Question about Microsoft Xbox 360 Console
GPU Error. Code 0022 on my xbox 360
So I finally got the 3 red lights on my 360. Well, it's not under warranty. I attempted the "towel trick" as a last resort. Didn't work. After this, I got the error codes off the xbox. What I got was "0022". Which according to sources, it means GPU Error/GPU Overheating. Is there anyway to fix this problem without voiding any possible future warranty on it?
  • 3 more comments
  • Anonymous Mar 09, 2009
    0022 damn....
  • Gman888 Mar 10, 2009
    Yup just keeps coming up three red rings and secondary error code 0022 after replacing xclamps and thermal paste. Any helpfull suggestions ???
  • Anonymous Apr 09, 2009
    I turned it on and i saw three quadrants flashing red, i was so confused
    i turned it on and the three quadrants just started blinking red. I dont know what to do and i'm confused. SOMEBODY HELP ME OUT
  • Anonymous May 05, 2009
    I have the same error code, I've replaced the x clamp and everything else I have found except for the towel trick. Not sure what else to do, I might have to break down and by a new system.
There is a very simple fix to this issue and I am not sure why it is not being talked about. I will have to make a video and post it for everyone to see, but in short, you need to overheat the GPU while keeping the CPU cool.
Now, if you do not know what you are doing, I would wait until I make a video about it. However, if you are comfortable taking your Xbox apart then it is simple.
You will need to disaseble the box all of the way down to removing the top cover and exposing the board. You do not need to remove the DVD or the fan, however you will need to take off the plastic piece that vents the fan air into the heat sinks. After you get that far, take the fan out of the case. DO NOT UNPLUG IT, as you will need it. Just pull it out of its holding spot. Next, you will want to move the DVD drive off to the side, away from the GPU heat sink, but leave it plugged in. Then set the fan on top of the CPU heat sink, the taller one, so that it does not overheat. Then turn your system on and let it RROD, then leave it on for about 10-15 min. What this will do is overheat the GPU and reflow the solder underneath it. After 10-15 min, turn your system off, let it cool, put it back together, and you should be good to go! I have done this on 3 systems that came up with error codes related to the CPU or GPU, and all 3 are now working again. Good luck!
Posted on Oct 05, 2009
  • SemiTech30 Jun 23, 2011
    This is a really efficient way to burn out your motherboard so it never works again, according to most techs who do professional reflows or reballs. It might work for a while but most techs agree that it does even more damage to the system. If people learn the correct way to flux the GPU and CPU, then do a reflow with a heat gun, then let the board cool for the appropriate amount of time (about 1/2 hour), then apply fresh thermal compound (preferably Arctic Silver 5), and finally to install an X-clamp fix kit and put the system back together without damaging anything, their Xboxes will work for months or even years.
    Problem Solver:
  • 11 Answers
0022 CPU error, generally caused by a poor connection to the mainboard (cold solder joints/bridged solder joints). This can also be triggered by an error with the TSOP.
http://forums.xbox-scene.com/index.php?showtopic=484726
Posted on May 14, 2008
@xx Mimic xx: thats true that will work for a while, but in time, the sub error 0022 will eventually show back up again...really what needs to be done is just have the mother board taken out completely and reflowed...
Posted on Feb 15, 2010
  • iiiii
    iiiii Aug 27, 2014
    warm other side of board up before reflowing
    Problem Solver:
  • 11 Answers
You will have to open the xbox up and fix the GPU if you want to know how call or Text me at 804-519-2435
Posted on Apr 18, 2009
  • Spencer Stitt
    Spencer Stitt Dec 26, 2011
    My Number has changed 804-372-RROD
The error code 0022 means thers too much pressure on the gpu if you did the x clamp fix undo the screws a little not much just a little, i got the same problem i did the x clamps for e73 + 1 red light and when i had finshed i got 3 red light and that error code then i undid the screws slightly and then started it up and it came alive, not sure if it will work for everyone but its worth a try
Posted on Aug 10, 2009
  • 3 Answers
Call 1800 4MY XBOX
Posted on Mar 22, 2008
Code 0022 means that the connection is lost in yourcircuit board bit. maybe theres a jump between two soldering parts or 2 wires are touchin. take the case off and make sure nothing is touching then start it back up again. this worked for me. DO NOT unplug anything inside, and make sure you dont break the circuit.
Posted on Mar 28, 2008
I know how to do it without voiding warranty turn the console on and leave it on until the fans start blowing loud and when they stop blowing loud turn it off and pray it woorks
Posted on Apr 02, 2008
My Ipod are not open, only process icon is showing now. how to process for running ipod
Posted on Mar 23, 2008
I tried the towel trick and the penny heat sink. The console worked for 3 weeks then the red ring of death showed up again. Nothing I've tried will work. Any suggestions/
The towel trick and penny heat sink is a temporary fix for the Xbox 360. The red rings of death is a general hardware failure which means it needs a permanent fix. If your console is out of warranty it will be $99 through Microsoft, you check your local service centers for the system to be fixed and it might be cheaper.
May 20, 2010 | Microsoft Xbox 360 Console
My xbox 360 has the E 74 code on it and the bottom right of my xbox ring is flashing red
E74: I/O Hardware Error - HSIO related, could be crc error, or many things: There is high chance it's a scaler chip problem (the "ANA" or "HANA" chip near the AV cable connection) it can also be caused by a faulty AV cable so check that first. Microsoft covers this error under their 3-year warranty, this is availble to anyone who hasn't modified their console. contact MS to get a free replacement console before attempting to fix this yourself. Failing that this error In some cases it is a problem with the GPU and may be repairable by doing the x-clamp replacement (see error E-18)
E18: Error in the "Digital Backbone" (CPU/GPU/RAM), this is usually caused by a cold solder joint between the GPU and the mainboard.
There are two theories to fixing this one deals with the "X" clamps that hold down the chips. The other involves re-Heating the chips. DO NOT attempt either of these if your console is still under warranty. If your console is still under warranty return it to the store where it was purchased or call MS to have it replaced.
Mar 30, 2010 | Microsoft Xbox 360 Console
Freezes,and red lights come on
This is called the red-ring of death. Call 1-800-4my-xbox and they can help you with this situation. If you haven't had your 360 over 3 years, than they will fix it free under the warranty. Another trick others have said works, is to wrap a towel around your 360. This will heat up your xbox, and reconnect any soldering that seperated. The towel trick is only a theory I heard...not sure how much truth there is to it. Worth a shot. :D
Mar 19, 2010 | Microsoft Xbox 360 Console
My xbox 360 has 3 rrod and the error code is 0010 said to be overheating, but when turned on the red lights come on but nothing else. Left it running for 30 mins and heat sinks were cool as ice!! Also...
Hi, If you still have the manufacturer's warranty from microsoft. Get a replacement for the Power supply. Or if you have other power supply available. Say, like try borrowing one from a friend. Try that. The issue here is on the power supply.
Mar 07, 2010 | Microsoft Xbox 360 Console
Help me...!!!! i got error 0022 in my console
There Error code is with the Graphic Processing Unit:
0022 GPU Error / GPU Overheating
If it is still under warranty contact Microsoft.
If you are looking for a do it yourself solution you might want to check the link below.
Tutorial : X-clamp Replacement - RBJtech's Method - Scenyx Entertainment Community
Best of Luck.
-Mind
If you need further help, reach me via phone at https://www.6ya.com/expert/clayton_0b2096930c0c699a
Jun 30, 2009 | Microsoft Xbox 360 Console
How do i fix my xbox 360 e74 error code
you can fix e74 wiht te same process as the 3 red light problem
Aug 14, 2008 | Microsoft Xbox 360 Console
3 red redlights
Call 1-800-4MY-XBOX. All XBox360 consoles have a 3-year limited warranty protecting against the 3 red lights. Since the XBox360 hasn't even been out for three years yet, yours should still be under warranty and will be replaced for free.
Apr 15, 2008 | Microsoft Xbox 360 Console
Xbox 360 error 0102
do the erasor trick. its like magic
Nov 28, 2007 | Microsoft Xbox 360 Console
Xbox360 error code
Here is how you interpret the LEDs to get the code number:
  • All four lights flashing - 0
  • One light flashing - 1
  • Two Lights flashing - 2
  • Three lights flashing - 3
0001 power supply problem
0002 Network Interface problem
0003 Power problem could be the PSU could be the GPU/CPU, somehow the console isn't getting clean power from the power supply.
0010 over heating
0011 over heating - If you are receiving this error after disassembling your console make sure to all 8 of the heatsync screws are tightened securely to the board/heatsink holes.
0012 over heating
0013 over heating
0020 (Not yet known, possibly overheating)
0021 DVD Drive Time out - Can be caused by problems with a firmware flash. This is also speculated to sometime be caused by a problem with the southbridge chipset on the motherboard.
0023 (not yet known)
0101 (not yet known)
0102 unknown error
Oct 12, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
39,443 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
