Question about AOpen MX46-533V (91.89U10.061) Motherboard
No Video! I have an AOpen MX46-533V motherboard. On the motherboard, the light is red, the cpu, and power supply fan is working, the problem i'm having is that I not able to get any video on a working monitor. I've tried like 7 video cards and even my onboard vga slot doesn't work. What can I do? I know it's a good motherboard, and I don't want to discard it. Please Help Me!!
  • Anonymous Nov 29, 2008
    hi I have the same problem and when I turn the computer and monitor on the monitor says no input signal cable not connected or power saving. I have reset the cmos checked my video card and the ram and it still does the same thing.
    Genius:
  • 1,913 Answers
Hi
change your ram try onther ram.if stiil pro then clean your processor case .
change your smps.
Posted on Mar 23, 2008
  • AOpen Master
  • 13,433 Answers
Hey, il look into this problem more in a minute but
the light is red you said. Mine is green when working.
Il check the manual now and get back to you.
Posted on Mar 22, 2008
  • Ekse Mar 22, 2008
    Hey lets try a few things
    if you have the manual you can read better instructions from there if needed.
    1st reset the cmos memory (bios)
    Theres a is a red jumper on the motherboard
    manual page 21
    unplug your pc
    Open the case
    find the red cmos jumper at bottom right.
    You need to pull the jumper up, it comes loose, now place it back on in another position so its connecting the other pin witch was free before you pulled it out.
    let it be for a few seconds
    pull it out and place it back how it originally was.
    the bios has been reset, plug your pc back in and test to see if it works.
    If not, can you tell me details of what cpu, video and memory cards you have installed.
    Thanks
I have got a system with an Aopen motherboard which having only a 20 pin connector for smps connectivity. the Atx smps i have is is 24 pinned. i can connect the main line by splitting up the 24pin...
The actual Processor fan connects to the CPU Fan header on the mainboard. It's 4 small pins. It plugs in right near the CPU socket on the mainboard. Check the user manual for exact placement, you may download it from the AOpen website if you don't have one already.
Plug in the 20Pin connector if that is the most Pins that the mainboard will allow. Cable tie the other 4Pins back onto the 20Pin connector.
Then if there is additional 4Pin connector required by the mainboard for CPU power and you don't have that connector on you power supply, you will need to purchase a Molex to 4Pin CPU power connector. When you go to the computer store check with them that all is correctly connected.
Take care!
damnor01
May 25, 2011 | AOpen MX4GER Motherboard
I have an AOpen vKM400Am-S Motherboard, when i turn it on a red light and cpu fan turns on but no video to my monitor,i checked if my video card works on a difrent pc and it did, my pc wont turn on
this caused by RAM error, open your computer, disconnect ram, turn on your computer?is computer beeping, 1 long and 2 short beep??if yes the problem is come from your ram, clean your ram connection then connect ram to mother board, turn on your computer, is the video come to screen??if no, try to connect another ram to your computer, for sure use new ram
i hope this helpful
thank you for using fixya
Feb 05, 2011 | AOpen MX4LR (91.89Y10.002) Motherboard
There is a red light glowing on my motherboard
give me sound dirivers of ibm thinkpad R50
Dec 23, 2008 | AOpen AX4SPE-UN Motherboard
Aopen mx4lr motherboard Pc wont turn on.(not even fans) the motherboards led1 and led2 are both red. Could this be motherboard? Or is it the power supply? Or even the power button itself?
check your power supply with tester first make sure that all power plugs are in all pluge on board some take a 4pin plug by the cpu socket as well looks
Dec 16, 2008 | AOpen MX4LR (91.89Y10.002) Motherboard
My mother board AOpen MX4LR, socket 478, dead
bad mobo or psp is bad try psp for now lock down mobo tight also losee no good
Jan 06, 2008 | AOpen (MX4SGI4DN2PRE) Motherboard
Aopen mother board diagnostic light lite up
if that problem...that motherboard is defective ...i suggest to buy a new motherboard that compatible to your processor and memory... i'll give a link of site to buy the part.....
http://search.ebay.com/search/search.dll?sofocus=bs&sbrftog=1&dfsp=1&from=R10&_trksid=m37&satitle=motherboard&sacat=-1%26catref%3DC6&sargn=-1%26saslc%3D2&sadis=200&fpos=ZIP%2FPostal&sabfmts=1&saobfmts=insif&ftrt=1&ftrv=1&saprclo=&saprchi=&fsop=1%26fsoo%3D1&fgtp=
Dec 17, 2007 | AOpen vKM400Am-S Motherboard
Hard drive shuts off?? I think.
replace your power supply, you need to upgrade this to at least 500watts to avoid problem like this, there is no problem with your hard drive its your power supply
Dec 11, 2007 | AOpen AX45-V (91.88I10.004) Motherboard
Motherboard ABIT KN8
i dont know about the red light, but all main boards these days have a built in protection if the cpu fan quits. check the cpu fan connection, ensure that it and the heat sink are dust free. if still no go. update  your question with exact info..e.g. does absolutely nothing.. how many beeps you hear..how long b 4 it dies.. final note: be careful what you touch.. static can harm more that most think and the oil from touching can retain heat.
Oct 29, 2007 | Abit KN8 Ultra Motherboard
Help pc problems???
CHANGE THE POWER SUPPLAY.. BUT FIRTH..
1-UNPLUG HD AND TEST WITH FLOPPY OR CD BOOT DISK
2-UNPLUG YOUR MEDIA ROOM LIKE CD OR DVD AND TEST ONLY WITH FLOPPY BOOT DISK
3-UNPLUG VIDEO CARD AND ALL CARD ON YOUR MOTHERBOARD.. TEST ONLY WITH THE FLOPPY DISK AND ONBOARD VGA.. OR GOOD TESTED VGA CARD.
EXCUSE MY BAD ENGLISH.
CO3OV
CUBA
VICTORES45@YAHOO.ES
Oct 14, 2007 | AOpen AX45-V (91.88I10.004) Motherboard
Compaq Presario 4400us
Either the new power supply you purchased is not functioning correctly. But, assuming it is now that you are getting some form of power to your PC, it is very likely the motherboard. Whatever fried your old power supply (or it could have just been the power supply itself) most likely fried your motherboard in the process. Probably not the CPU since the MB can't even post.
Jun 21, 2007 | Compaq (388746-001)...
AOpen MX46-533V (91.89U10.061) Motherboard Logo
133 people viewed this question
Top AOpen Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Matthew Spark
Matthew Spark
David
David
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
