My computor is full of junk and has become very slow. I have backed up onto an external hard drive and I now wish to return the unit to original factory specs. However I cannot access Acer eRecovery Management by following the instructions on your manual. If I put No (1) disc in nothing happens
    Genius:
  • 3,587 Answers
Well..the junk can be eliminated another way, see the tuneups listed here, for some suggestions
Posted on Mar 22, 2008
SOURCE:
How can I export go daddy emails onto an external hard drive
Look for an Archive feature in your go daddy web mail user interface.
Mar 25, 2014 | Seagate Computers & Internet
Removing all my data from wd my passport essential
You plug it in. Right click the drive on windows explorer, then select format. Perform a full format and your data should be gone.
Nov 02, 2012 | Western Digital My Passport Essential...
Hello I have a HP Pavilion a1320N it is running very slow, so I want to do a full recovery back to the original state, but I did not create a set up disks when I bought it. How can I do a full recovery?
Use an external hard drive to backup your files and do the recovery... or better use the System Restore utility to at least restore it to an old backup date.
Apr 27, 2012 | HP Pavilion a1320n (882780261747) PC...
Hard drive problem detected instructed to check users manual but cannot locate manual everything is very slow...Is it time for a new cpu? Computer will turn itself to a black screen with the...
Hi do you here any noise from the hard drive?
If so you should backup your data and buy a new hard drive, install it on your pc and install windows and all of your programs again. This is because the noise you hear means that your hard drive is getting broken
Let us know if you solved your problem
Mar 06, 2011 | Gateway E-6000 PC Desktop
Maxtor 40gb disk diamond max plus8 stops. how to fix it to download files again
Is the hard drive full check it by going to my computer see the hard drive go to properties check that and then see how much space is available. I highly recommend a bigger hard drive especially if you download things quite a bit or move files to another source external USB flash drives work well or external drive will do the job. Check the space if it is fine and you have enough room then something in one of those files is stopping the drive from working. Reformat get all you can off of it then install the software Operating software again starting over fresh. I usually do my drives about 1 or twice a month reinstall software back to its original so that I do not get packed with junk I do not have to deal with or see. Also it is advisable to clean and defrag disks frequently some will tell you do not have to do this I can tell you since I have been doing for over 20 years now I just do not have problems with my computers. John
Jan 13, 2011 | Maxtor Hard Drive
I have a Maxtor One Touch 4 Mini 120GB External USB 2.0 Hard Drive, I've previously used it multiple times in the past, importing AND exporting data. For some reason though after using it on one computer...
try testing it in another computer. if you have the same problem. then there might be an issue with the drive.
to recover your data. unplug external drive from the computer and open the external hard drive case. remove the hard drive inside. with you computer off and disconnected from the wall open the case to your computer. look and see how the hard drive inside is connected in your computer and add the external the same way. you might need a cable to connect it. you can simply disconnect the cdrom and plug the hard drive instead. make sure the external hard drive is not touching any electronics inside the pc. now you can turn on the computer. give the computer a minute to detect the new drive and assign a drive letter. navigate to my computer and select the newly added hard drive. copy and paste all the data you want to save. after everything has been backed up format the external drive to clear any bugs that may be causing it to be recognised in its case.
when finished remove the hard drive, plug in the cdrom, close the case, plug back into the wall, and return external drive to its case.
Feb 28, 2017 | Maxtor OneTouch 4 Mini 120GB External USB...
Maxtor external hard drive takes all system resources from pc
John,
I hate to be the one to say this but the reason you are seeing the spike in CPU usage when you connect the hard drive is because the computer is trying to read the hard drive and the hard is beginning to go bad, I would recommend taking the hard drive to a repair shop mom and pop type they often have the best rates and ask them to recover the data.
Treat the hard drive as if it were an egg bumps can make it very difficult to recover your data that you need. That is if you have any..
I deal with hard drives for a living this happens to my laptop and quad core desktop all the time but i am always able to get the data if they bring it to me before it gets worse
DONT RUN THE HARD DRIVE time is critical...
I wish you the best of luck
Please rate
Thank you
Jon King
Mar 25, 2009 | Maxtor Hard Drive
Proper or Best way to use my newly installed WD SATA external Hard Drive;
The files are placed on the drive by you. Unless someone setup a special application files will not automatically migrate to another drive. You would not generally want them to because they would never be where you left them and be much harder to find. Primarily you will want to be moving data files and not application files (unless you uninstall from the internal drive and reinstall to the external drive) You can open my computer and find both drives -- you can drag/drop folders (containing only data, mp3s, videos, etc) between drives. I always like to check these moves by doing a right mouse click selecting properties on each folder separately to assure that an equal number of folders and files were copied before deleting them off of the smaller drive.
I emphasize again moving programs in this fashion will cause them to break. If you have large and seldom used applications you can uninstall them then using the installation process and media provided by the manufacturer then reinstall them choosing the external drive as the destination..
I hope this helps.
Dec 09, 2007 | Western Digital Caviar SE WD800JD SATA...
Open Questions:
Computers & Internet Logo
Ekse
Alun Cox
