Question about Sharp R-510HW Microwave Oven
My sharp r-510hw flashing like crazy
My daughter cooked her microwave popcorn.Then she put a small amount of butter in a bowl to melt.aprox 5 sec the microwave was flashing.Removed butter checked inside for metal or other foreign matter did'nt see anything.Hit start with it empty ,and it started flashing again.
  • 1 more comment
  • may3042 May 28, 2008
    I have sharp r-509fw with a similar problem,,,it flashes so much that I don't set the clock anymore..the cover for the waveguide cover is missing. could this cause the flashing> if i close door 2-3 times reset the time (cook) 3-4 times, push start gently ,I luckup w/hot meal.....once on, it works to time completion..except every now& then.....is the cover missing my problem?? sharp wants $13 for the little piece of mica plastic..Ill pay , if, thats the problem. thanks richard nowling bluebird6342@yahoo.com I cooked dinner tonight.5/28/08
  • Anonymous Dec 26, 2008
    microwave was working fine, melted some chocolate chips in pyrex measuring cup, worked fine.Put back in microwave after stirring, turned microwave on & huge flashes occurred. No visible damage or dirt in oven. Put water in a cup & turned on & flashing occurs again. Do not use micro wave for 24 hours, now heated a cup of water & it appears to be working fine!! This is a Sharp R-510 HW 1200 watt.
  • flbr Jan 28, 2009
    Bright flashing whenever I use the microwave, whether something is in it or not. Very scary! I will not even turn it on until I know what the problem and solution is.
  • Sharp Master
  • 9,098 Answers
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced.
You can order Sharp parts from Tritronics at http://www.wehaveparts.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 30, 2008
How to cook corn in microwave
Depends on your microwave and the popcorn. Your owner's manual will have instructions. The first couple times, it will probably be by trial and error.
BTW--the best way to get rid of stinky burned popcorn smell from a microwave is to microwave a small amount (1/4 cup) vinegar until boiling and let it set in the microwave for a while.
Apr 24, 2016 | In Microwave Ovens
How to pop popcorn
place a teaspoon of cooking oil in the pot and place on stove. Put a small amount of corn to be popped in the pot and the heat will do the rest. 1/4 cup of corn will probably overflow the pot so use small amounts first until you get the idea.
Feb 05, 2015 | Panasonic Inverter Countertop Microwave
Arcing sharp carosel microwave when i put orville redenbacher mini popcorn bags in i found oil on outside of bag
Arcing will occur if you have any metal inside the microwave, or if the powder paint on the inside has been damaged. If the paint is damaged dispose of the microwave
Oct 24, 2013 | Sharp Microwave Ovens
Sharp R305KS Stainless Steel 1100 Watts Microwave Oven problems:1.5 years old. We put in a microwave popcorn bag and had bright flashes going off as though there was metal left in there and gurgling...it...
unplug microwave.
Take ALL dishes out of the microwave and do a proper check of the inside the cooking area. If you are sure that's ok put the glass dish back in if it has one.
Test that the oven and grill are still functional.?
Do they heat up? If they do then get one of those microwaveable bowls or dishes and put some water into it. Place it back into the microwave and do the check again on microwave heating.
Does it bang or spark again?
If it does and the other heating is OK then the Magnatron to me sounds as it's on it's last legs.
That does not mean you have to scrap the microwave if it is the Magnatron. as a new one can be purchased and installed.
Apr 12, 2017 | Sharp R305KS Microwave Oven
Can you oil or butter in with popaire 2,
(BUTTER chamber thing) The little rectangular scooper-looking thing on the slope of the top is where you can put a chunk of butter that will melt from the hot air and drizzle into the popcorn popper as the popcorn is popping. My dad said you cant use oil in it
May 02, 2011 | Microwave Ovens
Sharp microwave losing cooking power
If the supply voltage is low it will take long time to heat foods. The second reason is the Magnetron. Since it is in the warranty period you can call at the sharp authorised service center. They will do it free of coast.
May 04, 2009 | Microwave Ovens
Sharp R-510 FK dangerous noise
Hello. To me, it sounds like something is stuck to the inside of your cavity and it is arcing, as you are seeing a bright flash, and hearing it. I would take apart/clean everything inside the cooking area, something is causing a problem in there. Usually just a good cleaning is all it needs, as the debris is making a focus point for the energy. Try putting a small glass of water, only 1/4 full, and watch while you start it, to see where the arcing is, it won't hurt anything for a second or 10.
Hope that helped, and thank you.
Mar 29, 2009 | Sharp R-510HW Microwave Oven
HOW DO I ROAST A CHICKEN IN A AC925CHS
Search the internet for “roast chicken recipe for microwave”
Here is one just in case you don’t find one:
Microwave Roast Chicken
3 lbs. chicken
1 tsp. salt
4 tbsp. butter or margarine
1 tsp. paprika
Instructions
Melt butter in a custard cup in microwave. Mix paprika into melted butter. Wash chicken (reserve giblets, these are best cooked conventionally). Sprinkle inside of chicken with salt. Cover ends of legs, tail, and wings with small pieces of saran wrap or wax paper. Place trivet on inverted saucer or small casserole lid in 12 x 7 inch baking dish. Place chicken breast side down on saucers. Brush with butter. Cover with waxed paper. Cook 12 minutes. Remove wax paper or saran warp from legs, tail, and wings. Turn chicken breast side up and brush with butter. Cover with wax paper and cook 12 minutes more or until meat thermometer registers 180 degrees (temperature will increase to 195 degrees during standing).
DO NOT USE MEAT THERMOMETER IN OVEN WHEN COOKING!! Remove chicken from oven; cover with aluminum foil and let stand 15 to 20 minutes before carving. Note: For other weights of chicken, allow 8 minutes cooking time per pound.
Jan 09, 2009 | GE JVM1860 Microwave Oven
Sharp R-510HW Microwave Oven Logo
192 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
