The black block
On some of our channels we have a black block in the middle of the screen can you tell me how to troubleshoot this or wat is causing it
  • Anonymous Oct 24, 2008
    Black box appears intermediately in the middle of the screen. We had this problem a bout a year ago and tech support helped. Their phone number is no longer. I am trying removing closed captioning but would like to keep this as an option
  • 99 Answers
Possibly one of two things:
Turn off Closed Captions - should be in options menu or on remote.
Make sure PIP (Picture in Picture) is turned off.
Hope this helps.
- Kyle
Posted on Mar 22, 2008
Hi Tony
You`ve mentioned that ON CERTAIN CHANNELS THE TV WORKS FINE, so your trying to say that not all channels THE BLACK SQUARE APPEARS IN THE MIDDLE O THE SCREEN... my be that black square is generated from the broadcast center. may be your unit is good. let me ask you how many channels that your tv works fine..?
Jan 16, 2014 | Panasonic CT-34WX52 34" TV
Black box in middle of screen/picture
Closed Caption function to that channel you select is ON. Make it OFF, when you are in that channel which displays this black box. It will be best to reset the TV to its factory settings first, and then re-tune it. for more details, refer its user manual.
Jul 10, 2012 | RCA L32WD26D HDTV/DVD Combo
What causes a black block in the middle of the screen
This is known as "burn in" it often happens with Toshiba televisions. The main reason is because of a cheaper screen they use, the color causes it to have a reaction over time, which in turn leaves the black box in the center.
May 25, 2011 | Toshiba Televison & Video
I have a black rectangle covering the center of the screen from top to bottom. How do I get rid of it? I tried the menu for Closed Captioning but it did not seem to work.
Try turning off the closed caption and text also check v chip, if you have a channel or channels blocked it could cause a black rectangle to pull up on the screen, if that doesn't work try resetting the unit to factory settings
Jun 16, 2009 | Toshiba 50HP66 50 in. Plasma Television
I have a LG plasma T.V., model 42PB4D. Black box/middle of screen
Try this:
In the menu go to CC and set the TV to CC1 as this is a text box appearing for captions. Hope this works!
Jan 11, 2009 | LG 42PB4D 42 in. Plasma HDTV
Ilo picture problem
turn off the closed caption Sounds like it's in text mode
good luck
Sue, Hitone tv, Baldwin NY
Feb 14, 2008 | iLO 2600 Television
Screen not showing on innovage mp3 player
generally the black spot means there may be an internal crack in the screen or it was left in direct sunlight and was damaged by the heat. If it is an ipod thre are many places that will repair screens if it is that specific problem. If it is that get quote first because it may be cheaper to buy a new on than to have that one repaired.
Feb 02, 2008 | Audio Players & Recorders
Black out screen
I had the same problem once with my RCA television. It only happened on certain channels and didn't happen during commercial breaks. If I adjusted the volume on the tv the box went away, but came back shortly after. The problem ended up being some malfunction in the closed captioning. I turned it all off and changed the CC settings and never had the problem again.
Oct 05, 2007 | Westinghouse W33001 30 in. HD-Ready LCD...
You have CC (closed captioning) turned on and it is set to text mode.....Go to the menu on the remote use the right arrow and hilight "C.CAPT",use the down arrow to highlight "C.CAPT",use the right arrow and highlight "off" then exit button on remote.
Sep 15, 2007 | Toshiba 36A60 36" TV
Televison & Video Logo
166 people viewed this question
Top Televison & Video Experts
