Question about Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor
Processor upgrade I have a Acer aspaire T180 with a sempron 3400+ 1.8ghz processor and I want to upgrade what do I got to look for to make sure the new one will work in it?
    Scholar:
  • 101 Answers
Also dont get a processor with a higher FSB than your board supports. Acer website gives no indication of board specifications but does say that the T180 supports the following processors AMD Sempron™, AMD Athlon™ 64 and AMD Athlon™ 64 X2 Dual-Core Processor with NVIDIA® nForce® chipset. If you are running XP you need minimum 512mb RAM and Vista minimum of 1GB RAM.
Posted on Mar 22, 2008
    Genius:
  • 1,027 Answers
Follow this link, download and run the program the cpu and cpu id will tell you the front side bus speed, the pin configuration (AM2)
Multiplier etc.
The mother board tab will id the board and chip sets to check manufacturer of the board and see what processor support there is.
Judging by your specs its upgradeable to an athlon 64- 4000 2.6 ghz.
  • Mark Williams
    Mark Williams Mar 22, 2008
    sorry this link.
    Download and run newkeysretriever.exe from the utility section.
    this utility will id the motherboard and attached devices
    Scholar:
  • 178 Answers
Need to look at the motherboard specs along with the processor "Socket". It will usually be a 754 or 939 depending on what your motherboard says. I wouldn't try too fast and set yourself up for disappointment. I would upgrade the RAM before the processor.
Hi i need more help in knowing just what type of processor chip to buy i know i need to put the same type back in my problem is i dont know what type it is my pc is acer aspire t135 1.8ghz it says on my...
Hi Paul,
Correct, you have to use the same type, but you can upgrade to a faster CPU.
According to the specs for your computer it can take the following:
AMD Sempron processor 2600+ to 3300+, 333MHz FSB
AMD Athlon processor 2800+ to 3200+, 400MHz FSB
See:
http://support.acer.com/acerpanam/desktop/0000/Acer/AspireT135/AspireT135sp2.shtml
The Athlon's are better...faster Bus. The Sempron is cheaper.
The 2 processors you describe are very similar. The difference between the 2 is that the first one is capable of running 64-bit operating systems and applications. The second one is strictly for 32-bit systems.
The next question will probably be, "What do I have?" Probably a 32-bit system. You can go with the 64-bit CPU and be safe as it can run both. You can see what your old one is by the revision number on the top of the CPU. You can use the following comparison chart to see the differences:
Sempron 3100+ Comparison
I hope this has been some help. Maybe it has just caused more questions. Just ask.
Thanks for using Fixya.
Mar 24, 2010 | Computers & Internet
Yea i need to purchase a new processor chip the motherboard is a 754 socket my pc takes a 3100+ amd sempron processor my pc is 1.8ghz im just not sure what to buy some say they are 64 bit and this one is...
please purchase the processor that is compatible to your motherboard. if the motherboard can be upgrade to a higher speed of processor then purchase it. if not, stick to the required specs. if you still want to upgrade, replace the motherboard, processor and the memory.
Mar 23, 2010 | Computers & Internet
I recently purchased a new battery for my acer Aspire 3050 and was told that it wont work if my laptop was dual core.I'm not sure what that means, is my 3050 dual core
you are in luck the answer is no its not dual core
Acer Aspire™ 3050 (LX.AV10J.037) PC Notebook The Aspire single core™ 3050 from Acer® provides performance, flexibility and value in a compact system. Featuring an AMD Sempron™ processor, wired and wireless connectivity and a stunning 14.1” WXGA display, this notebook brings productivity and entertainment to a new level.Please rate my help++++Thanks for using FIXYA
Nov 30, 2009 | Acer Aspire 3050-1733 Notebook
Best processor upgrade for my Acer T180
the processor you are using is the best combination for your computer and if you want to upgrade you should increase your RAM and install a good graphic card.
plz rate it .
Sep 13, 2009 | Acer Aspire™ T180 PC Desktop
WHICH CPU?
AMD Athlon 64 X2 5600+ ~ 3.20GHz
This is one of the crown jewel from AMD and is very robust
thanks and regards
May 12, 2009 | Computers & Internet
Upgrade possibillities for Acer Aspire T180
Specifications
Product
Aspire T180 Language
English Model
Aspire T180 Specifications Specifications
Processor
AMD AM2 Athlon 64 x 2 or Athlon 64 or Sempron (940 pin)
emory
256MB DDR2 533/667/800 SDRAM expandable to 4GB
1 Ok now that i found the spec for your computer here we go you can install the amd 64 x2 but not Phenom x4 9950
2 As for the graphic card you seem to know a little about computers so you can install and pci express x 16 graphics card that only needs one slot but remember some need power and this mean you my have to upgrade your power supply.So really you can by any single slot pci express graphics card for your computer so it comes down to how much you want to spend.
3.Ok for ram your max will be 4 gbs most likely ddr2 which mean that you have 4 ram spot in your computer.
hope this help please vote for me.
Oct 26, 2008 | Acer Aspire™ T180 PC Desktop
ACER 180 (AMD 64 3800+) upgrade
any amd 64 will work. bios should be ok if you stay with just the amd 64 if this is a aspire t180 then you might want to go to a 64x2 which you will have to flash the bios. hope this helps
roduct
English Model
Processor
Oct 18, 2008 | Acer Aspire™ T180 PC Desktop
Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor Logo
171 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
