LED won't come on and only faint hum is heard.
When switching on my projector, the lamp doesn't come on, only a faint internal noise is heard, no fan, and no LED indicating a problem.
  • Anonymous Mar 23, 2008
    lamp comes on then goes off
  • lluchjm May 30, 2008
    Hello I have the Epson EMP-500 too,
    First, I plug in the power suply wire, then Operation Indicator led is orange and I can heard the internal noise of the fans. It's ok.
    But, when I press the power button, the projector switch off completely.
    Which part could be damaged? Where could I find it?
    thanks
  • 563 Answers
Hi there
You are most probably looking at a faulty Ballast Board wich is the lamp's power supply.
If the Projector makes a really hard humming noise it could be your Colourwheel that is faulty.
The unfortunate thing about a Colourwheel is that you can't fix it , you have to replace it. The fortunate thing is that it is a very cheap part to replace.
Posted on Mar 25, 2008
Sharp projector Bulb replaced but still won't work?
check the ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Nov 08, 2012 | Sharp Projector Lamp For Xv-z90 Xv-z90e...
Epson PowerLite 410W projector (used for a smart board in a classroom) won't project anything or even turn on. Power button (maybe lamp indicator light? I don't really know anything about this...)...
It seems you assume that it is not an overheating problem.
The problem is, the bulb gets really, really hot when using the projector. It doesn't matter whether it has been there without any usage. As you switch it on, it will start to get hot.
But the lamp or other parts of the projector should not get too hot. To control the temperature, air is moved through the projector with the help of fans. Air enters through air filters and move through the projector absorbing heat from hot parts. This prevents these parts from getting overheated.
But what if air doesn't flow freely? Then the parts CAN get overheated.
First, switch on the projector and check whether you can hear the fans working.
Next, switch off the projector and remove power cable.
After about 30 minutes, remove the cover and check whether the air filters are blocked. If they are, clean them with a small brush.
This would probably solve your problem.
Sep 23, 2011 | Epson PowerLite 410W LCD Projector
When I tried to switch on my projector Acer H5360 it makes some noise then it beeps 3 times, blue led light flash 2 times and then red is steady by returns... Its brand new.. Any idea? Pls help
Ordinarily my first thought would be that the lamp is needing replacement. But if it's brand new, the lamp should be OK. Can you open the lamp compartment to see if it was broken during transit, or perhaps it's not fully seated properly. If it's a broken lamp, then I would contact the dealer you purchased it from, or contact the manufacturer directly to have it replaced. Also, is the noise loud and unusual, or just the normal sound of a projector coming on? If it's very loud, it could be the fan motor. Check that the fan is blowing. If the fan is the problem, the projector will shut down to protect itself from overheating. That, too, should be covered under the waranty.
Jan 13, 2011 | Acer H5360 3D Video Projector 3D
Marantz vp4001 is completely dead??
warning indicator led lit up means something dis connectivity inside the projector
1)lamp cover switch or its connection from main board
2)fan connectors
3)thermistor connector
above casues for machine shows warnnig temprature indicater
and projector remains in standby mode
Jan 05, 2009 | Marantz VP4001 DLP Projector
Dell 2200MP makes a loud Humming Noise and vibrates
even if a fan spins it still can be noisy.clean all fans (i use a tooth brush).i also buy air in a can..(poundshop sells them).and spray them to clear any dust.when you have done that start the projector and see if is sorted...
Nov 02, 2017 | Dell 2200MP Multimedia Projector
Intermittent Power up / dn
HI-
The projector is overheating, try cleaning the filters for the fan.
Hope this helps
Oct 29, 2008 | InFocus LP 600 Multimedia Projector
Tv makes humming noise when on. how can I eliminate or reduce the nose?
Some of the larger TV's are DISH ready, meaning that they have the tuner inside for SAT TV. The SAT tuners often have an internal fan that makes a humming noise. If it sounds like something other than that, you might have a bad component in your sound circuit that allows 60 HZ hum through the speakers.
If it is a rear projection LCG TV it has a fan in it to cool the bulb. You will hear the fan if you listen closely. It usually cannot be heard over the volume.
The fluorescent bulb and electronics inside make humming sound naturally. Kinda like when you turn on a lamp, and some lamps make a low humming sound.
Apr 03, 2008 | Televison & Video
485 people viewed this question
jasbo
jasbo
