Question about Hitachi 53FDX20B 53" Rear Projection Television
Magic focus --blue and yellow sag in the upper left area of the screen
I followed the instructions for Magic Focus, but nothing changes. The blue
will not align. We are in a remote area, no access to repair within 75 miles. TV has worked fine up to about 1 hr ago when the red and yellow elements no longer align. Magic Focus is run but does not fix the issue. Towards the center of the TV the piture is more together, but everywhere else the colors concave in towards the center.
  • 4,234 Answers
This is a problem with the convergence circuit. If you can solder, you can repair this yourself. First try and resolder the pins on the existing convergence ICs. These are large black ICs attached to a heatsink and should be marked STKxxx. If the resoldering does not resolve the problem, replace the ICs.
Posted on Mar 22, 2008
Problem with focus (severe problem on upper left
The Convergence circuit needs to be repaired.
There is a pair of Convergence IC's that need to be replaced. Best thing to do is to call a repair facility unless you have a solid back ground in Projection repair.
Hope this helps,
Jul 03, 2009 | Televison & Video
Split colors on screen
Replace the two convergence Ics they are STK392-110 if your model is the 53FDX20B you can get replacement Ics with installation instructions at the following link.
May 11, 2009 | Hitachi 53FDX20B 53" Rear Projection...
Magic focus off
You will not be able to solve this yourself. It needs the convergence IC's replaced which is a big job.
Mar 30, 2009 | Hitachi 57SWX20B 57" Rear Projection...
The Model# is 53UWX10ba - Colors off in upper left part of screen
The problem is with the convergence circuit. If you can solder, try resoldering the pins on the convrgence ICs. If that fails to resolve the problem, replace the ICs. These ICs will be large and black, attached to a heatsink and be marked STKxxx.
Update this with your progress.
Jun 19, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Hi, convergence circuit has failed, convergence IC`s and any burnt resistors will have to be changed, this is NOT an easy repair if your not very proficient at soldering and un-soldering components, you will also need a good (accurate) volt meter as the resistor(s) will have to be removed and checked for value and the values are critical to the circuit, ie: 3.3 Ohms must read within 1%, if you have the tools & soldering experience get back to me and I`ll tell you where to go to get the parts, if not you need to get the set to a tv shop, BMW Rider
Jan 13, 2008 | Hitachi 53FDX20B 53" Rear Projection...
Hitachi53SDX89B color problem
Blue convergence IC bad...have both IC's changed..insist on
STK394-160E upgrade part # CZ 01341 Hitachi brand.....Original part is STK392-110......Also, check B+ feed resistors next to
convergence amp IC's for burn / damage...after rebuild, press magic focus.......................T.
Dec 21, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Blue shadow
Needs convergence circuit repair = replace convergence IC's,
then activate Magic Focus...............need step by step?......T.
Nov 30, 2007 | Hitachi 43F300 43" Rear Projection...
Blue/Yellow out of focus on Hitachi 43UWX10B
You will need the convergence circuit repaired......IC's replaced,
B+ resistors checked and then magic focus activated......T.
Sep 17, 2007 | Philips 60P8342 60" Rear Projection...
Green alignment
One of your convergence output IC's has burned out and needs to be replaced.
Jun 22, 2007 | Hitachi 53FDX20B 53" Rear Projection...
Color Alignment
get a shop manual,it tells how to do the whole convergence process and how to store it to the rom memory to save it.
Mar 15, 2007 | Hitachi 43FWX20B 43" Rear Projection...
Hitachi 53FDX20B 53" Rear Projection Television Logo
113 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
