Question about Refrigerators
I have a ge monogram aka whirlpool ice maker that makes very little ice. Instead it chuggs after a few minutes of running and continues to do so indefinitely. I have replaced the bin themister and the control board. There is ample water pressure to the unit. the diagnostic tests are ok when you run it in clean mode. any suggestions?
  • 4,889 Answers
Lift up the wire arm on the ice maker to shut it off then put your finger where the ice cubes should be and if the water isn't frozen you may have a cooling problem listen to see if you hear the freezer fan running then look at the bottom of the freezer at the back wall where the vents are and see if they are blocked with frost and reply to me
Posted on Mar 22, 2008
Cutter grid is not getting hot
I need you to look around your ice maker for a package containing a wiring diagram. I have information related to the Whirlpool 15 inch and 18 inch ice makers but for some reason GE did not publish the repair manual for your model. I want you to check the voltage going into the WR62X10015 Transformer
You should be getting at least 120 volts ac. Then test the voltage coming out of the transformer. What is the voltage coming out of the
WR62X10015 Transformer? Check the control board area for a fuse that goes to the
Check for loose connections going to the grid or broken wires on the grid itself. WR29X10073 Cutting Grid Assembly
Here is a link to the GE Monogram Technical Data
The Whirlpool and the GE Monogram Ice Machines are basically the same thing other than part numbers so I am linking to the Click Here=> Whirlpool 15 inch and 18 inch Ice Machine Service Manual I will be here to answer your questions so please let me know should you have questions, More information can be found
HERE Thanks Sea Breeze
Apr 07, 2013 | GE Monogram ZDI15C Automatic Icemaker
My GE Monagram Ice maker is not making ice. I have cleaned with approved cleaner for the clean cycle and it does not seem to help. The water just seems to flow over the freeze plate and periodically a thin...
I don't have the service manual for this model without having to purchase one but I have a link to Whirlpool Service Manuals which is very much the same when it comes to diagnostics. There are several reasons that may cause this problem as you described. They are water control valve sticking causing warm water to continue to flow over freeze plate and stopping ice production. A defective condenser fan or a very dirty condenser coil. Link to Whirlpool 15 inch and 18 inch Ice Maker Service Manual Link to a site where there are information and answers for most model ice makers HERE You can contact this person at the bottom of the page, Thanks Sea Breeze
Mar 06, 2013 | GE Monogram ZDI15C Automatic Icemaker
My ge monogram ice maker randomly goes into cleaning mode
Your ice maker is electronic and the electronic board inside has failed. Not much you can do in this case except replace the ice maker. Your Monogram uses a=> WR30X10093 Ice Maker Assembly
and here=> WR30X10093 Ice Maker Assembly I will be here should you have questions, Thanks Sea Breeze
Here is a Ice Maker Service Manual that may help should we have missed something=> HERE
Feb 28, 2013 | GE Monogram ZISS480DRSS Stainless Steel
GE Monogram Ice Maker
Could you please describe the problem you are having a little better?
Nov 21, 2012 | GE Monogram ZDI15C Automatic Icemaker
MY GE MONOGRAM ZIS420D FREZZER IS NOT MAING ANY ICE. WHAT SHOULD I DO
check for continuity on the ice maker water fill solenoid valve in the lower rear area of the refrigerator,then remove cover from front of ice maker, and there are 2 gears inside this cover,follow the instructions on the ice maker by this gear and turn it the way it tells you to,this will initiate a manual ice production,you will see the gears turn by themselves after you help turn these gears initially,then you should see water enter from fill tube in the back of the ice maker if the fill tube isnt froze over,if no ice production occurs the ice maker thermostat could be open(bad) or if it makes ice but doesn't push it out the heater below the maker may be open(bad)
Aug 12, 2012 | GE Monogram ZISS480DRSS Stainless Steel
GE MONOGRAM ZFS826DRC SS ice maker not working
Push the white paddle in three times slowly within 15 seconds. Then wait 2 minutes. You should see the ice maker start to cycle. If the ice maker doesn't cycle, replace the ice maker. If you need a new ice maker, you can go to the link below
Order Ice Maker
Refrigerator Parts
Mar 06, 2011 | GE Monogram ZISS480DRSS Stainless Steel
Monogram stand alone Ice machine continually drops ice when full
The thermistor can cause the ice-maker to run at all the time and harvest the ice slab. Replace the thermistor with this part.
Jan 27, 2011 | GE Monogram ZDI15C Automatic Icemaker
What do I use to clean the calcium deposits in the ice maker? The note inside the machine says to use a bottle of Nickel safe ice machine cleaner by Nu Calgon.....Home Depot doesn't have it....Target...
CLR will work great, just rinse the ice maker very well after cleaning the calcium deposits and throw out the first few batches or bins of ice produced after the cleaning process. Good luck !
Nov 26, 2009 | GE Monogram ZDI15C Automatic Icemaker
GE Monogram refrigerator icemaker problem
This is normal if you have previously used the crushed ice mode. The refrigerator will continue to dispense crushed ice for some time until the reserves are depleted. If this continues for a longer period then shut down the refrigerator and remove the dispenser compartment, clean any remaining ice and reinstall it. Start the power supply and wait 5 hours for the ice to form. Use the cube mode and you will surely obtain ice cubes.
Aug 27, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Ice Maker Quit Working
Replace the whole i/m - it is bad. Takes 5 minutes to do. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Nov 30, 2008 | GE Monogram ZISS420DRSS Stainless Steel
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
