Question about Kirby Ultimate G Bagged Upright Vacuum
Vaccum just stopped working tried turing back on and nothing
Have a ultimate G vaccum think the motor but not sure what the problem is
  • LilyK Mar 22, 2008
    Kirby G 2000, just stopped working one day. Couldn't turn back on.
    President:
  • 1,673 Answers
Check and make sure that the bag emptor(bottom of bag asm.) is pushed up against the casing. There is a safety switch there that may not ne engaged. Cord may be bad, one side of the line may be open. Noozle asm. not on straight, there is another safety switch there. Problem with switch or motor.
Posted on Mar 22, 2008
6ya staff
SOURCE:
After shampooing carpet vaccumed worked just fine, tried to turn on next day and no power will not turn on.
Make sure the bag assembly is fully attached and snapped in place. Wet the rubber gasket on top of the motor exhaust if necessary. If the bag (or head) are not correctly installed, a safety switch prevents operation.
Dec 31, 2010 | Kirby Ultimate G Bagged Upright Vacuum
Hello, I was vaccuming around the house i accidently **** some water out of my dog water bowl.Now it dont want turn on?
Water and electricity don't mix, so you probably burnt out the motor. There's a possibility that a thorough cleaning with a motor cleaning spray that leaves no residue will bring it back to life, but I think you will need to replace it.
Dec 12, 2010 | Kirby Ultimate G Bagged Upright Vacuum
My pet hair eraser vacumm judt shut off while I was vaccumming what could it be?
the motor overheated and tripped its thermal interlock. Let it cool and just tirn it on without trying to vacuum, ie no load. If it does not work, I am to be thinking your motor is cooked! Solution on a funny note, get rid of the dog or install hardwood floors. lol could not resist.
ash
vote please 4 thumbs would be nice if for nothing else, you laughed.
Sep 26, 2010 | Bissell 3920 Bagless Upright Vacuum
Hi My Hoover wind tunnel cyclonic stopped working when i was using it. I tried different plug even then it doesnt work . What to do??
If the motor stopped running, it most likely did because it was not being cooled, becuause something was stopping up the air flow. If you have cleaned the secondary filter out and it still stops while running, then remove the exhaust filter cartridge and try it then. If it does not stop running now, then the problem is the previous models like this had a foam filter as the exhaust filter, not a heppa cartridge filter. You will not hurt the machine by running it without the heppa cartridge. Cut a foam filter to fit to replace it. I do not think Hoover knows this yet.
I have a customer working on this problem today (Sept 2010) I have repaired machines for 30 years. This filter is meant to just catch the tiny particles from getting back into the air. However, it worked fine on the previous machines with the foam filter here instead of this Heppa cartridge.
Dave in Texas
Aug 31, 2010 | Dirt Devil Hoover Uh70085 Pet Cyclonic?...
Turn on the power and nothing happened. I checked the power plug. It was ok. what caused the Vaccum didn't work? Thanks, Peter
Same, I have the same issue with this model. Brush motor is working but not the vaccum motor. Any ideas?
Jul 26, 2010 | Bissell Lift-Off(R) Revolution(R) Turbo...
Was vaccuming and vaccum quit. Tried unplugging and turning back on. Getting absolutely no power. unscrewed screw under handle and tried to make sure connection was being made. Don't really know what to...
ok..If you have a multimeter you can check plug fuse then switch and motor, if you put leads across the plug you will get some reading if its working.could be thermal cut out on the motor.
Apr 18, 2010 | Kenmore Magic Blue 24195 Bagged Canister...
Vaccum problem
No sound at all? or the motor runs but no vaccuum?
did it stop while using it? might have overheated due to dirty filters... strange that the light comes on but no motor at all... that would suggest to me that the motor is shot...
Here is a link the the manual.. there is no reference to any user accessable fuse or breaker...
Peace,
Mar 07, 2010 | Bissell 6594 PowerForce Bagless Upright...
Beaters stop when vaccuming rug...didn't when new
I believe you need to change the belt that drives the brushes. When it gets stretched out, it will just spin on the axle of the motor or spin on the brush and smoke.
Jim
Jun 01, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
My bissell bagless vac has no vaccum. ihave
You will have to clean the filter and clean the main motor.  I had this issue on mine and the main motor was so full of dust bunnies, that it stopped it from creating a vacuum.
Mar 06, 2009 | Vacuums
Kirby Ultimate G Bagged Upright Vacuum Logo
115 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Chris Nomland
Chris Nomland
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
