Question about Cameras
Trouble with Nikon Transfer D60
I have a new Nikon D60 and am having trouble transferring my first set of pictures from the camera to the computer. I successfully installed the software. I attached the usb cord to the computer and the camera, and when I turn it on Nikon Transfer launches. Then the device button for the camera displays for a second but then it disappears. Nothing shows on the source panel at all. I tried uninstalling and reinstalling.. nothing has worked. Any suggestions?
  • 3 more comments
  • skrgregory Jul 27, 2008
    I have the exact same problem with a D60 and Nikon Transfer. Cannot find a solution anywhere yet.
  • pkucan081851 Aug 01, 2008
    Same problem with the D51
  • Anonymous Sep 27, 2008
    Same problem. Can't find a solution anywhere.
  • Anonymous Sep 28, 2008
    Same with D300.
  • dana460 Oct 08, 2008
    I just got my D60 and loaded the appropriate software after taking several "trial" pictures. Nikon transfer comes up, the button that is supposed to appear does so for about 2 secs, then dissappears. Windows hardware see's the camera, but nothing else works to transfer the files. Does not show up as a mass storage device either. Pretty frustrating after spending this amount of money. I updated the Nikon Transfer to 1.2.0, still no go.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo management program such as Picasa.
Organize edit and share your photos
Posted on Nov 22, 2014
t00nz
  • 4738 Answers
SOURCE: Nikon Coolpix S550 transfer problem
It's very hard to troubleshoot software problems online, and it likely is a software issue. But as a solution I highly recommend that you instead consider a card reader to download your photos to your computer. They're very inexpensive, much faster downloading photos from the camera, do not use the camera's batteries during download, and are much less prone to file corruption of the photos during the download.
You place the camera's card in the reader, and your computer sees it as a hard drive. You simply copy/paste or drag/drop your photos onto your hard drive. For all of these reasons, most professional photographers utilize card readers exclusively. Really, you'll save yourself a lot of heartache. Here are some examples from Amazon. Also, don't be fooled by the cost. some of the cheap ones work just fine. Go by the reviews. Also make sure you get a reader that is stated capable of reading your card (particularly if you have an SDHC card)::
http://www.amazon.com/s/qid=1232260593/ref=sr_st?keywords=sd+card+reader&rs=172282&page=1&rh=n%3A172282%2Ck%3Asd+card+reader&sort=acrelevancerank
For international readers, here's another source for card readers (free international shipping too :-)
http://www.dealextreme.com/products.dx/category.300
Posted on Jan 18, 2009
SOURCE: camera not recognised on computer so unable to transfer photos to
Try reloading drivers software that came with the camera.
Posted on Apr 24, 2009
dg9dotorg
  • 151 Answers
SOURCE: Using Nikon Transfer software...camera on or off?
Turn it off first, plug it in your computer, if it doesn't auto-detect it, turn it on after...
Posted on May 06, 2009
  • 25 Answers
SOURCE: nikon transfer will not detect the pictures on my
You may be able to update Nikon Transfer to add the D60 drivers into it.
Check nikonusa.com.
Posted on Aug 12, 2009
emissionwiz
  • 70374 Answers
SOURCE: I attach Nikon CoolPix S550
Some Macintosh computer systems support using a digital camera using SD/MMC card in two modes: 'Digital Camera' mode and 'Disk Drive' mode. At times, when try to use the camera using SD/MMC card in 'Digital Camera', it is not recognized by iPhoto or Image Capture. To solve such behavior, you might need to reformat the digital SD/MMC card and use backup to restore the lost files. But sometimes, you observe certain issues while restoring from backup or the backup is not available. To cope up with such situations, you should use Photo Recovery application to recover the lost files efficiently.
For an instance, consider that you perform following sequence of steps:
  • You connect your digital camera that uses SD/MMC card to a Macintosh computer in 'Disk Drive' mode
  • You switch to 'Digital Camera' mode and observe that the camera is no longer recognized by iPhoto or Image Capture
Similar behavior is also observed if you use FireWire or USB card reader to connect the SD/MMC card to your Macintosh computer and try to switch to 'Digital Camera' mode.
Solution
To prevent such errors from occurring, you should continue using the camera in 'Disk Drive' mode. You can then successfully access it through iPhoto or Image Capture. However, to solve the existing problem of the SD/MMC card, follow these steps:
  • Connect the camera in 'Disk Drive' mode or use FireWaire or USB card reader to access the card.
  • Backup all the files to your system
  • Use your digital camera to reformat the card.
Note: A digital camera using SD/MMC card uses different protocols in different modes so that to communicate with the Macintosh system. But it can only be accessed through Desktop, when connected in 'Disk Drive' mode.
After reformatting the SD/MMC card, sometimes you observe that backup is not valid and couldn't provide the required results. In such situations, you are suggested to use Digital Photo Recovery products to recover them. Photo Recovery utilities are competent tools to scan a logically crashed media using powerful scanning algorithms. Also, they provide interactive user interface that allows easy implementation
Posted on Nov 25, 2009
My camera id D5000. Once i connect it to nikon transfer, there will be a green light that keeps flashing on my camera. My nikon transfer does not sense my camera and i can't transfer my photos.
Try re-installing the Nikon transfer software on your computer. Have you also just tried using the computer's image software to transfer images (or just copy and paste from the camera to the desktop)?
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
212-673-8400
Jul 05, 2011 | Nikon D60 Digital Camera
I have a Nikon Coolpix s51 but my screen is cracked. I am trying to transfer the photos from my memory card and camera to my computer, but i am having trouble figuring out how to do that???
At this point, I would remove the card from the camera. If you don't already have a card reader, invest in one. Connect the card reader to the computer, then plug the card into the reader. You can use Nikon Transfer ( http://support.nikontech.com/app/answers/detail/a_id/61 ) or the operating system's drag&drop to transfer the pictures to your computer.
If you have pictures stored in the camera's internal memory and the screen is at least partially legible, you can try to select "Copy" from the Setup menu to transfer pictures from the internal memory to the memory card before you follow the suggestions in the first paragraph.
Feb 03, 2010 | Nikon COOLPIX S51 Digital Camera
Light facial detail in my Nikon D60
Are you using the flash? If so, dial in some negative flash exposure compensation. Otherwise simply dial in some negative exposure compensation.
However, you will have to leave behind the Auto and the other point&shoot modes.
Dec 28, 2009 | Nikon D60 Digital Camera
Nikon recognises my d60 camera for about 10 seconds then disappears off of nikon transfer screen
Try NOT connecting the camera to the computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive.
Nov 19, 2009 | Nikon D60 Digital Camera
Nikon D60 transfer problem
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Aug 18, 2009 | Nikon D60 Digital Camera
Nikon d60 won't play back pictures
Sounds like your computer or the software program you're using to download your pics is set to automatically erase the card after the download.
Aug 14, 2009 | Nikon D60 Digital Camera
Nikon transfer will not detect the pictures on my nikon D60
Check nikonusa.com.
Jun 20, 2009 | Nikon D60 Digital Camera
Camera not recognised on computer so unable to transfer photos to
Apr 24, 2009 | Nikon COOLPIX L18 Digital Camera
Apr 16, 2009 | Nikon D60 Digital Camera
Cameras Logo
333 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
