Question about IBM ThinkPad T30 2366 Notebook
How to connect through wireless
I want to get connected with my ibm t30. I have Wireless DSL modem. please guide me.
  • smasenora Apr 28, 2008
    I just purchased a used T30, Model 2366. It has integrated wi-fi, but when I try to find networks in range, nothing shows up, even though I am on a wireless network using my T22 to write this.
    Explorer shows the card installed.
  • smasenora May 11, 2010
    Doesn't integrated mean that I don't need to insert a card in the slot?
    Explorer shows Intel(R) PRO/100 ve Network Connection and says it is working properly.
    When I go to 'Network Connections', under LAN or High-Speed Internet it says: Local Area Connection. Network cable unplugged, Firewalled.
Do you have a wireless card in the laptop,some come with ,some come without a card,thats your first step
Posted on Mar 23, 2008
SOURCE:
Setting up for use on laptop
ay6dz0yqzpfvaaaaaelftksuqmccconnect the cable on the yellow jack and the other end to your pc.
Oct 27, 2012 | Belkin N150 Enhanced Wireless Router...
IBM T30 Thinkpad 2366 wireless network I inheirited a IBM T30 laptop from my wife. She haad it loaded up with so much **** and it was extremely slow. My fix was to format the drive and reinstall Windows...
You need to download the drivers for your Netgear.
The IBM drivers also need to be found,Depending on your model, it may have WiFi. From IBM spec sheet:
  • 10/100 Ethernet installed on the system board
  • Selected models will have Intel Wireless and modem Mini PCI combo cards
  • Selected models will have CISCO Mini PCI card
  • Selected models will have Bluetooth communication daughter card
Nov 01, 2011 | IBM ThinkPad T30 2366 Notebook
I cant connect to internet but i installed the necessary driver
To connect to the Internet you need a few extra things aswell as a network card.
1. You need to sign up with an Internet service provider.
2. Connect a LAN cable from your computer to the DSL or cable modem
3. You need a DSL or cable modem and connect and configure the modem to inaccordance with your Internet service provider's instructions.
4. Install Internet Explorer if it has not been done.
5. If everything has been done correctly, when you open Internet Explorer youcan access the Internet. If you have a wireless router and it is connected to the DSLor cable modem then -
To connect to yourwireless router, the router needs its wireless settings to be configuredwith the SSID, encryption key etc., also the wireless cards in all thelaptops/computers needs to be configured with these router's wireless settings.Then the laptops/desktop computers can communicate with your wireless router.
May 18, 2011 | IBM ThinkPad X41 Tablet PC
How to set up wireless network connection can't conect to the internet
1st If the wireless card driver is not installed then the driver.
2nd. Check Device Manager to see if the wireless card is working and enabled.
3rd. Configure the wireless card with the Wireless router's wireless settings, ie, SSID, WPA or WPA2 encryption etc.
4th Connect your DSL or Cable modem to the WAN/Inernet port with a LAN cable.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Mar 11, 2010 | IBM ThinkPad A31 Notebook
My D-link G604T connects with WEP but not with WAP
When you change the WPA encryption in the wireless router, you also need to configure the wireless card in the computer with these settings.
Please click in this link to secure your wireless network, configure the wireless router and the wireless card in the computer and follow my instructions :-
Feb 03, 2010 | D-Link DSL-G604T Wireless Router
Wifi on ibm thinkpad t30
The wireless driver may got corrupted or uninstalled.
Go to Control Panel - System - Hardware - Device Manager - Click on Network Adapters and if the wireless card is listed click on it to see if it is working and enabled. If not then reinstall the wireless driver.
Aug 13, 2009 | IBM ThinkPad T30 Motherboard 91P7695 -...
Need wireless connection driver
it should be on your recovery disk that came with computer when it was bought new if you dont have that disk try windows update to fine it
Mar 26, 2009 | IBM Thinkpad T30 Notebook
Internet Connection
A few years ago, i too had an IBM thinkpad and encountered some issues as well when connecting to the internet.
The IBM 2647 does not have a built in wireless card, meaning that you need to purchase one from your local electronics store to use wireless internet. The software provided with these CD's can often be quite helpful and will help you set up the connection.
The 2647 only supports an analog modem connection, and the modem in the area you are attempting to connect via ethernet may use a digital modem. Adapters are available although they are quite pricey (ranging from $200 and up.)
Hope this helps.
FerrariXP
Mar 10, 2008 | IBM ThinkPad T20 2647 Notebook
Ibm think pad t30
To my knowledge, your laptop (IBM ThinkPad X30 2672) does not have any built-in WiFi. It's modes of connection are IrDA, modem, Ethernet, USP, Firewire aside from the regular serial & parallel. This would indicate that if you are wireless you either have a USB dongle or PCMCIA card. Please post back with your WiFi brand/model and your Operating System. Further, please post back likewise your WiFi AP/Router brand/model.
The message "a network cable is unplugged" pertains to the absence of a lan cable connected to your Ethernet port.
Good luck, kind regards and will await your second post.
Nov 16, 2007 | IBM ThinkPad X30 2672 Notebook
IBM ThinkPad T30 2366 Notebook Logo
144 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
