Key pad is not functioning. Not even the caps lock. I have disengaged the battery, unplugged the power cord, held down the power button and nothing works. notebook...Aspire 5610z
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 34 Answers
Has it been dropped or bashed at all, as it sounds like the keyboard connection plug may have come loose inside the unit. I have had a few like this on Dell units, not sure of acer but maybe worth a look.
Posted on Mar 22, 2008
SOURCE:
Dell Inspiron 6000 powers up, caps lock flashes 9 times, then laptop shut down. Why???
Unplug power cord from laptop, remove battery from laptop. Open memory access panel on the bottom of the laptop. Remove memory module(s) (SO-DIMM). Plug power cord back into laptop. Turn laptop on (with the memory removed), the caps lock and scroll lock LEDs light, then the laptop shuts itself off. Unplug power cord from the laptop. Reinstall the memory modules. Make sure they are seated correctly. Put the battery back in, plug the laptop back in, and power on. Laptop should power on and boot up properly.
May need to hold the power button down to get it to power on properly.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Dec 03, 2011 | Dell Inspiron 6000 Notebook
MY HP 60 235DX WILL NOT TURN ON. I TOOK BATTERY OUT AND HELD DOWN POWER BUTTON, PLUGGED IT BACK IN AND IT STILL WILL NOT WORK. NO POWER LIGHT WHEN THE POWER CORD IS PLUGGED IN. BUT WHEN I DO PLUG IN...
fan turns? hear it and feel it.blow.? in must.
cd drive ejects? (button)
no text ever on the screen? this is first. all else more complex.
do the flash light trick?
http://www.pcdied.com/monitors.html#flashlighttest
no beeps
no flashing caps lock key (codes) if yes, what code.
step one is get BIOS and its screens working
even using and external VGA monitor will help.
and the magic Fn+F4 key to turn that on.
hp is down this morning...(support pages)
the G60 series uses a CCFL lamp, that blows out (easy)
or its inverter.
if external monitor works, and flashlight trick works
CCFL back lamps are dead.
Aug 23, 2017 | HP G60-235DX Notebook
I have a HP Pavilion tx 2000 tablet pc. When i turn it on the power button it shows that its on. The hard drive light does not flash and the caps lock and the number lock button keeps on blinking. My...
Hi
Boss you need to mention here in what sequence do the lights blink.
Anyways you can take help from this
Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
DO RATE MY SOLUTION
Jul 04, 2011 | Compaq Presario Notebook
How to unlock the key pad on a dell latitude D600 laptop
Hi. Please do troubleshooting steps below:
1. Check to be sure your "Number Lock" or "Function Lock" keys aren't lit. These can lock out certain parts of your keyboard. If either of these is lit, press them to unlock the locked portion of your keyboard. These can be found at the top right on a laptop and between the number pad and main keys on a desktop keyboard.
2. Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
3. Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
4. Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
Have a good one!
  • Step 2 Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
  • Step 3 Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
  • Step 4 Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
  • Read more: How to Unlock a Dell Keyboard | eHow.com http://www.ehow.com/how_5063232_unlock-dell-keyboard.html#ixzz0uguUk4bZ
    Jul 25, 2010 | Dell Latitude D600 Notebook
    Dell keyboard locked up
    Dear Sir,
    PLzz folow this step to unlock your keyboard
    Step 1 Check to be sure your "Number Lock" or "Function Lock" keys aren't lit. These can lock out certain parts of your keyboard. If either of these is lit, press them to unlock the locked portion of your keyboard. These can be found at the top right on a laptop and between the number pad and main keys on a desktop keyboard.
    For desktops, disconnect the keyboard from the desktop. Reconnect after one or two minutes.
  • Step 5 Reconnect the power adapter or AC cord. Start your computer.
  • Step 6 If your keyboard is still locked on a Dell desktop, disconnect the keyboard. Restart your computer and reconnect the keyboard after the system boots. Allow your operating system to recognize and reinstall the keyboard
  • Thanks For Your Time.
    Apr 10, 2010 | Dell 0Y3740 Keyboard
    My laptop (Compaq Presario v2000) won't seem to boot up
    Remove the battery. Plug power cord in. Turn on machine. Does it boot? Replace battery.
    gurutim
    Mar 17, 2009 | HP Compaq Presario V2000 Notebook
    Cap Lock on or off
    Your EX 110 receiver has 3 indicator lights (LEDs) that display the status of the Caps lock, Function key, and the Num lock during normal operating mode. These lights will also flash when the connect button on the receiver is pressed.
    LED A: Indicates that the Caps Lock (Capital lock) key is on when lit.
    LED F: Indicates that the F keys are in Standard F Keys Mode when lit and in Enhanced F Keys Mode when the LED is off.
    • Your EX 110 keyboard has an Enhanced F Keys Mode for F keys that provides additional functions you can program. See Knowledge Base article 9526.
    LED 1: Indicates when the Num Lock (Number lock) key is on. This function allows the number pad to produce only numbers
    Feb 11, 2009 | Logitech Cordless Desktop EX110
    FAST BLINKING GREEN & WON'T POWER ON
    I had exactly this problem. After plugging and unplugging it multiple times over several weeks (even plugging it in quickly after it was unplugged but with the green light still flashing as suggested here) all to no avail, it just started working on its own one day. It worked for a few weeks and then the problem re-appeared.
    InFocus tech support recommended:
    1. Check whether the lamp door is securely closed.
    2. Check the color of the LED and the number of time it blinks. (For me, a very fast almost flickering flash)
    3. Does the fan operate? (My fan would go on when plugged in)
    4. Remove the lamp module, shake it gently and reseat the lamp module.
    For me, these steps did not work. InFocus then recommended that I send it to ProjectorDoctor http://online.projectordoctor.com/, and it was diagnosed with a bad power supply. $395, but it is fully functional again. Good luck.........
    Jul 24, 2008 | InFocus ScreenPlay 7200 Multimedia...
    Open Questions:
    Computers & Internet Logo
    Ekse
    Alun Cox
