Question about Maytag MER5775Q Electric Kitchen Range
Oven won't come to temperature
I have a Maytag mer5775qaf and we are having problems with it heating up (the oven). When I preheat it it isn't coming all the way up to the selected temperature. I preheated it last night for 2 hours, wanting a temperature of 350*, and it never went above 225*. What to do?
Tanya
  • Anonymous Mar 18, 2014
    oven doesn't heat up to selected temperature
    President:
  • Maytag Master
  • 2,651 Answers
Sounds like you may have a bad bake element. can you see hte bottom bake element??? if not you can lift the oven bottom to reveal the "hidden bake element". eitehr way, the elemnet usually looks bad upon closer inspection. theres aburn hole in it or its completly broken. perhapseven a white powder plume from where the element went bad. if thats the case, its an easey enough partot replace yourself. 2 screws and2 wires.POWER MUST BE TURNED OFF FIRST LIVE WIRES AT ALL TIMES TO BACK OF ELEMENT!!!!!!!!!!!!!
Posted on Mar 22, 2008
6ya staff
SOURCE:
Problem with Maytag oven
Sounds like it may be the igniter failing
Feb 13, 2014 | Maytag Ovens
Maytag Oven won't work
either you element is bad or the relay on your control will not open , if able check voltage to element and inspect element for defect .
Feb 20, 2013 | Maytag Kitchen Ranges
My Maytag MGR5750ADW oven will take forever to preheat. It does get hot, but the preheat light takes a very long time to go out. Food takes much longer to cook as the oven does not seem to get up to temp.
Hello there and welcome to fixya
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out. You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results. If the bake element is burned out, replacing it should solve the problem. To determine if the heating element is burned out, watch the part testing video at the bottom of this page. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component. When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Aug 10, 2011 | Maytag Ovens
I noticed my oven was taking longer and longer to reach the preheat temperatures I was setting. As time went on, the stove was not heating up past 285 and now the temperature never increases but I can...
It is probably as simple as changing the ignitor...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Aug 16, 2010 | Maytag MGR5770 Gas Kitchen Range
The oven shuts itself off after preheating.
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Jun 03, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Maytag electric oven will not come up to temp., heats to 170 but no higher. Clicks like it wants to raise temp. but it will not go up. Model # MER5775QAF. Serial #18808572GL.
Usually the element burns out. It may have "3500 watt element but only producing 2000 watts". It's not completely out, but not far from it.
Jan 07, 2010 | Ovens
Ge gas oven will not heat but burners work
You will need to check the bake and broil igniters and/or the temperature sensor. A multi-meter should come in handy to verify if these components are good or bad.
Sep 06, 2017 | Ovens
THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
Sep 03, 2008 | Thermador SC302T Electric Double Oven
Preheating
heatman101
Jan 13, 2008 | GE Profile J2S968 Dual Fuel (Electric and...
Maytag MER5775Q Electric Kitchen Range Logo
569 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
freddyfox
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
