Question about LG WD-14124RD Front Load Washer / Dryer
LE error is shown
I am geeting an LE eror on the washiung machine, reading the manual it is a morot problem an I have to call support.
I don't want to watse month on a call out when the answer is it is cheap to just but a new washing machine. Any idear what is involved with fixibg an LE problem in $$$ and would it be better just to get a new washing machine?
  • n1ch0las Apr 19, 2008
    le code AE?
  • 489 Answers
The LE error code means that the motor sensor has failed on your unit.  It's a small sensor that is attached to the motor in the back of your washer.  You will need to order that motor sensor part from LG.  To replace the part, you will need a 17mm socket and a 10mm socket.  Remove the back panel of the washer.  You will see the motor behind the panel.  Take your 17mm socket and remove the center bolt.  Now pull the rotor assembly & put if off to side.  This rotor assembly is magnetized so don't let any dirt or steel parts get in contact with it.  Now take your 10mm socket and remove the 6 bolts that hold the stator assembly to it.  Pull the stator out and turn it around.  You will see 2 connectors to it.  The 5 wire connector is your motor sensor.  Remove the connector and pop off the motor sensor from the stator.  Replace it with the new one and reverse the installation procedure.  Everything should work fine.
Posted on Apr 28, 2008
LG WASHER LE CODE
Fix for Error Code "LE" on LG Front Load Washing Machine
I just had an interesting experience with our LG washing machine today. I found some hints for the solution online buried in some user forums, but I thought posting my particular solution here in a less cluttered blog might make it easier to find.
I had just run a load of laundry, emptied the machine, and reloaded. I put the detergent in and started the machine. After sitting for about 2 minutes with no activity, a "LE" error message appeared.
While the online forums indicated this might be a problem with a sensor, I was able to solve the problem by doing the following:
1. Press the Power button
2. Manually rotate the hopper 4 times clockwise and 4 times counter-clockwise.
3. Press the power button and run the machine normally.
Don't know if this will work for everyone, but it worked for me. If I keep getting the error message, I'll have to call LG and find out about this sensor I was reading about.
May 30, 2014 | LG WM-2277HW Front Load Washer
Le error code
The error code "LE" appears after an unsuccessful attempt to fill the drum with water that results in the water level being too low to safely begin cleaning. The product manual suggests calling for service, but there are several steps you can take to try to resolve the issue at home.
Read more: http://www.ehow.com/info_8696564_maytag-washer-repair-code-le.html#ixzz2zXrmqUO5
Apr 21, 2014 | Maytag Neptune MAH5500B Front Load Washer
We are getting an LE error on a LG WT R852 washing machine
Here is a tip that explains what the LE error code means.....
LG Washing Machine LE Error Code or Fault Code
heatman101
Aug 13, 2011 | Washing Machines
LG washing machine loud and error code LE
heatman101
Jul 02, 2011 | LG WM2301HW Front Load Washer
I am Looking for the meaning to eror code LE on my washing machine it is an nec model No NW 452
According to what's written in the manual...
'LE' will light up if the machine is unbalanced or the lid is open. This can be corrected by following operation: WATER SUPPLYfi RINSEfi DRAIN. However if the unbalanced condition is unchanged despite repeating the above operation, the lamp 'UE' will light up, and the buzzer will sound to indicate a problem.
Jan 13, 2011 | Washing Machines
Machine stopes and reads le
Here is a tip that explains that problem...
http://www.fixya.com/support/r4348161-lg_washing_machine_le_error_code_or
heatman101
Mar 27, 2010 | LG WM-2277HW Front Load Washer
LG Tromm has the error code LE what is it?
unplug the machine or turn power to outlet off. wait five minutes. turn all back on should solve problem
Mar 15, 2009 | LG WM-2277HW Front Load Washer
Error Code "LE". I have cleaned water filter twice. still problem
hi,le means locked motor disassemble the filter and work your way down to the macerator(steel chopper blade) remove it and see if the side labeled "this side up" is really up, its in english... dont think the chinese labourers paid attention to the warning cause i have seen alot that were wrong way
if it was installed correctly order the complete motor/sump assembly btw you do know LG d/w came with a 2 year warranty right? and some of the water distribution system had a longer limited warranty
read your manual, it states warranty, then price the part, then call warranty depot to ask them their service call and labour to install motor/sump
This part taken from a LG repair manual:
(Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is
locked.
The rotor of Washing Motor is
locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.)
good luck.........
Mar 13, 2009 | LG WM1814CW Front Load Washer
LG WD-14124RD Front Load Washer / Dryer Logo
136 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
