Question about Kenmore 24032\24036 Top Load Washer
Kenmore elite washer
My kenmore elite top loading washer does not put in cold water. I can wash with hot water with no problems. I have even switched the hoses around thinking that i could wash with cold in the hot cycle but that don't work. I know that water is flowing free through the hoses. What could be the problem?
  • mwhamrick Jan 06, 2009
    Kenmore elite intermitently fills with cold water, I replaced the switch on the control panel, did not fix it. Other temp water works fine. Could it be the e.t.c. sensor or the e.t.c. dial? Water lines and filters OK.
    President:
  • Kenmore Master
  • 2,651 Answers
Sounds like you have a bad water valve,,either that or a bad water temp select switch,(doubt that). way more common is a bad water valve.
Posted on Mar 22, 2008
How do i fix the FH error code on a kenmore elite he 3t washer?
This indicates a water problem. Make sure you have both hot and cold water turned on and running to the machine. If pressure is to low on either hot or cold you will also get this reading
Jun 23, 2014 | Kenmore 24032\24036 Top Load Washer
Cold and hot water switch
Switch the hoses where the water comes in the washer.
Aug 23, 2012 | Kenmore Elite 45986 Front Load Washer
Hot water coming out on cold setting
try switching the hot and cold valves on the back of the machine and see if it works if it does just the oppiste then it's the water valve in the back where the hoses hooks up.
Jul 23, 2009 | Kenmore Elite 45986 Front Load Washer
Washer only puts out hot water.
switch your hoses around this could be your problem
Jun 06, 2009 | Kenmore 24902 Top Load Washer
Washing machine won't heat water
it sounds like the hot water supply hose on the back inlet water valve is not opening up,to check it switch the hoses,cold on hot,and hot on cold,put the washer on fill cold,if hot water comes out you know it's the water valve-mike
Mar 21, 2009 | Kenmore 80754 Top Load Stacked Washer /...
Kenmore Top Loading washer gets very little cold water
You could try reversing the water lines and see when you select hot if cold comes out strong. If it does not then it should be the valve. If it comes out good in reverse, it could be the tempature sensor. Here is the link to parts and diagrams.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=11023032100&productCategoryId=0153200&brandId=0582&modelName=WASHER&diagramPageId=00003&componentDescription=REAR%20PANEL&documentId=P0110152&backToLink=Return%20to%20Sub%20Components%20list
Mar 04, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore front load washer: no cold water problem
that's odd.
if you choose cold/cold then check your hose orientation. you could have put the hot water to the cold solenoid.
or the wires have been interchange, the hot water wire was plug to the cold solenoid and the cold water wire was plug to the hot water solenoid.
or hot water is still flowing to your cold water line.
if the cold water solenoid is the problem, then there should be no water at all going to the tub.
try to experiment, try to switch to hot/hot and see what would come out...
tnx 4 using fixya,
drcool
Oct 02, 2008 | Kenmore Energy Star 44092 Front Load...
Kenmore 24032\24036 Top Load Washer Logo
124 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
