Question about HP Pavilion dv1000 Notebook
Battery won't charge
Battery charge light doesn't light. Laptop works fine when plugged in. Tried a new battery without success.
  • iamjls Jan 24, 2009
    best buy replaced my mobo under warantee, I had trashed my usb ports. soon after the 30day warantee on repairs expired. my battery failed. actually it may not have. now with a new battery the power light flashes the computer runs on ac but the battery will not charge.
    sounds like a batch of defective mobo's
  • 58 Answers
Sounds like the ac adapter isnt working.Test the adapter with a volt meter.The sticker on the adapter should tell the output voltage.
Posted on Mar 25, 2008
  • Anonymous Mar 25, 2008
    Sorry didn't read listing correct,if it works with adapter plugged in then its not the adapter. Sounds more like the board curcuit is bad ,,,,it works with adapter but the charge doesn't make it to the battery,need to check the adapter jack where it is souldered to the board.If the problem isn't there it could be in the board itself.
SOURCE:
Dell precision m6300 battery won't charge.
You say it's a new battery. Is the battery the same EXACT spec? Some aftermarket batteries don't work well with your laptop. The pin-out/connections may be incompatible. That said, in your BIOS is there a "Battery Learning" section.
Jan 04, 2013 | Dell Precision M6300 Mobile Notebook
My laptop is completely dead, fine yesterday. Today no lights, sounds nothing. I tried removing the battery , unplugging no response. Thanks,
Remove the battery for at least 3 minutes... Then put it back and then plug in the charger and switch on the charger. If the battery is completely drained, it would take a while for the charging to initiate. Please have patience and leave it on charging even though without the charging indication for at least an hour. After that still if the charging indicator doesn't lit, then its definitely your charger or laptop. You will need to take it to a service centre in that case.
Nov 03, 2011 | Compaq Presario 2170US Notebook
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
Medion E1210 notebook. Battery has suddenly stopped charging. Didn't get a fall. Laptop works fine when power supply connected, but if plugged out laptop shuts down immediately. When power plugged in...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 21, 2011 | Computers & Internet
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
Battery is not charging.
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced. Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Apr 14, 2011 | Gateway MX6453 Notebook
Hi, I really need some help. I want to know whats wrong before taking my hp pavllion dv600 to service centre. Problem is that the charger doesn?t charge the battery at all. Charger is fine with other...
If the power supply does not run the laptop without the battery, then the problem is the jack in the laptop, over time the plug breaks free of the motherboard causing intermittent operation or no power. If the power supply runs the laptop without the battery, it is the charging circuits on the motherboard that is the issue.
Jan 04, 2011 | Computers & Internet
HP Pavilion dv1000 Notebook Logo
757 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
