HD sound not working correctly, static pop, is barely audible
Seems this just recently happened, we have a 26" model purchased in oct 06, no reason I can think of for it to quit, nothing has changed recenty electronicly in the house, no new additons etc.
I have a 26 inch which gets no sound except through noise reduction headphones. The close caption is stuck in the on position and the remote and tv buttons only work in turning the set on and off..nothing else......I have a 26 inch which gets no sound except through noise reduction headphones. The close caption is stuck in the on position and the remote and tv buttons only work in turning the set on and off..nothing else......
You can't post conmments that contain an email address.
remove the rear cover to access the main board. now look for the main board, and the amplifier ic. turn on the tv unit for a while and then turn it off again then unplugged. try to touch the amplifier ic, if too hot then it needs replacement which mean some pins get shorted.if you don't know on how it will be done just leave it to a trained tv technician.
You sound driver may be corrupted, I suggest you re-install the audio driver.
You can download the drivers from ASUS WEB site. Selectyour model motherboard/computer/laptop, and make sure you select the Windows XPor Vista version of the drivers that matches your Windows operating system.Please click on this link to their WEB support site : -
http://support.asus.com/download/download.aspx?SLanguage=en-us
please bring a good contact cleaner from radio shack near you and apply the spray over the socket of the headphone(the place where you put your headphone jack)take headphone jack out and apply spray in and insert the jack in and out many times.-also check your system setup and confirm that all speaker are on- no mute button pressed-no cable is disconnected.
First, turn down the volume on the reciever. Next make sure that "tape monitor" has not been selected. If that doesn't do it, it will be time for a shop visit...accordianman
Do you get good audio from the headphone jack?
If yes, then it is the Audio Amp or some component in the Audio Circuit
If NO, then then Audio Switching IC is defective.
Expeens will depend on the person fixing it. expect $70-100 parts. I think labor is normally $80-120. so $150-220 total.
You can get a new 26" for that though. If the headphone works then the Audio Out of the TV will work. I suggest a miini system for audio out.
