The shutdown window keeps coming up and my computer shuts down
No matter what I'm doing at the time, my computer will show the window to turn off the computer as if I clicked on the start icon and selected the turn off icon. If I don't click cancel fast enough, the computer shuts down. It also starts itself up too. Some times it will not happen for more than an hour, but most of the time it's almost constant. I am using windowsXP home version. Please help me with this as I am ready to take a hammer to it :-) thank you
  • 1 more comment
  • Buddy2815 Mar 22, 2008
    Here is the list of applications that are running. Thank you for your help.
    Nerocheck,RECGUARD,SM1BG,igfxtray,hkcmd,
    PDVDserv,AOLDial,jusched,AOLSP Scheduler,ASMonitor,AOLSoftware,m3SrchMn,mwsoemon,InstantAccess,RegisterDropHandler,HDAShCut,SOUNDMAN,ALCWZRD,ALCMTR,qttask,ctfmon,msmsgs,YAHOOM~1,AOL,Action Manager 32,Adobe Reader Syn...,BigFix,PowerReg Schedul...
  • Buddy2815 Mar 23, 2008
    Thank you so much for your help ginko, I'll try everything you said and let you know how I made out. Thank you again, I really appreciate it. Thank you to Sergio and eagle338 as well.
  • Buddy2815 Mar 28, 2008
    Hey guys, I tried your suggestions, but still had the same problem, so I took my computer to the geek squad and it turned out that the power supply was the problem. They replaced it and it's been working fine since. Thank you for your assistance though, I do really appreciate it.
  • 4,889 Answers
This is probably due to a virus.. there are many viruses that do this.. Until you fix it you can open
gpedit.msc -> computer configuraton -> windows settings -> security settings -> local policies -> user rights assignment -> shut down the system -> remove everyone from shutting down the system.
This wont let anyone including you shut down the system including you but that would keep the system on until you fix the problem. I will check for the virus that does this and post back..
Posted on Mar 22, 2008
  • eagle338
    eagle338 Mar 22, 2008
    click start->run->type in msconfig->and click on the startup tab.. Get me the list of all the applications that are running and i will tell you which nasty virus is doing this..
  • eagle338
    eagle338 Mar 28, 2008
    Great to know that you have fixed it and thanks for the information... Thanks for using Fixya!
  • 19,396 Answers
Go into control panel and find display properties.
click the 'screen saver' tab at the top in display properties.
click the power button displayed in display properties under 'screen saver 'tab.
see the settings for atoshutdown
  • 2 more comments
  • Ginko
    Ginko Mar 22, 2008
    if it is not power settings (auto hyberante or auto stand by), then either you have a virus or windows is corrupted.
    If your antivirus is good and up to date, then probably windows is corrupted.
    In any case do a backup of your data.
    If you do nott have any virus you will need to reinstall the system doing a complete recovery from disk, or doing a windows installation from windows cd.
    Do a backup and do a total recovery if you have the disks most likely the problem will disappear.
  • Ginko
    Ginko Mar 22, 2008
    Here is a breackdown of processes running on your pc.
    Nerocheck, nero startup
    RECGUARD, process from HP
    SM1BG, installed with iTunes, Napster and USB devices
    igfxtray, Graphic card help
    hkcmd, Intel's Hotkey Command Module (VGA card)
    PDVDserv, process info for PowerDVD
    AOLDial, AOL dialler
    jusched, process info for Sun Java Update
    AOLSP
    Scheduler, AOL scheduler
    ASMonitor, This is either aol monitor or a known spyware/trojan/virus. If the find this process in aol subfolder = C:\Program Files\AOL\Active Security Monitor\ASMonitor.exe then it is just aol scheduler. the virus in in programfiles\ASMonitor \ ASMonitor.exe. In your case it should be just the aol security, as you have the rest of aol. Do not download from Internet any tool/software to remove, identify asmonitor.exe, majority of this software are virus installer themselves. I think in your case this is not a virus
    AOLSoftware, AOL Software
    m3SrchMn, mild spyware called my serch bar this download. U se your antispyware to remove this. By the way, this never cause your pc to shut down
    mwsoemon, mwsoemon.exe is an search toolbar application by MyWebSearch, same as above, mild spywaare.
    InstantAccess, Trojan dialler, this one does not turn pc off either.
    RegisterDropHandler, scanner textbridge file
    HDAShCut, High Definition Audio Property Page, often erroneally indicated as spyware by bogus antyspyware.Same as ASmonitor above, most likely this is not a virus.
    SOUNDMAN,soundcard software
    ALCWZRD, audio drivers from RealTek, same as HDAShCut above , indicated wrongly as spyware by bogus antispyware websites, it is not a virus
    ALCMTR, ALCMTR.EXE is a process installed alongside RealTek AC97, same as above, not spyware
    qttask, quick time task
    ctfmon, configuration monitor
    msmsgs, msmessenger
    YAHOOM~1, yahoo messenger
    AOL, AOL
    Action
    Manager 32, drivers for Plustech scanners
    Adobe Reader Syn..., Adobe Reader S
    BigFix, bigfix security software
    PowerReg Schedul, normally is registration reminder, sometimes some malaware can use same name.
  • Ginko
    Ginko Mar 22, 2008
    To get a more detailed analysis you need to download This software called hijack this
    Althought you have a couple of trojans malaware seems none of them has capabilities for regularly shutting down your PC.
    Try first performing a regular system scan from safe mode using your antivirus, if you do not have updated antivirus you can download and install a free one here.
    Also download and install spybot antispyware here.
    Also download and install this antispyware tool call smitfraudfix
    Never download any untrusted antivirus /antispyware, often they are malicious software and install viruses.
    Reatart pc and go into safe mode pressing f8 on startup,
    All from safe mode do following
    run full antivirus scan
    run spybot scan
    finally run smithfraudfix
    Restart pc.
    At this point you should have fixed all malaware in your pc, check which processes are starting on startup using hijack this .
    It is possible that the shut down problem had not been fixed, as Windows had been permanently damaged.
    In this case you need to do a backup of your data and reinstall windows using recovery disks or Windows Setup Disk.
    regards
  • Ginko
    Ginko Mar 22, 2008
    PS: the setting : gpedit.msc -> computer configuraton -> windows settings ->
    the system. It is used in computers which are turned off from network etc, not on standalone computers.
    The registry setting above, if used for a prolonged time can cause further damage to your system. Do the virus scan from safe mode as soon as possible.
    regards
  • 818 Answers
You have a virus, scan your pc with nod32, you can download from www.nod32.com
Sergio
When laptop start window 10 boot screen come up and during the process after 15-20 seconds since the laptop was powered on the laptop get shut down.
hi there.
Laptop performance slowing down, or the laptop isshutting off completely because the laptop is trying to protect itself from damage caused by an excessive heat build-up. ... There are times when a laptop will turn offbecause of a virus or malware, hardware or software problems/conflicts as well.2 Nov 2013
Don't panic!... Is your "laptop shutting off by itself" or "slowing down ...
https://www.youtube.com/watch?v=74agkgZdzkI
What is the problem if laptop shuts down automatically?If removing air doesn't fix shutdown issue, it is a faulty hardware (can be anything), related to overheating or serious power related failure, such as bad battery or adapter. Overheat issue will result in unit turning on, but shuts down after about the same time (i.e. 15 sec).29 Jun 2015My Laptop automatic shutdown in few seconds - Laptops - Laptop ...
What would cause a computer to keep shutting down?An overheating power supply, due to a malfunctioning fan, can cause a computer toshut off unexpectedly. Continuing to use the faulty power supply can result in damage to the computer and should be replaced immediately. ... Software utilities such as SpeedFan can also be used to help monitor fans in your computer.5 May 2017Computer turns off without warning - Computer Hope
How do I get my computer to stop shutting down?Cancel System Shutdown or Restart. You cannot cancel a restart or shutdown using the Shutdown Event Tracker Windows interface. It is only possible to perform this task from the command line. To cancel or abort system shutdown or restart, open Command Prompt, type shutdown /a within the time-out period and hit Enter.1 Apr 2013Stop, Cancel, Prevent, Abort System Shutdown in Windows 10/8/7www.thewindowsclub.com/abort-system-shutdown-windowsSearch for: How do I get my computer to stop shutting down?
or go to this link to find out more.
Laptop keeps shutting off after few minutes
Nov 19, 2017 | HIS Computers & Internet
Tablet only shows half of screen when turned on
Try to fully power the unit off, full shutdown. Then restart. If the battery can be removed, do that also after shutdown.
Mar 01, 2017 | Televison & Video
I put about 30 Gigs of pictures on my wd 500gb hard drive and am trying to "safely remove hardware". but it says there is a program running that is using the hard drive and to close it. There...
The quickest route would be to go through the shut down process on the computer. That will close out any processes that are still running. I would only do this if you are absolutely sure all the data has been transferred to the external drive. If you're not sure, leave it for a little while and check again later. Hope this helps : )
Jan 01, 2011 | Western Digital My Passport Essential...
My computer windows station is sutting down repeatly and before shutdown show a massege, that is the application failed to intialize because the window station is shutting down
Shutting Down is powering off your computer, That message is just telling you that windows is turning off your computer and closing all programs. If an application fails to initialize it just means it can not start as windows is shutting down
Oct 07, 2010 | Computers & Internet
When i was playing a game my whole computer just shut down. when i started it back up nothing will show up on the screen. it just stays black,but the lights will come on the computer..what could be...
Scanning computer to eliminate malwares, spywares and the viruses from your laptop.
2- Repairing and cleaning Windows registry.
These two tips are found to be very helpful to fix the laptop shutdown problem. Almost all the computer users surf internet which could result in viruses attacking your system. Some of these infections are really pesky and cause the machines to shutdown randomly.
The registry errors, however, are the internal errors and can become a cause of system crashes and freezes. The registry keys shall be in good health to keep a system perfect.
When I noticed my laptop keeps shutting down everytime, I tested the Intel Software Partner, Reg In Out to fix the random shutdown problem with my laptop. increase ur ram also
Sep 02, 2010 | Dell Inspiron 1525 Laptop
My Gateway 700X PC (Windows XP) will not Shutdown/Will not Start.
Best to format and reinstall a fresh copy of your operation system.
Regards
Feb 24, 2010 | Gateway 700 X PC Desktop
My computer won't shut down it just keeps restarting
The most common shut down problem is that the system will reboot rather than shutting down. In most cases, the reboot is triggered because Windows XP is designed to reboot after a critical failure. To stop windows from rebooting in case of a failure, you need to take the following steps:
Right click on My Computer, Select Properties, Click on advance tab, Click on Settings under Startup and Recovery, Uncheck the option Automatically Restart under System failure, Click Ok twice and try to shutdown the pc. If it shows any error code then let me know
Nov 24, 2008 | Toshiba Satellite M65-S809 Notebook
Windows xp pro
Did you reinstall windows, or install another operating system? Have you placed your windows disks in your computer recently? To add files or possibly drivers?
This is in your ROOT boot up .ini file, which shows that loading screen, also there is an option that has blocked shutting down your computer. I can help you get to shutdown, is this a laptop, is this a home computer? Did you recently place this unit in the shop. All of these answers do matter for me to give you assistance.
ManOwar
Aug 07, 2008 | Dell Dimension 2400 PC Desktop
Windows XP shutdown
The computer is just doing it's internal diagnostics before it shuts down. This uses fairly little amount of physical memory. Every computer handles it differently depending on your configuration. If the computer does shut down on it's own....there is no real problem present.
Feb 22, 2008 | Microsoft Windows XP Professional With...
Computers & Internet Logo
David Payne
David Payne
