Question about Dishwashers
AEG Favorit 675 Once you press the on button, the inlet solonoid opens and the container below the dishwasher fills but nothing happens after that.I'am an electrical contractor who would love a circuit diagram to this model so i can follow the squence of operation, it is my own dishwasher.
  • 818 Answers
See this manual
pag 19-21
http://www.serviceforce.co.uk/pdfs/U04142.pdf
Sergio
Posted on Mar 22, 2008
SOURCE:
Aeg 60870 dishwasher water not getting in
The most common cause of a fault "i10" is closed valve on the water supply line. So this failure indicates a problem with filling of water.
Possible error causes:
Closed water tap, Inlet valve faulty, inlet hose bent, softener system clogged, pressure switch or pressure switch hose obstructed or leaking, wiring from pressure switch to printed circuit board (PCB), wiring from inlet valve to PCB and finally PCB.
Dado
Oct 04, 2014 | AEG 24 in. Favorit 60870M Free-standing...
Aeg favorit dishwasher not filling with water
Dado
Sep 05, 2014 | AEG Dishwashers
Dishwasher is not filling
Check that water and power are switched on properly, and that inlet hose is clear. Check manual first, if no answer or this doesn't fix, then contact manufacturer or service agent.
Aug 07, 2014 | AEG 23 in. Favorit 65070IA Built-in...
Aeg favorit 40010vi dishwasher won't fill with water
I have a similar issue on oko favorit 50700. I have checked the flow from the inlet hose into a bucket and it really seems ok, so I think maybe a problem at the inlet to the machine? Plea update if you get a fix!
Mar 24, 2013 | AEG Dishwashers
Water not entering machine when start button is pressed eevn though pump is working
Check the votage in the inlet valve when the start button is pressed, if voltage is present then the inlet is faulty, can be dirt which can be remvoed and ccleaned orr the valve can be faulty if there is no continutiy test onthe coil.
If there is no voltage on the valve the program controller must be checked for fault.
Sep 23, 2010 | AEG 24 in. Favorit 50740 Free-standing...
In which way can i reset my dw AEG favorit F 86050 vi?
There are 6 program buttons on the right side of the On/Off button.
Press and hold button 1 2 ( 70
Sep 04, 2010 | AEG 24 in. Favorit 86050Vi Built-in...
Our AEG Favorit Sensorlogic dishwasher has had no power to it
Open the lower front panel and locate where the water inlet hose is connected. Shut the water off under the sink, disconnect the hose at the water inlet solenoid, then put the loose end into a bowl or pan and turn the under-sink valve on slowly. Do you get water flowing from the hose? If so, then check the solenoid water inlet valve for damage. If the coil is ok, the valve part may be stuck closed. It should make a firm 'click' when the timer is set to start the machine (leave the hose loose). If it doesn't click, the coil may be bad, the valve may be stuck, or the timer is not sending 115 volts to the solenoid. Try a new valve first. If still no click, you may need the professional service. Good luck!
Mar 26, 2010 | AEG 23 in. Favorit 50750Vi Built-in...
AEG Favorite Compact 525. The pump runs continuously even when the on/off button is pressed. Tho only way to stop it is to turn the power off at the socket/plug. any ideas
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak)
Mar 10, 2009 | AEG 24 in. Favorit 40850 Free-standing...
Drain pump keeps running AEG oko favorit
Aug 29, 2008 | AEG Favorit 50500 Built-in Dishwasher
Dishwashers Logo
108 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
