Unlock zone code
How do I change the zone code on a Sony RDR-HX750 DVD recorder
  • 1 more comment
  • Anonymous May 08, 2008
    Same Problem here. Have some US-DVDs I want to play on my Region 2 Player. Please Help!
  • steery Jun 19, 2008
    I'm thinking of buying a rdr-hx750, but will need it unlocking. If it's not possible, then I won't buy one.
  • wyft Jun 27, 2008
    i just bought the sony rdr-hx750 and it is locked in region 4. Everything is good with it, quite easy to set up but would be much more happier with it if i could unlock and play multi-regional dvds. Been searching the net but no luck so far.
I need unlock my sony rdr-hd750 dvdplayer,pls tell how to do it.
Posted on Mar 06, 2009
Hi All
I have tried the above and the dam thing just won't do it.
I am using Niviiremote on my iPAQHX4700 and it seems to work on all other functions
I switch to DVD with no disc and turn off
Then 12345 (press each individually)
I turn it on
Then 12345 (a/a)
But the "T:imer OK" does not come up.
Can anyoen help....
Posted on Nov 17, 2008
I managed to unlock my DVD player with a solution I found on videohelp.com. I quote the solution:
I made my new RDR-HX750 code free with this Remote Controll program on my old iPAQ:
http://rapidshare.com/files/12586334/RC1_825.rar
Just follow these steps:
Turn player to DVD mode and switch off player (standby) with NO DVD inserted
Press 1 on NoviiRemote
Press 2 on NoviiRemote
Press 3 on NoviiRemote
Press 4 on NoviiRemote
Press 5 on NoviiRemote
Player turns on
Player shows "T:imer OK" on the display and turns off
Turn player on again, after that you can verify your firmware setting:
1. System Menu
2. Settings
3. Audio output
4. Dolby output
5. Just mark "Dolby Digital"
6. Press Angle button
If successful your code region should be "14"
The first problem is to find an old PDA with infrared (Irda) since the newer models no longer use Infrared. The PDA also needs to have windows mobile. I managed to get hold of one via my dad.
I downloaded the program via the link above; after some trial and error, I managed to install the NoviiRemote program.
After installing boot up the Noviiremote progra. You have to select the "sony 0" codebase; don't worry, it's easy to find after you booted up the program on your PDA and it comes with the download. You will see a screen with 5 digits: 1 2 3 4 5.
After this, the instructions say:
press 1 2 3 4 5; the player turns on.
Instead of what the instructions say, when I did this, my player did NOT turn on. I turned it on manually, then continued with the procedure. I pressed 1 2 3 4 5 and the display indeed said: t:imer ok. I don't know if it is necessary to press the digits before turning the DVD player on, but hey, who cares, since eventually it worked.
After this I went on following the instructions: turn on the dvdplayer, press the system menu button on the remote, go to settings, go to audio output, go to dolby output and highlight/select/mark "dolby digital". Then I pressed the angle button as mentioned. You see a "secret" textbox where your region should be displayed as 14. I tried to play my region 1 DVDs and voila, to my own surprise it worked!
I don't know who made the codebase for the Noviiremote program, but I am very thankful. I hope this helps more people!
Posted on Sep 13, 2008
I have two SONY RDR-HX750 DVD Recorders that I haven't used for a couple years (I've been using my TOSHIBA and MAGNAVOX DVD Recorders with Hard Disk Drives instead). Now when I try to play a DVD or play a...
have you tried resetting both machines, also if they where stored somewhere cool and then brought into a warmer area it may just be condensation, if this is the case leve the machine to acclimatise for an hour first.
To reset power up and remove all discs, then press and hold the Stop button on the machine and then press the power button, the unit will power off and will be reset to factory default.
Dec 06, 2013 | Sony RDR-HX520 DVD Recorder
Sony recorder rdr-hx750 How to reset to analog.no picture but there is sound on av
my problem is last time i did some thing on dvd but i 4get wat i did and now even the remot dosnt work i have frind he said to me i have to restart but i dont now how i do it pleas help me to find the problem ??thx
Oct 07, 2010 | Sony RDR-HX725 DVD Recorder/HDD Recorder
Looking for the code to unlock my sony rdr-gx315 dvd player
There are no default password to unlock the parental lock. If you've forgotten the password, it is required to perform the Easy Setup to reset the settings on the DVD Recorder. Please refer to page # 83 of the Recorder's manual to reset the Settings.
http://www.docs.sony.com/release/RDRGX315.pdf
Sep 26, 2009 | Sony RDR-GX315 DVD Recorder
Region Unlock For Sony RDR GX-120 DVD Recorder
GO BACK TO THE PERSON WHO HAS REPAIRED ASK FOR FREE REPAIR AGAIN. IF HE NOT RESPONDING, TELL ME LATER I'LL HELP.
THAT TIME PLEASE MENTION FULL MODEL NO. FOR YOUR SET AND WHICH COUNTRY YOU LIVE?
Apr 23, 2009 | Sony Televison & Video
DVD player/recorder Sony RDR-HX750 error code E01 when selecting HDD. Anything I can do to fix that ?
Hi
You need to re-format the drive or replace the drive and format it.
Search eBay with "Sony formatter" for more.
Jul 03, 2008 | Sony Televison & Video
Dvd recorder
No, it is built in.However, AnyDVD software can correct that on a PC, and you can create a new copy from the original.
Jun 09, 2008 | Sony RDR-GX300 DVD Recorder
Televison & Video Logo
2,018 people viewed this question
Top Televison & Video Experts
