adjusting any model except the 6400-i20, select a 0.011 inch (0.28mm) flat feeler gauge.
If you are adjusting a 6400-i20, select a 0.012 inch (0.30 mm) flat feeler gauge.
ATTENTION Do not force the platen against the feeler gauge. Damage to the hammer tips will result.
6. Insert the feeler gauge (2) straight down between the hammer bank cover plate (3) and ribbon mask (4), within four
hammer positions of the left end of the hammer bank.
ATTENTION Adjust the platen set screws less than 1/4 turn on one side, then check the other side. Adjustment sensitivity is
approximately 0.03 inch per revolution of the set screw. Also, insert the feeler gauge no more than two inches down
from the top of the ribbon mask.
7. Gently close the forms thickness lever (1). As the platen is closing, gently slide the feeler gauge up and down, keeping it
between the hammer tips and ribbon mask. If the feel is too tight as the platen closes, adjust the 3/32 inch set screw (5)
counterclockwise. If the feel is too loose, adjust the set screw clockwise. With the forms thickness lever closed all the way,
the feeler gauge should contact both the tips and the ribbon mask and move with light friction. Shift the gauge slightly to
verify.
8. Repeat steps 4 through 7 at the right end of the hammer bank.
9. After adjusting both sides, check the gap again at both ends. Readjust if necessary.
Aug 25, 2009 | IBM 6400 Matrix Printer
Will not print and keep getting paper thickness error
Did you try moving the paper thickness lever (blue lever on top of the print cartridge holder)? It should be all the way to the left when you start--if it needs to be adjusted the printer message will let you know.
Jun 27, 2009 | Canon i850 InkJet Photo Printer
Ink smudge on envelope
dvlknc
The paper thickness lever is not on the front...it is on the floor of the "paper output tray" chamber. It is hard to see without directed light.
Refer to Loading Paper section of the Quick Start Guide....p 15 2 Prepare to load paper
(4) Adjust Paper Thickness Lever
(See diagram)
Or look at the "User's Guide on-screen manual" as directed by the Note on p. 17
I really had to search to find this lever while attempting to resolve my problem with a badly aligned printing head. I am going to have to buy a new printer. It definitely won't be a Canon due to the rip off cost of print cartridges.
Hope this is helpful.
kellyplus
Nov 14, 2008 | Canon PIXMA MX310 All-In-One Printer
Paper thickness error not clear
i have a brother DCR375CW and it will not print on card it keeps saying no paper feed , how do i set it for card thnaks
Sep 29, 2008 | Office Equipment & Supplies
Printer won't print
hi Printer won't print but the paper come out
Jan 02, 2008 | Canon i 550 InkJet Printer
Failed to print
At the head you said 'paper thickness position'and then you seems to have ignored that and did all the other things. Is there an adjustment for paper thickness, a lever perhaps. It does seem to be with the paper feed or paper presence detection. Take a look around, is there something stuck in the paper feed track? Can you have pass a piece of paper through without it rucking up? Do these things see what happens Take a look also at www.fixyourownprinter.com
May 26, 2007 | Canon BubbleJet i550 InkJet Printer
Epson LQ-2180 Dot Matrix Printer Logo
324 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
