Question about Refrigerators
Poorly Cooling Side Bu Side
My side by side by side refrige/freezer is not cooling very well at all. Model: MSD2432GR. I looked for some coils to vacuum off but did not find any on back or even underneath (that I could see anyway). Nonetheless. I vacuumed off everything I could find. Still not cooling well at all.
1. Are there "coils" somewhere that I just missed?
2. Any other ideas?
    President:
  • Refrigerators Master
  • 2,651 Answers
The coils are actually behind the unit next to the fan assy(sorta a plate rolled over it self opposed to conventional coils on this particular unit).tyr removing hte lower panel in freezer section, check the evaporator.Should be an even frost pattern across hte entire coil, no frost with execption of the top 1 or 2 coils, is an indication of a sealed system issue( covered under 5 yr manufacture warr usually). excessive frost (cpmpartment completly frozen over) is a sign of bad defrost system.perhaps even the fan not circulating the cold air into the refrig compartmant
Posted on Mar 22, 2008
Side by side refrig by kenmore and refrig running but not cooling. freezer is fine. checked settings.
Hello there:
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running. First, answer these questions: Is the thermostat knob turned to the proper setting? If not, reset it. Next, see if the compressor motor is running The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help. If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these: The compressor The Thermostat The overload, relay, or capacitor The defrost timer The condenser fan motor Cooling is poor A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas: Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Aug 07, 2010 | Refrigerators
Refrig. stopped cooling then the freezer side. then started back
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jul 19, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer coils icing up, refrig not cooling 8 years old expensive where is thermostat control
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 17, 2010 | Jenn-Air JCD2389G Side by Side...
Model # MSD2758GEQ - The freezer side is OK the refrifg side is n
Check to see if you have frost build up on the back of the freezer wall toward the lower section. If so you are have an auto defrost problem. Deice the coils and Check heater to see if broken. Most of the time the adaptive defrost control is the problem which is located in the fresh food section at the top area under all the nice looking plastic covering the cold control and freezer controls. The part is a 61005988 and cost approx. 80.00. I have to 2 of these today myself. Good luck. If you defrost all the ice out of the coils this will buy you few days of cooling before having to do it again. Hope this helps.
Feb 03, 2010 | Maytag Refrigerators
Refrig not cooling Freezer has frost build up on coils
Frost on the coils won't allow air to pass to the fresh food section, thus resulting in insufficient cooling. To eliminate this problem, you will have to get a new adaptive defrost timer ( small board ), and a defrost heater assembly.
Apr 26, 2009 | Maytag MSD2732GR Side by Side Refrigerator
GE Profile refrig side by side Model GSS 20iEMCC, not cooling
heatman101
df
Dec 26, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
I have a maytag side by side refrig., model number msd2432gr. The unit is on and running but not cooling, making clicking sounds like it's trying to do something.
I have honestly had the same problem, if the compressor is ok it has to be the start capacitor. I can help you repair even if it is the compressor. Hope I can help you more
Dec 17, 2008 | Heating & Cooling
FREEZER NOT FREEZING
I will be more than happy to help.  Read this first on Frigidaire Refrigerators.   Then if you have anymore questions about this ask me on Frigidaire Tech Support.
Thanks, Bill
Jun 30, 2008 | Frigidaire FRS26H5AS Side by Side...
Refrigerators Logo
149 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
