Question about Stoves 720EF Electric Double Oven
Oven making whirring noise when switched off
Oven began making whirring or clicking noise even though it had been off for a day. the oven still works normally
  • 250 Answers
The back panel of the main oven houses the circulating fan. From experience, fat/grease/gunge accumulates and drips down the inside of the plate through the vents. This will then rub on the fan as it turns. There are four self tapping screws, one in each corner of the panel. Remove the screws and the panel will come off. That is the easy bit, getting rid of the grease is harder. Don't forget that the oven side of the panel is a stay clean and shouldn't be cleaned with anything abrasive. I use the Lakeland brush on oven cleaner on ALL the walls of the oven (even the Stay Clean) and it works a treat. It may take some time to disolve the residue and a couple of goes, but it does work.
Posted on Apr 24, 2010
  • Malcolm Parsons Apr 24, 2010
    Sorry , just reread your problem. Forget what I said earlier. The clock is the only thing that should be on. Are you sure there are not any other external things behind the oven that can cause this?
SOURCE:
Candy fl 134 x uk , single oven ..... oven works fine ... clock/ timer is dead and keeps making clicking noise , when not in use i power it off ... do i just need to replace the clock ???? Thanks roy
[n 75 years I have never heard of anyone powering off an oven when not in use . those little clocks do not use enough electric to worry about waste
Feb 25, 2017 | Candy Ovens
My wall oven is making a constant unusual noise
Without a model number its hard to be exact. If your oven is older it will have a clock timer motor that turns the dials or flips the clock display cards. This timer has gears and bushings that will be annoying as they wear and start a vibrating hum or clicking-usually not worth tinkering with..it can be taken out and checked or replaced. Electronic timers of course don't have any moving parts to the timer, but have relays in the circuit to turn the oven on and off. They do not 'whir'. This is the likely issue.
Repost..let us know.
Apr 28, 2015 | Ovens
Kitchenaid superba oven
It is very possible that moisture from the cleaning has caused the ignition switches to make enough resistance to cause the burners to spark. It usually goes away after the stove has dried out. If it continues after a day or so one or more of the ignitor switches may need replacing.
Nov 20, 2013 | Ovens
Viking 27" Electric Oven Noise
Hello. The Viking does have fans which operate continuously to insure even baking. If it sounds like fans running, this is the convection fan operating. J.
Jul 01, 2010 | Viking 27" Professional Select Built-in...
I have a 1960s GE P7 oven that will not heat. How can I test the WB 22x53 switch? Could it be the latch release switch or the oven temp rheostat? The oven makes a humming noise when the dial is turned...
you can test any switch or relay or capacitors on the control board with an ohmmeter in the ohm setting. If low or no resistance, then it is bad. You can get any parts and manual at repairclinic.com or appliance411.com
Oct 14, 2009 | Ovens
Start button not working.
probably your button is dirty had carbon inside. do you hear a click sound when press it? if so , the IC did not received the signal, it need to be check by a technician.
Jun 30, 2009 | GE Profile JT910SASS Electric Single Oven
Oven will not light
there is a eletric thermocouple at the bottem back of oven unplug the stove remove broiler draw to get access to this part remove small screw disconnect wire replace with new one to order part you will make modle s/n off data plate good iuck later
Apr 01, 2009 | Ovens
Wolf oven - oven clicks continuously
This sounds like you have a flame switch getting ready to go out. The reason you are hearing the ticking noise is that after the ignition is satisfied the flame switch is not detecting and sending a signal to continue to try for ignition.
Nov 02, 2008 | Ovens
Stoves 720EF Electric Double Oven Logo
375 people viewed this question
Top Stoves Ovens Experts
Marvin
Marvin
Anthony Ward
Anthony Ward
Are you a Stoves Oven Expert? Answer questions, earn points and help others
