Question about Maxent MX-42HPM20 42 in. Plasma HDTV
How do i use my tv as pc monitor?
I have a maxent 42 inch edtv monitor. I know that it works cause my buddy as made my computer work on it many times before. Please tell me how.
  • Maxent Master
  • 19,396 Answers
Here are specs for your tv
you need a dvi to hdmi cable similar to this one here
or this for US
ask also to your local reseller.
If your pc does not have dvi output you can try a vga to hdmi converter cable, I do not know if vga one will work on your tv.
Posted on Mar 22, 2008
SOURCE:
How do i hook regular cable to Maxent MX-42EPM20 42 in. EDTV Plasma Television
Your Maxent MX-42EPM20 is not a TV (Television) it is a Plasma panel. The difference being your Panel does not a TV Tuner (no Coax jack or electronics relating to a tuner) Below is the spec sheet that shows this
http://reviews.cnet.com/flat-panel-tvs/maxent-mx-42epm20/4507-6482_7-32139310.html?tag=mncol;subnav
You can use a cable box or a cheap Digital TV receiver. You can buy them at walmart, You need one with A/V out puts such as Component. Here is a link to one. This will give you a tuner.
http://www.walmart.com/ip/RCA-Digital-TV-Converter-Box-DTA800/8343230
Feb 18, 2012 | Maxent MX-42EPM20 42 in. Plasma EDTV
Maxent MX42X3 42" plasma Monitor..
Are you sure that its the main A/Vboard coz it sounds like the main power supply issue to me. Anyways the mainboard is the large board usually located at the center of the tv. If you can remove the back cover of the tv and get me a high res picture of the tv I can mark the board for you.
Jun 03, 2011 | Maxent MX42X3 42 in. HD-Ready Plasma...
Why Doesnt My Remote Control Work Anymore?
point it at a digital camera to se if the light flashes if you can se it flasheing it works chech your cod or pres tv on the remot.
Jul 19, 2010 | Maxent MX-42EPM20 42 in. Plasma EDTV
My tv has sound but no picture its an akai model pdp4206em1
Try unplugging it for an hour or so or try change sources , if the computer ever fell asleep while it was plugged in it is possible it triggered a sleep mode in the tv. Most will do such a thing. It is doubtful that the computer caused any damage to it but i would advise against using a plasma tv as a computer monitor because burn in WILL eventually occur with a static image left on the screen constantly.
Dec 26, 2009 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Has sound but no picture
Sorry to say - it sounds like the 'pop of death' - If you got this from costco - give them a call and see if you can claim warranty (or the manufacturer).
Dec 06, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
Maxent 42 inch TV Keys locked and Remote will not work
See if you can reset the electronics to factory defaults. Also check with the mfg about this. If nothing works you have one sick puppy on your hands.
Try this - turn set on then pull the power plug. Then push and hold the power button to on position for a few minutes.
Release button and plug back in Turn on and see what happens.
Sep 21, 2017 | Maxent MX-42HPM20 42 in. Plasma HDTV
How do you hook the up
Use the instructions that came with the device for full details. Their site is down, so you can't get a manual online at this time.
Usually, all you need is video input (a cable connection) and power.
If you have a straight cable line (no box), coax cable connection is will work if supported.
If you have a box, the better cables support the RGB and audio split, and will give you a better quality picture.
Be sure all are secure connected, and that if you use the RGB/Audio split connection, be sure each matches the color coding on the connector.
Jun 09, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
Sylvania 42" LC370SS8
Your TV monitor cannot support the format (scan rate) that your computer's display card is putting out. Go in to the computer's set-up for the resolution under the display properties and adjust the settings to support the TV monitor. Refer to the TV's instruction manual to see the supported formats.
When going back to the computer's display, the display format will have to be changed back to have the proper resolution.
TV sets are generaly not as good as dedicated computer monitors for use on computers.
Jerry G.
Apr 18, 2008 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
Black stripe down TV plasma screen
I'm sorry you have not been given a clear ansewer on how to repair your TV. I know how to fix the problem you are having (1.5 inch Black vertical lines that come and go) If you still need help fixing your Plasma TV please feel free to message me @ [email protected] or just give me a call @ 1-503-432-9904 and I'll help you fix your TV buddy! Ask for Dave!
Talk to you later buddy!
Dave
[email protected]
Apr 05, 2008 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Maxent edtv monitor 42 inch- how to use as a pc monitor
You'll need an adapter suited to the two ends of the the devices.
An adapter where one end fits the back of the PC graphics card ouput where you would normally plug the pc monitor, and the other end fits the back of your tv input.
If you're using windows, right click on desktop, Properties, Display settins, and choose your TV's name from the list.
Mar 22, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
Maxent MX-42HPM20 42 in. Plasma HDTV Logo
232 people viewed this question
Top Maxent Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
