Question about Gateway MS-6389 Ver.1 S462 Motherboard (4000758)
Drivers for MS-6389 Ver.1
How can I get the drivers for the MOBO above? My HD is down. I put a new one and I don't have the drives.
Thanks!
  • Vando Mar 22, 2008
    No StuartB... It is a desktop computer. A friend of mine gave that CPU. When I turn it on, I get for bips (a long one and three shorts) and a error message (Invalid Disk System). It seems to be a software problem. I would use some soft to colect all soft drives but i just can't get in. So, I intend to format the HD and start up all over again! It uses windows 98.
    I found out drives for the MOBO 6390 on MSI website. I couldn't find out the drivers even on www.driverguide.com where they say have more than 400.000 drivers!
    I have access to the files in the HD using it as a slave on another computer. Do you know some way to collect the drivers by this way?
    Thank you very much for trying help me.
I have gateway ms-6389ver:1,I need the drivers for sound,please help
Posted on Aug 29, 2009
  • 46 Answers
This is everything I could find. The board is used in the Gateway Select 1400CS PC. Gateway doesn't recognize the model number, and MSI doesn't recognize the main board number. Cute, huh? However, in an odd quirk, Gateway DOES recognize the board number. Here's the info.: http://support.gateway.com/support/manlib/cmponts/sysboard/8507869/07869.htm. This says that the board uses PC133 memory, with a maximum of 512 MB in each of the two slots (for a total of 1024 MB). It also says that the fastest CPU supported is the AMD Athlon 1400.
Posted on Mar 04, 2009
I need information about memory card for this motherbord only I now is 3.3 v and 168 pins
Posted on May 18, 2008
  • 807 Answers
Is it a Gateway PC?. They seem to be the only ones that use that motherboard.
If so have a look on their website.
You will need PC model or serial number.
http://support.gateway.com/support/drivers/ddaStep.asp?pg=2&Tab=All
Posted on Mar 22, 2008
Ms-7142 ver:1 audio driver i want a free download Ms-7142 ver:1 ni996 pleade give me audio driver
Hi there
This board is also known as K8MM-V.
If you go here:
Support For K8MM
Then you will find four tabs toward the bottom of the page, the second of which says Drivers. Clicking on this will give you a box further down which is a drop down menu to select your Operating System. Once you have done this there will be a list of all the drivers for this board and you can download whichever ones you want. You should note that this is quite an old board and it does not appear to support any OS above Vista 64bit as there are no drivers for Windows 7 or higher. Also with only 2Gb RAM maximum supported (according to the manual) I doubt its capability to run Win 7 or higher.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 10, 2014 | Computers & Internet
Motherboard Manual for MS-6389 Ver.1 S462 Motherboard
Hi, This is the closest manual I could find for this motherboard. The link below will lead you to download a manual for the MS-6380LE (the other models close to this were MS-6378 and MS-6390) However, it shouldn't be too different. http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=287 Please let me know if you still have problem with connection. Thanks, Lolita
Jun 07, 2007 | Gateway MS-6389 Ver.1 S462 Motherboard...
When ever i install win xp there are no sound drivers whats the problem?
if there is no sound after installing win xp fresh copy, you have to install sound card driver with cd
Mar 23, 2011 | Gateway MS-6389 Ver.1 S462 Motherboard...
MS-7142ver 1 audio drivers how to down load
Try with realtek hd audio drivers.
You can download them from
http://www.realtek.com
Please rate my solution! =)
Sincerely
Aleksandar Adzic
Apr 16, 2010 | Intel Motherboard
Need a msi ms-7312 ver 1.0 vga driver
Hi, Your driver can be downloading easily by using this: Driver Update Software. take a look, and wish you best of luck. Hans
Oct 02, 2009 | MSI K9MM-V Motherboard
I've tried to find your driver but without results.. :/
better try some professional tool like this one: Driver Update Software for XP Vista 7 8
used it many times, and it's awesome.
Brian
Aug 04, 2008 | MSI K8MM-V Motherboard
Computer restarting
Your hardware can be a cause of your issue , ( A.K.A bad DVD-Rom , power supply or even the hard drive ) Or the Opertional System is corrupted ( A.K.A Windows XP , WindowsVista , Linspire 6.0 or RedHat Linux )
Jul 28, 2008 | Gateway MS-6389 Ver.1 S462 Motherboard...
MSI MS-6541 Motherboard drive
i need sound driver of mother board motherboard MS-6541 VER :1.0
May 09, 2008 | MSI MS-6547 Motherboard
Unable to Power Motherboard
Try to jump start it with a screwdriver, just touch the screwdriver to the place where the power connection (from the front) cable plugs in. If this works, you need to plug the power into there, if not, you may not be hitting the right spot, or the psu/mobo is bad.
Gateway MS-6389 Ver.1 S462 Motherboard (4000758) Logo
1,018 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
