Question about Microwave Ovens
Does not heat properly
I own a 6qt. Westbend Crockery Cooker and the internal temp on HIGH only reaches 177 degrees......It should be a minimum of 275/300.......
What is wrong & what can I do? Unit in only a year old and has never worked properly.
    President:
  • 2,072 Answers
Sounds like the thermostadt is simply shutting off at the wrong temperature.
That is most likely located in the controle section of the cooker where you select the features and cooking temperature. Those thermostats can be off pretty easily.
The are sombined metalic items that change resistance at varying rates with temperature. Not uncommon.
That would have to be replaced. No way to adjust one.
Posted on Mar 22, 2008
Thermador warming drawer takes 45 minutes to reach 190 degrees on high setting! That can't be right! Tech support said it should be 220 degrees on high and should take 20 minutes to fully heat.
I recommend that you go with your microwaves and claim to fix it. This can be a problem with magnetron, or power diode, capacitor faulty, or thermostat.
God bless you
Oct 27, 2013 | Thermador 30 inch Convection Warming...
GE dishwasher GSD6260JSS doesn't clearn as well as when new
water temp should be a minimum 140 degrees at inlet this can be checked with meat thermometer at kitchen faucet,also need proper fill of water entering dishwasher proper water pressure and fill also important for proper cleaning of dishes,if water is slow entering you may have sediment inside fillvalve screen if on well water in this case you will have to disconnect water supply line and take valve apart the screen is in side valve reassemble and test operation...if this does not work you may have to replace inlet vavle
Oct 21, 2012 | Microwave Ovens
Corningware 6qt one touch slow cooker user manual need fast. HELP!!!! PLEASE
Is that fast enough? Here you go...
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0903105.pdf
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 10, 2011 | Microwave Ovens
I lost directions for Model 85006 "Discovery" line West Bend electric cooker. There is nothing wrong with the pot. I need to find the booklet'
First of all, here is a direct link to the ONLINE USER'S MANUAL for that model:
http://www.westbend.com/supportdata/L5357-Crockery.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, the follow the onscreen instructions to install the software on your computer.
Thank you very much and good luck.
Joe.
May 11, 2011 | Microwave Ovens
The induction cooker when put on it shows E6 after about a minute or so and no heating takes place.
There is a error message there, it indicate a problem with your induction cooker. It cause a defective winding wire or circuit controllers your know induction cooker works similar to the principle of electro magnet induction, it give heat to metal cooking pot. I hope I give you a idea regarding what happen to your unit.
Mar 23, 2011 | Microwave Ovens
Emerson MW8992sb - Turns on and acts like it is operating normally but does not heat properly. It only heats the items to a warm temp not hot. Even when on full power it seems it's only defrosting. It...
From your description it sounds like the magnetron is failing, or the high voltage transformer is not putting enough high voltage to properly drive the magnetron, the other possibility is the solid state triac is not working properly, normally if it becomes defective the power level stays on one only, but you stated even at full power it was only defrosting, so it would seem the triac is working but maybe not they way it should. The cost for parts and labor could be close to the price of a new unit depending on the nature of the repair.
Feb 28, 2011 | Emerson Black Microwave Oven
Only heats to 325 degrees in convection mode. takes long time to reach this temp.
Hi two possabilities here, either the element or the thermostat is faulty and will need to be replaced.
Jan 07, 2010 | Amana AMV6177 Convection/Microwave Oven
15 yr-old GE electric oven takes over an hour to preheat to 450
After jiggling the lower burn element the oven heated up in the normal time. Perhaps a connection had come loose.
Feb 14, 2009 | GE JEM25 Microwave Oven
Sharp R-1874F Low Convection Temp
We have the 2 service manuals you need to refer to for this model and have uploaded them to our site here and here to help you.
You will need the
free Acrobat Reader to view or print them in case you don't have it.
The manuals have a safety info, disassembly info, troubleshooting chart, test procedures, part numbers, etc.
I would first suspect a bad thermistor, but it should be checked, as well as the line voltage at the outlet, etc.
The best place to order parts for this brand is Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
Jan 08, 2009 | Sharp R-1874 Convection/Microwave Oven
Microwave Ovens Logo
49 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
