Question about Sony Ericsson Walkman W810i Cellular Phone
Cant run my phone sync program cause it says i need xp&; i have vista
    Problem Solver:
  • 12 Answers
I have the same phone and vista. What are you trying to sync? Contacts, Music, Pictures? The easiest way to do it is to use the USB cord that came with the phone, When you plug it in the phone says choose, click file transfer, and click cancel on ur computer when the software install app opens up. Then treat it just like and extra hard drive or flash drive. Manually drag and drop the files u want into your phones folders, the phones folders are well labeled and its an easy process. - JHOBBS
Posted on Mar 22, 2008
SOURCE:
Wont connect to pc
Thanks for visiting FixYa!
Your phone connects to your PC through either 'Active Sync' (for windows XP) or 'Windows Mobile Device Center' (for Vista or Windows 7).
After downloading the program you need, restart your PC then connect the phone to your PC with a USB cable.
Click to Download: Active Sync (Windows XP)
Click to download: Windows Mobile Device Center (Windows Vista / Windows 7)
Sep 10, 2011 | HTC HD2 Smartphone
Navman n40i smart st compatability problem with vista.
Are you not able to run the activesync program despite the Vista warning? Did you try running it in compatibility mode? What happnes when you try to connect with sync center (what happens...any error messages)? Regarding the mobile device centre...did you check that McAffe and windows firewall is not blocking it from internet access?
Jan 26, 2008 | Navman NavPix N40i GPS Receiver
Cant down load the usb driver
you need active sync or windows mobile device center, no other drivers needed.
If you are using windows xp download Active sync, if you are using Vista or newer then look in your start menu, all programs and find Mobile device center. if its not there then get it from http://www.microsoft.com/download/en/details.aspx?id=14
Sep 01, 2011 | HTC Wildfire Cell Phone
My samsung pc studio dosen't work with vista
hi friend, in windows vista you can run the program in Compatibility mode from vista, go to START> Control pannel> Programs> and below program and features it says use a older program with this version of windows, Thats what you want. Regards
Mar 28, 2009 | Samsung SGH-D600 Cellular Phone
Vista and yahoo voice compatability
U NEED TO FINDOUT IF WINDOWS VISTA SURROPTS WHATEVER U WANE RUN CAUSE SOME PROGRAMS JUST DONT WORK ON VISTA AND YOU WILL HAVE TO GO BACK TO NORNAL XP
Feb 03, 2009 | E-Machines eMachines Desktop PC
Ipaq 4700 active sync problems
i can try to help you , first are you using xp or vista ? and which version of active sync ? i found that after upgrading to active sync v4.5 my ipaq 4700 refused to sync , i have xp home , so by trial and error i learned several things , i tryed my usb cable in every usb slot i had , only to find some usb ports are more friendly to certain devices , for a lack of better terms , i deleted all partnerships in active sync , found that i needed to make sure active sync is not running on ipaq , go to settings / memory / running programs on the ipaq , stop all running programs , turn the ipaq off , then on the pc made sure firewall not locked , plug usb cable into pc , i leave mine in a port permanently , plug into the ipaq , it automatically turns the ipaq on , then i see 2 icons in pc system subtray start blinking , at that point i know sync is going to work , then active sync icon starts turning , lit up in green , and asks do you want to create a partnership , yes , follow prompts , and thats what has been working for me , now if i was to put the usb cable into a different port , no doubt it would give me grief , and the same thing with my phone and active sync , make sure active sync is not running on the device , sometimes i have to reset the unit , ipaq or phone , make sure unit is turned off them make the connection , give it a try .
Jan 02, 2009 | Computers & Internet
Won't sync to computer
Mkae sure you r running an Operating System COmpatible with the device, ie. Windows XP/Vista, if u r running the correct OS, insert the disk that came with the device, and you should get driver updates automatically, if all this takes place and still cant sync, check ur USB cord, if the cord works and still cant sync, contact support or a tech agent like Best Buy's Geek Squad
Dec 28, 2008 | Philips GoGear SA3245/37 Digital Media...
I neet Usb drivers for connect my HTC S710 phone to Pc
You can get the programs from the htc website for the programs needed to run the device, you can get the usb program ActiveSync (preVista) from Microsoft.
Oct 17, 2008 | HTC S710 Smartphone
Software compatibility
Hi san, many of vista's problems can be resloved by useing there combatilty mode, its in the properties if you right click on the programe. Make sure to click "Run this program in XP SP2" and "run as administaror" are checked. Good Luck
CoDoc
Dec 11, 2007 | Microsoft Windows Vista Ultimate Edition
Can not connect using LG Mobile Sync
I have the same problem like everyone else in this forum! here is the solution:
1. The USB modem driver came with the CD may or will not work, so get the latest drivers for it.
2. Before install the new drivers, change your phone setting under " setting -> USB connection -> from MASS STORAGE to DATA LINK.
3. Plug the usb cable to the phone and to your PC, it should do anything or give any message if it does just cancel it for now.
4. Install the new USB driver you just download, while install it will said something like " does not work with XP " just click OK don't panic.
5. After it finished installed you will see by the clock that it find the USB LG blah blah...and ding ding sound if you have sound on.
6. Now go back to LG Sync software and click on Connect & choose LG modem com port whatever it there.
7. You're done !!!
Here the link where to get the new USB driver:
http://it.lgmobile.com/web/web.product.manualSoftwareRF.laf
Yeah the link is all Italian ...don't panic, I couldn't read it either LOL...just click on the picture where you see the phone and the PC with wrap around with arrow, then follow instruction will be in English.
Good Luck!
Keep posting good answer that you find and help out other just like US!
Sep 20, 2007 | LG Prada KE850 Cellular Phone
Sony Ericsson Walkman W810i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Ekse
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
