Question about GE DBXR463EBWW Electric Dryer
HELP!!! Dryer will not work!!! MODEL#DBXR463EBOWW
Dryer was working in other house. We moved it and now it is getting juice, but acts like it isn't. No sound, nothing!!! Please help I need all the advice I can get.
  • bskohl421 Oct 21, 2008
    I have checked the voltage and the 3 fuses with a volt meter and everything is fine. I checked the dryer door swtich and the light comes on. I checked the drum belt and its good. I can turn the timer switch and hear clicking when set to a manual time. It appears its either the timer switch or the motor. How can you test the timer switch or motor?
  • john gagnon
    john gagnon May 11, 2010
    hi thanks for the question is it getting 240 volts
    Genius:
  • 1,122 Answers
Check the door switch and the heater box main fuse,let me know-mike
Posted on Oct 26, 2008
Beko DRVS 62 W Tumble Dryer Squeakig
I had a problem similar to this on my Frigidaire dryer. I found that there is a felt ring that goes around the drum inside. This acts like a washer to prevent the drum from rubbing on the housing. On mine, the felt somehow got pushed in some and the drum was squeeking as it rotated. I had to order a whole new drum and replace it since on my model it was part of the drum.
Feb 11, 2014 | Dryers
Dbxr463eboww
Your glides are probably gone and the drum is riding on the plastic bearing that the glides mount to. Glides are easy to replace. I made a video:
Feb 08, 2014 | Dryers
Dryer loses power
YOU NEED TO HAVE AN ELECTRICIAN,OR SOME ONE WITH KNOWLEDGE AND A METER TO CHECK YOUR VOLTAGE..PLEASE DO NOTING ELSE! YOUR ASKING FOR A FIRE..I KNOW THIS ISN''T THE ANSWER YOUR LOOKING FOR BUT IT MAY SAVE YOUR LIFE...RDS
Apr 23, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I need the part information for a new belt for this model GE dryer(DBXR463EBOWW)
The part number on a drive belt for the model you have listed is WE12M29. It can be purchased on line at pcappliancerepair.com for about $11. I hope this helps you.
Oct 28, 2009 | GE DBXR463EBWW Electric Dryer
Roper dryer model REX 3514RQ1. dryer works for/then quits. help!!
I have seen this before. You have got to remove the housing for the filter. Blow out the area around the blower and get the junk out of there. Wash out the filter housing.
Jul 06, 2009 | Dryers
Dryer was working. I moved it to new house. Dryer doesn't work
Hi Ken,
I believe that it purely coincidence that you just moved and the dryer failed. I suspect that the thermal limiter is the culprit. Follow this link and you'll see it (number 10 in the drawing).
You can test this theory but you'll need to UNPLUG THE DRYER FIRST!!!
Access the front of the blower housing and remove the 2 wires from the limiter and connect them together (effectively by-passing the limiter). Now insulate them with vinyl (electricians) tape. OK, plug the dryer in and turn it on. If it fires up, there ya go!
Remember, this is a safety device that you just jumped out. The dryer should not be run until it is replaced with a factory OEM part. You can find 'em here.
If this test did not identify the problem, write back and we'll go deeper into it.
SG
Apr 05, 2009 | Dryers
I need to change a dryer belt on GE model DBxR463EBoWW electric dryer we have the belt on but it is loose
First, make sure you are using the proper belt. For your model
DBXR4630WW that would be a part number WE12M29. Next, the grooves of the belt touch the drum. Now, looking at it from the front side, the belt goes from the left side of the drum directly to the motor drive pulley, then around the tensioning pulley, and then back to the bottom right back around drum.
Jan 21, 2009 | LG DLE2512W Electric Dryer
Top of Dryer getting scalding hot
hi there try drying a load without your house ducting.if its restricted at all this cause the heat to not leave the dryer a designed by manufacture and their for get hotter.can be other things but thats most common.ps should have good air flow leaving dryer when vent off.but because fine at house just moved from i think new house is the problem.God bless ,tom
Jan 05, 2009 | Dryers
Dryer model NO.LGC8858EQO
check door switch and wiring to switch. It also has a thermal switch on top of heating element, should show resistence.
Jan 04, 2008 | Dryers
MODEL: GEW9200LQ0 Electric Dryer
Has it ever work at this house? the first thing to check is the voltage and the pig tail .. let me know if you are willing to check it.. and I will help..
Aug 18, 2007 | Whirlpool GGW9200L Gas Dryer
GE DBXR463EBWW Electric Dryer Logo
321 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
