Question about Bose 3 2 1 GSX System
1 speaker playing
I read your reply to try another speaker. My system has speaker wires that merge into one computer type plug. I have had problems with the one speaker's volume going way low until you "stomp" the floor. It happens for a few days and then is fine for a month or so. Any suggestions.
  • 61 Answers
The next time it happens, try "thumping" the low speaker instead of the floor, it's probably a connection problem inside. I would need a lot more info about the system to even guess about a better diagnosis.
Hope that is a little helpful, anyway.
Posted on Apr 10, 2008
I have the sub woffer only would like to use on my comp
No problem....just plug the subwoofer into your Green Port on the computer sound section. The Right and Left channel will merge into a monaural sound and come out of the speaker as if you were listening to music from a radio.
Dec 16, 2013 | Dell A525 Zylux Multimedia Computer Pc...
I tray to changing 3 new keyboards but still reads the problem. What's your problem?
OK what type of keyboard are you using Serial or USB? A serial type keyboard has a round end that plugs into the computer's PURPLE port (the Green Port is for the mouse).
A USB type keyboard has a flat end that plugs into one of the computer's usb ports.
If you are using a Serial (Round end) type keyboard, it is not Plug and Play (meaning you cannot unplug it or plug it in while the computer is running or it will not be recognized). You can only plug or unplug the serial keyboard when the computer is off. If you turn the computer off and plug it in good then reboot and you still have a problem then since you have tried 3 different keyboards, maybe the Purple Serial Port where the keyboard plugs into the computer is bad. Try a USB Type Keyboard.
A USB (Flat end) keyboard is Plug and Play. You can unplug and plug it while the computer is on. Also you have the luxury of plugging it into any one of the computer's usb ports.
May 24, 2012 | Dell Optiplex GX60 PC Desktop
Model RTD325W My DVD player has been locking up during a movie and even when I am listening to just the radio (tuner mode) I am forced to unplug to reset since it will not allow me to power off with...
Fastest way to check this is to disconnect all speaker wires from the unit leaving the video hooked up and play a disc. If it keeps playing fine, you have a speaker or wire problem. If it still reacts the same, it's an internal problem and would need to be serviced. If the unit continues to play, post a reply and I will describe in detail how to troubleshoot the system. Hope this helps
Jan 24, 2011 | RCA Audio Players & Recorders
I just got a used set of altec lansing ADA745 computer speakers and can't get power to them. I have never seen computer speakers w/ two wires for input to the computer. I plugged the usual green colored...
https://support.dell.com/support/edocs/acc/ada745/ada745.pdf
That is the setup guide for the speakers.
The two wires plug into a cable that then that single cable plugs into the computer, this way you have sound coming out of the left and right hand speakers.
Feb 05, 2010 | Altec Lansing Multimedia Computer Speakers
I need to hook speakers up to my Dell B110 computer.
2 things are needed to get sound from your speakers:
1-wiring connecting your speakers to a socket to the back of the computer. (The spot they need to plug in to ON YOUR COMPUTER is a small light green circular socket. The other end of the plug you plug in here should run to one of your speakers *usually the right side speaker-the right speaker should then have separate wiring to connect the left speaker.)
2- A source of power.
Some speakers use their own power source and plug in to a power outlet - your wall. Other types have a USB type plug and plug into a USB port in your computer and that is how THOSE get their power.
Those are the basics of sound setup. Some computers are equipped with more complicated setups such as surround sound, subwoofers, digital and more. Reply if you need more help, I will try to assist you further.
Hope this helps.
Feb 02, 2010 | Dell Dimension™ B110 PC Desktop
JVC HX-C6 goes directly into "Protect Mode".
I received a reply promptly from JVC to check power connections for shorts. O course I had already done that. So as a last resort, I pushed the power switch on and held it for maybe 10 seconds. It seems to have reset the unit, and it's playing fine. Best of luck, hope you all read this and it works for y'all. AJ
Sep 26, 2008 | JVC HX-C6 Shelf System
Computer won't read audio unit.
Still there is no problem to your speakers... it's the Sound Driver is missing for Windows to activate the audio part of the motherboard... If you have the motherboard CD.... System properties and install the driver in order to restore that missing file...
Good luck.. Hoping this Fixya the problem... post me back if you have other inquiry... Just don't forget to rate us...
Feb 05, 2008 | Altec Lansing MX5021 Computer Speakers
Right speaker doesn't work
I had this very same problem and I had my system for about 2 weeks. I have seen a lot of similar posts on this site so it seems that this problems happens a lot. For some reason my right speaker just stopped working so i came to this site for help. I looked at alot of posts and nothing fixed the problem. when i switched the right speaker to the left input it started to work so I knew the speakers were fine. So i finally decided to unplug everything and restart my laptop. Once my laptop rebooted I plugged the sub back into the wall after about a minute of it being not plugged in. Then I plugged all the the wires and volume control back into the sub and turned the switch back on. Make sure the volume control is down when you plug everything back in. Then plug the wire into the device, which in my case was a laptop, and start to play some tunes. Right away everything was working perfectly fine again and no problems ever since...for me atleast.
HOPE THIS HELPS
Mar 13, 2007 | Logitech Z-2300 Computer Speakers
The speakers don't work
Ok There is another chance to work your speakers ,
  If you have your mother board CD , get play that  and  reinstall the sound system .
  I hope it will work ,      please do reply
Sep 06, 2006 | Gateway GMAX 2100 Computer Speakers
Bose 3 2 1 GSX System Logo
37 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
