Refilling LC37's Can I refill my LC 37 Brother Inkjet bottles? I have a number of correct coloured inks left over from my previous printer, so if I can, can you give instruction to do it? Thanks Mitrebin Australia
  • 4 Answers
This answer:
http://www.refillinstructions.com/Brother/B6.htm
is wrong.  It doesn't work for LC37 cartrdges, because they are not the same as LC51.  There are no instructions on that site that work.  Here's what I do:
You don't have to take the shell off the cartridge; it would be better if you did, but it doesn't come off nearly so easily as the above link says.  It is glued together, so to take it off, you have to split the seam with a very sharp knife.  If you can do this, the refilling job will be a lot easier as you will be able to see what you are doing.  If you don't want to attempt it, you can still fill it "blind".
You need a 10ml syringe.  You don't need a needle.  The tip of the syringe is not quite long enough, so I had to make an extension for it.  I used a piece of skinny tubing from the inside of an old spray bottle.  I cut about 1" (2.5 cm) off and attached it to the end of the syringe using epoxy putty, like the stuff for patching leaking radiators.  You can get it at any hardware.  I put a piece of wire through it to keep it aligned while I was molding the putty around it.
After it sets, fill the syringe with 5ml of ink.  Push it into the outlet hole of the cartridge while twisting it until it is firmly stuck into the hole.  Turn the cartridge/syringe assembly so the syringe is up.  Pull back on the handle and **** 5ml of air from the cartridge.  Then gently squeeze the 5ml of ink in.  Fill the syringe with another 5ml of ink and repeat.  You may find it hard to **** air out without getting ink as well.  The cartridge is built like a labyrinth inside, so there are lots of places for ink to get trapped.  Twist and turn the cartridge and push and pull until you've got the 5ml of air.  Then again put the syringe topmost and gently squeeze in the ink.  If you have removed the shell, this will be easy to do.  The main point is to make sure you remove the same amount of air as the ink you put in.  Do not push the plunger valve.  If you do, you very likely will get a handful of ink.
An LC37 only holds 10ml of ink, not 30 like the LC51.
When you are finished, you can gently push the plunger just slightly; if any ink comes out, you need to remove some more air.  You can damage the printer if you install a cartridge that has pressure inside it.  New cartridges have a vacuum inside; you can hear them go "whoosh" when you click them into place.  If not a vacuum, you need to at least have neutral pressure before you install it.  This is very important.  The printer has sensitive electronic sensors mounted roght at the business end of the cartridges.  If any ink gets spilled in there, your printer will likely be ruined.  Be warned.
It is about impossible to do this without any spillage.
Wash the cartridge in running water, shake out the excess thoroughly and then dry it with a paper towel.  Don't install it unless it is totally dry and not pressurized.
Posted on Jul 23, 2008
Check here, its pretty much the same. I use the left over ink to refill the LC 57 works fine
Posted on May 09, 2008
Not printing
Sometimes... refilling is done badly and the ink has some dried grains in it if the guy who filled it is not careful... This can cause the cartridge to clog up from the inside... You can still use it but the life of it drops from 1000 pages a refill to about a 100 per refill.
The life of the cartridge drops on every consecutive refill if it is done badly.
Jul 25, 2010 | Brother DCP585cw AllInOne InkJet Printer
Error message after cartridge refill on Canon MP160. How do you clear/ reset the printer after refilling the cartridge?
what error come out???
you can push and hold maintanace n colour button...
wait untill you see number 1..
if error 5,you catrige was broken...
too much ink...
Jun 13, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Ink cartrages lexmark ,,
Hi there
Lexmarks cartirdges not like to be refilled they not work the chip on the inks will still say emty after you refill them.
If you want to try to fill them.
All printer are the same ways to refill the inks up go to this website it will show you how it done there is a few Videos there for you to see how it done
http://www.youtube.com/watch?v=pnCPB9Clk5c
All the best Pineworks
Mar 07, 2010 | Lexmark X4650 InkJet Printer
Unable o clean
HTML clipboardHi If your brother printer has been left unused for some time it is probably clogged? And the inbuilt cleaning facility does not help then you will probably need to buy a Magic Inkjet Flush Print Head Cleaning Kit.
Which you can find on Ebay.
http://tinyurl.com/yfx2y5k
Although it is possible to take the Brother printers apart, it is too difficult for most people.
To view what´s inside a Brother Printer click on next line...
Click again to enlarge photo.
http://magicinkjetflush.com/images/Unclog_Refill_Brother_Printers.jpg
Therefore, what we suggest is to make cleaning cartridges using the Dr.EpSUN Refill Tool...
Then use them to flush the print head (usually at the end of long tubes near to the back of the Brother printer)
*NEVER TOUCH THE WHITE star shaped PIN... under ink cartridges... because once pessed in... it cannot be used !
Also in most cases a single cleaning cartridge for black and 1 for colour is all you will need.
If you only have FULL INKS and need to make a cleaning cartridge use Dr.EpSUN Refill Tool to empty ink cart...
Save the ink in a clean glass jar or similar make cleaning cartridge then once unclogged simply use Dr.EpSUN Refill Tool
to refill with your saved ink.
How to make Brother Cleaning Cartridges
If you wish to see photos? You can also follow the procedure for Epson C80 in the Magic Inkjet Flush Manual.
Using FREE Dr.EpSUN Refill Tool.
To refill Brother inks... or if printer has been left unused and you need to unclog print head? (To make a cleaning cartridges *Fill empties with Magic Inkjet Flush instead of Ink / Then print rectangles using Magic Inkjet to FLUSH print heads once prints appear without white lines simply replace with inks and continue printing rectangles untill all Magic has been flushed out of print head.)
How to refill Empties...
1. Secure empty Brother ink cartridge UPSIDE DOWN in a vice or similar.
2. ONLY HALF fill Dr.EpSUN Refill Tool with warm Magic Inkjet Flush (or correct color Ink if refilling with ink)
3. Then Holding Dr.EpSUN Refill Tool upright... cover metal tip with a tissue and expell any trapped air until ink appears.
4. Insert metal tip into circular ink outlet hole of upturned cartridge... until black rubber makes a GOOD seal.
Holding both securely...
5. Do NOT TRY TO FILL Instead. PULL UP on the plunger of Dr.EpSUN REFILL TOOL.
6. Air will bubble up through the Magic/ink whilst escaping from cartridge creating a vacum.
7. Now... Simply allow plunger to retract and the Magic/ink will automatically refill the cartridge for you.
8. STOP filling before the Dr.EpSUN Refill Tool is empty otherwise air will entering.
9. Repeat until ink cartridge is full.
How to FLUSH a BROTHER print head.
10. Place filled cartridge into printer and you are ready to print.
Use print head cleaning to prime which will also fill the ink tubes... then....
11. Print rectangles of the problem colour(s) using test sheets (see below) to prime ink.
As found in the manual, here are the print test sheets for printing rectangles depending on colour(s) with problem.
Just choose... Yellow, Magenta, Grey Tones etc...
PRINT TEST SHEETS FOR USE WITH MAGIC INKJET FLUSH
http://magicinkjetflush.com/Ebay/Print_Test_Black.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Color.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Cyan.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Yellow.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Magenta.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Grey_Tones.jpg
Once prints appear to be normal simply replace the Magic Inkjet Flush with ink cartridges and continue printing rectangles untill flushed.
Hope it helps. If you need any further help Click Here then choose "Ask a Question"
Thanks
John P Bradley Tinteiros (Ebay)
Nov 23, 2009 | Brother DCP 115C All-In-One InkJet Printer
Error:2200
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
May 13, 2009 | Lexmark X7170 All-In-One InkJet Printer
Refill ink not printing Lexmark x4550
take the cartridges out and clean them also clean where they go with a lint free cloth then replace them.
Jan 08, 2009 | Lexmark X5150 All-In-One InkJet Printer
Refilling ink cartridges
NVER EVER USE REFILLS ON BROTHER MACHINES, THE PRINT HEAD WILL GO BAD, I AM A SERVICE CENTER FOR BROTHER
Dec 23, 2008 | Brother MFC 240C All-In-One InkJet Printer
Refilling printer cartridge
http://www.hstt.net/refill-faq/brother.html#LC-1000 - Refill
use google translation from german language
May 13, 2008 | Brother Multi-Function Center MFC-240C...
Ink
better use this generic ink carts, which work pretty much better than the original ones :o
http://www.tianma.net.cn/
http://stores.ebay.de/stonewaregmbh
(LC1000 is identical to LC51)
There is much trouble by refilling original carts, because of the ink which might clog the ph.
Anyway if you keen on inky-fingers, malfunction ph and maybe bad printing results:
(use google translation german)
Apr 30, 2008 | Brother DCP 130C All-In-One InkJet Printer
Computers & Internet Logo
1,308 people viewed this question
David Payne
David Payne
