Question about EliteGroup ECS 945GCT-M/1333 Motherboard - v3.0, Intel 945GC, Socket 775, MicroATX, Audio, Video, PCI Express
945GZT M V1.0
Hi Ladies/Gents , I tried playing with the set up menu and after trying to make some changes, when booting up it could not even go to the setup menu. I am now stuck with the first screen showing only American Megatrends startup message .
Appreciate help .
Many thanks David
Shugster is right - had the same exact problem. After removing and replacing battery, it took 15-30 seconds for the F1 message to display. Then I could set my date time and boot sequence. After doing that and rebooting, it takes 15-30 seconds (a lifetime!) to get past that first screen - there are no beeps, it just looks hung, so be patient.
Posted on Apr 08, 2008
  • 93 Answers
David i take it you mean you played with the bios screen ?
if so you can remove the power cord then open the side of the computer and remove the bios battery (big silver watch type battery on the mother board) leave it for around 15 mins replace the battery then the power cord you will find an error screen when you switch on.
its normally f1 to load default settings and continue the boot
that should solve it
Posted on Mar 22, 2008
Ladies/ gents I need help please to unlock Bios Password on Dell Latitude E 6410 laptop, the SN# is 32JD3Q1-1F5A. Thank you! Ion
Try following the instructions on this page: http://forums.mydigitallife.info/threads/43628-FAQ-(forgotten)-Dell-BIOS-Password
Feb 05, 2015 | Dell Latitude E6410 Laptop
Trying to find 3 layer or 5 layer fringe boots in UK. USA do not ship them to us
Hi, if you go onto ebay.com and type in ladies fringe boots you will get a wide selection of them, rangin from 1 layer fringe to about 6 layer fringe,
Hope this helps
Feb 18, 2011 | Minnetonka 3 Layer Fringe Boots Boots for...
I have facing the problem in my laptop ... was powering on but no display
change the boot formate to f12 keep pushing f2 f2 f2 when first page comes push f2 then change boot formate to f12 then pushf10 for saving the boot setting then restart lap top then push f12 then run windows under d:drive.
Feb 18, 2011 | ECS 945GZT-M (V1.0) Motherboard
Peugeot 205 diesel - grinding noise on full lock.
may be the slip joint in the steering column is slipping in a rotational way stick your head under the dash and turn the wheel and watch the slip joint in the column if the lower part stops but the top part keeps moving get a new/ second hand stearing collum
Oct 02, 2009 | 2001 Daewoo Nubira
Aspire AM1201 does not boot up.
hi im josh in cebu phil. try to enter bios set up.go to power menu.then try to change the setting of power loss to shorter time then save the changes then restart your pc. good luck.try to txt if problems continue.
Feb 16, 2009 | Acer Aspire M1201 Athlon X2 320 Gb PC...
Ram Upgrate on 945gzt-m motherboard
Sometimes motherboards have the option through BIOS to change bus speeds, but not the memory chips. Usually, the wrong speed will just not work. It won't fry anything, it will just give you long beeps and won't boot up. I've not put any onto a board like yours, but I did try 667MHz chips with one I had with the same memory specs (400/533MHz) as yours and they did not work. You might consider mail order. Newegg.com has pretty good prices. They are very reputable and have very good customer service.
Jan 23, 2009 | ECS 945GZT-M (V1.0) Motherboard
Driver upgrade
Hi papaduds,
I see what you mean, have you tried any other screensavers besides the aquarium one? It's also possible that the screensaver itself is the problem. Otherwise if the problem with the screensaver happened a couple of days ago, you can still try to do a Windows System Restore, and bring the computer back to a previous state when it was still working fine. To do this you need to goto START then ALL PROGRAMS then ACCESSORIES to SYSTEM TOOLS then select SYSTEM RESTORE, just click NEXT then choose a bold/highlighted date that you can restore the system too and just click NEXT until the end and it should do the restore process.
Anyway you can download the updated drivers at this link:
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=725&DetailName=New&DetailDesc=945GZT-M(V1.0)&CategoryID=1&MenuID=73&LanID=0
Hope this helps!
Peace! :)
Oct 22, 2008 | ECS 945GZT-M (V1.0) Motherboard
My plasma screen turns itself of after a few seconds. i have to turn it of and on to get a picture up again which will last for a few seconds. it is a fujiama(?)computer screen with a 240 volt power cord
hi gents, ladies maybe.
thank you for your repley. after further search i found out that it is a problem with the capacitators wich happens quiet a lot according to the notice board enteries i found. i am heating up my soldering iron and will let you know the outcome.
nice one
Jul 07, 2008 | Televison & Video
Powering up, but no video display
u back cmo pin on 1 2 only 23 resets it wont boot do u have onbord video out port use thatto see in bios then change it to pci express or agp whetevr uuse to boot off 1st in inet disply ok
Jan 23, 2008 | ECS 945GZT-M (V1.0) Motherboard
EliteGroup ECS 945GCT-M/1333 Motherboard - v3.0, Intel 945GC, Socket 775, MicroATX, Audio, Video, PCI Express Logo
237 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
