Hi! This may mean a legal paper type. Try to check the paper type on the label. If the paper is not correct it wont feed. Hope this helps and have a good one!
What its saying is that you do not own these songs legally so you have "no authority". Which means you have no rights/licenses with these songs as you can not use them legally. So you would need to go buy these songs legally, as some MP3 players have "copyright cops" in them.
Manual Feed tray...it will be a pull down hatch on the front of the printer. this usually doesn't mean that you are actually out of paper, but that you printed the page to a size of paper that you don't have. Like printing to legal when the printer only had letter in it.
verify that the paper size shown on the display matches the size and direction of the paper in the respective trays, make sure paper side guides and rear backstop are tight against paper
Go to Printer and Faxes in Control Panel, Right click on the printer for which you want to change the settings. click properties, go to printing preferences there look for paper size and select A4 or letter/legal as per your choice
The document you're trying to print is formatted for legal size paper, and the tray contains only letter size. if it's a legal size, put legal paper into the MP tray, or override the setting and manually select "letter size" in the printer dialog box.
Ok.... I have these printers at work...and i think i have figured this one out :
Under setup menu , goto configure mp , then switch the settings from cassette to manual. You see these printers are used at Hotels where the bottom tray is for legal size paper used to make key packets and the mp is used for regular sized paper printing reciepts....Hilton family hotels use them for example....the next thing I'm trying to figure out is how to set it so I won't have to push the go button every time I print something
Menu> scroll to Paperhandling> MP Tray type>>(plain) try changing this to cardstock <enter>
instead of MP Tray type do the same for Cassette if you desire....
Best,
danakadan
1. From the MP Navigator screen, select "Scan with Scanner Driver" in lower left corner.
2. When in ScanGear MP, select the Advanced Mode tab
3. At Input Settings, select Document (ADF) for document type
4. Set paper size in next window
5. Click Scan button at bottom
