Washer will not spin properly
Try this:
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too.
Micro switch gets blocked with foam etc. So.... switch power off. remove top. At the back is a narrow black pipe leading down to drum. Diconnect pipe at top and blow down to clear. Put everything back and switch on. Hopefully, should now work.
