Question about HP OfficeJet 6110 All-In-One InkJet Printer
Fax reports How do i print fax reports
    Novelist:
  • 188 Answers
Hi Jambo,
Please click on the web link given below.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu04517&cc=us&lc=en&dlc=en&product=79477#N1605
Click on the Reprinting faxes in memory and check the steps to print the faxes stored in the memory,
For further information you can go through the web link given above for the detailed overview of faxing.
Have a great day!
Posted on Mar 24, 2008
How do I print a single call report for a FAX previously sent
Printing a fax call report
A fax call report is a brief report that indicates the status of the last fax that was sent or received.
To print a fax call report
1. On the all-in-one control panel, press Menu.
2. Use the < or the > button to select Reports, and then press .
3. Use the < or the > button to select Fax Call report, and then press .
4. Press to select Print report now. The all-in-one exits the menu settings and prints the report.
NOTE To set the fax call report to print automatically, see Setting print times for the fax call
report.
Setting print times for the fax call report
You can set the all-in-one to print a fax call report after any of the following events:
? Every fax error (the factory-set default)
? Send fax error
? Receive fax error
? Every fax
? Send fax only
? Never
NOTE If you select Never, you will have no indication that a fax failed to be transmitted
unless you print a fax activity log.
To set the print times for the fax call report
Use the following steps to set when the fax call report is printed:
4. Press the > button once to select Print report, and then press .
5. Use the < or the > button to select the option for when you want the fax call reports to be printed.
6. Press to save your selection.
The following print-time options are available:
Including the first page of each fax on the fax call report
If this option is turned on and the page image still exists in the all-in-one memory, the fax call report
includes a thumbnail (50% reduction) of the first page of the most recent fax that was sent or
received. The factory-set default for this option is On.
To include the first page of each fax on the fax call report
Use the following steps to include the first page of each fax on the fax call report:
4. Use the < or the > button to select Include 1st page, and then press .
5. Use the < or the > button to select On or Off, and then press to confirm your selection.
Jul 06, 2011 | HP LaserJet 3050 All-In-One Printer
How to I turn off the automatic printing of the fax logs.
To change fax confirmation
1. Press Setup.
2. Press Print Report, and then Fax Confirmation.
3. Press the right arrow button to select one of the following, and then press OK.
Off - Does not print a fax confirmation report when you send and receive
faxes successfully. This is the default setting.
On Fax Send - Prints a fax confirmation report for every fax you send.
On Fax Receive - Prints a fax confirmation report for every fax you receive.
Send & Receive - Prints a fax confirmation report for every fax you send and receive.
May 03, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
How can I get a FAX Confirmation printed out on the HPJ4680?
If you require printed confirmation that your faxes weresuccessfully sent, follow these instructions to enable fax confirmation beforesending any faxes. The default fax confirmation setting is Off. This meansthat a confirmation report is not printed for each fax sent or received. Aconfirmation message indicating whether a fax was successfully sent appearsbriefly on the control-panel display after each transaction. NOTE: You can include an image of the first page of the faxon the Fax Sent Confirmation report if you choose On Fax Send or Send &Receive, and if you scan the fax to send from memory To enable fax confirmation
1.Press the (Setup) button.
2.Press right arrow to select Print Report, and then press OK.
3.Press right arrow to select Fax Confirmation, and then press OK.
4.Press right arrow to select one of the following, and then press OK. Off Does not print a fax confirmation report when yousend and receive faxes successfully. This is the default setting. On Fax Send Prints a fax confirmation report for every faxyou send.
OnFax Receive Prints a fax confirmation report for every fax you receive.
Send& Receive Prints a fax confirmation report for every fax you send andreceive
Jan 10, 2011 | Office Equipment & Supplies
How do I print the fax log?
Follow the steps below to print Fax Logs for already received faxes
  1. Press Setup , and then press 2 . This displays the Print Report menu.
  2. Press the Right arrow button to scroll through the following report types:
    • Fax Report Setup: prints the automatic fax reports as described in Generate reports automatically.
    • Last Transaction: prints details of the last fax transaction.
    • Fax Log: prints a log of approximately the last 30 fax transactions.
    • Speed Dial List: prints a list of programmed speed-dial entries.
    • Self-Test Report: prints a report to assist in diagnosing print and alignment problems.
  3. After the desired report is highlighted, press OK .
Also, Click on the link below for more information about Fax settings on your printer
Fax Settings
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Dec 31, 2010 | HP OfficeJet 6210 All-In-One InkJet...
My HP 1040 fax prints a sending confirm notice after every fax is sent. Is there a way to turn this feature off as it is a major waste of paper.
Reports you can print
You can print these reports whenever you need to. Some of these reports can be set to print automatically also.
1. Press Report/Help.
2. Choose the report you want by using left or right arrow.
3. Press Start/Enter when the desired report is displayed.
4. The selected report will be printed.
Sending Confirm
A confirmation report shows whether the transmission was successful or not,
how many pages were sent, etc.
ON: prints a confirmation report automatically each time you send a fax.
OFF: never prints a confirmation report (You can print one manually using the
Report/Help button (see Print reports on page 51).
ERROR: prints only when an error occurs.
Nov 25, 2010 | HP 1040 Plain Paper Inkjet Fax
Trying to set up fax to print when sending fax
● Every fax error (the factory-set default)
● Send fax error
● Receive fax error
● Every fax
● Send fax only
● Never
Sep 24, 2009 | HP LaserJet 3390 All-In-One Printer
How can I print a fax confirmation on a specific outgoing fax
Checking a report for the transmission result (?TX Report? function) A report containing the transmission results can be printed. The machine can be set to either print or not print the transmission report or to print it according to the machine setting or only when a transmission fails. To print the transmission report 1 Press the [Fax/Scan] key to display the Fax mode screen. 2 Touch [FAX Menu]. 3 Touch [TX Report] on the Set 1 tab. 4 Select how to output the report, and then touch [Enter]. ? Default: The transmission report is printed according to the previously specified method. For details, refer to ?Specifying report output settings (Report Settings)? on page 10-48. ? ON: The transmission report is printed with each transmission. ? If TX Fails: The transmission report is printed only if the fax could not be sent. ? OFF: The transmission report is not printed, regardless of the transmission result.
Aug 10, 2009 | Minolta bizhub 200 Copier
How can i generate incoming call report ?
To print a report:
  1. Press the [Menu] button on the Control Panel, until Reports is displayed on the top line of the Display Screen. The Phone Book menu item will be displayed on the bottom line.
  2. Press the right or left arrow button to scroll until the report or list you want to print is displayed on the bottom line.
    • Phone Book: Phonebook list
    • Sent Report: Sent fax report
    • RCV Report: Received fax report
    • System Data: System data list
    • Scheduled Jobs: Scheduled job information
    • MSG Confirm: Message confirmation
    • Junk Fax List: Junk fax number list
  3. Press [Enter] to print the selected information.
Your machine can print reports containing useful information. The following reports are available:
  • Phonebook List: This list shows all of the numbers currently stored in the machine's memory as Speed Dial and Group Dial numbers. You can print this phonebook list using the [Phonebook] button.
  • Sent Fax Repor: This report shows information of the faxes you recently sent.
  • Received Fax Report: This report shows information of the faxes you recently received.
  • System Data List: This list shows the status of the user-selectable options. You may print this list to confirm your changes after changing any settings.
  • Scheduled Job Information: This list shows the document currently stored for Delayed faxes or Toll Save faxes. The list shows the starting time and type of operation.
  • Message Confirmation: This report shows the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results. You can set up your machine to automatically print the message confirmation report after each fax job.
  • Junk Fax Number List: This list shows up to 10 fax numbers specified as the junk fax numbers by using the Junk Fax Setup menu. When the Junk Fax Barrier feature is turned on, incoming faxes from those numbers will be blocked. This feature recognizes the last 6 digits of the fax number set as a remote fax machine’s ID.
  • Multi-Communication Report: This report is printed automatically after sending documents from more than one location.
  • Power Failure Report: This report is printed out automatically when power is restored after a power failure, if any data loss occurs due to the power failure.
NOTE: The lists you have set to automatically print out will not print out when there is no paper loaded or a paper jam has occurred.
Aug 04, 2009 | Xerox PE120i Laser Printer
01.12.2008 i fax to one number. now i want aknowledgement of that fax. its gone or not. How i can find on HP Officejet 5610 all in One System?
You can get the manual here if you do not have one - LINK.
Here is an exert form the manual on this:
Print fax confirmation reports
If you need printed confirmation that your faxes were successfully sent, follow these
instructions to enable fax confirmation before sending any faxes. Select either On
Fax Send or Send & Receive.
1. Press Setup.
2. Press 2, and then press 1.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
On Fax Send Prints a fax confirmation report for every fax you send.
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send &
Receive
receive.
Dec 10, 2008 | HP Officejet 5610 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
93 people viewed this question
Ben Johnson
