Question about GE 46GW945 46" Rear Projection Television
Was working fine for 6 years until it just sparks at the HV Splitter Box. Is it a bad splitter box? and if so where can I get a new one?
  • 50 Answers
YOU HAVE A CRACKED HV SPLITTER--THIS IS NOT A REAL EASY JOB--GO TO YOUR LOCAL TV SERVIC COMPANY --YOU WILL NEED THE MODEL AND CHASSIS #'S ,,THERE IS ALSO A PART # ON THE BLOCK--PRICE SHOULD BE 75.00 OR LESS-GOOD LIUCK!!!!!!!!
Posted on Mar 22, 2008
Log splitter blows fuses
It now has a bad dead short in the wiring and that is why the fuse keeps blowing.. Check for bad wiring
Mar 07, 2014 | Cars & Trucks
When testing the hv flyback by turning on the tv, if tv stays on the hv splitter block is bad ,but what if tv turns off what you check next? thanks for the help.
first, I think you have this backwards----if splitter disconnected (look for physical signs or arcing or it burnt) the High voltage would come up and sizzle where it connects to the splitter.
If the set with the splitter disconnected still shuts down it is not the issue---got a D52 of some kind?
Nov 02, 2012 | RCA Televison & Video
I AM CONNECTING AN EPSON PROJECTOR TO AN IBM MONITOR USING A VIDEO SPLITTER. ON SOME MONITORS THE SCREEN TURNS ORANGE AFTER THE SPLITTER IS HOOKED UP. IS THERE AN ADJUSTMENT I CAN MAKE ON THE PROJECTOR? ...
Either the video splitter or one of the cables was bad. I attached all new cables and a video splitter right out of the box and it worked fine. I think one of the cables was not making a good connection.
Nov 02, 2009 | Epson EMP-S1H Multimedia Projector
How to remove high voltage distribution box rated at 250 volts this is problem with rca model p60923bl tv no power on press power on button tv clicks 3 times and turn off no picture.
If you are talking about the HV splitter in the front of the set----remove the front grill(screws behind set on either side) and then the inspection plate behind it----the splitter will have a red wire coming from the HV transformer and 3 more red wires going to each of the picture tubes--If the splitter is bad remove the wire from the high voltage transformer that goes into it(it should pull out and if may be hard to get it out) with it out and not touching anything (isolate it well clear of anything) the set should then come on and you should hear a hiss from the wire you removed---if the set stays on shut it off quickly and replace the block---most of them are available on the internet at a reasonable cost.
hope this was helpful.
Aug 11, 2009 | Televison & Video
CRT Question
Maybe, be safe. Run a wire with an alligator clip from the screwdriver shaft to the chassis ground while popping the anode off.
Jul 25, 2009 | Televison & Video
RCA projection P46732BA no power and arcing sound
The High Voltage Splitter is the cause of this and replacing it should fix the problem. Their should not be a shock hazard once power is diconnected. But just incase, ground each of the anode leads from the crts to ground. That should take care of any HV charge from the CRTS. Do make a note of which wire went went where, that is important. When you get the new HV Splitter, you will need to transfer the small board that is mounted on the old Splitter. Again, be aware of where the wires hook up to it and you will be fine.
Hope this helps,
Skyassoc
Jun 18, 2009 | RCA P46921 46" Rear Projection Television
Zenith Z56Z98D8 rear projection......HELP!!!
its called a bleeder assembly www.partsstore.com has a replacement for it 172.00 That could very well cause of the HV modules problems.
Oct 27, 2008 | Televison & Video
Rca p60752eb
Disconnect the lead from the flyback to the splitter. Place the flyback lead securely in a dry glass container and try to power up the set. If it doesnt shutdown the HV Block (splitter) is bad.
Feb 11, 2008 | RCA P61960 61" Rear Projection Television
ProScan wont turn on
PS52690 52" projection TV (CTC188 series) that won't power up. From what I have read here and other places, the most common cause of this is the HV splitter. Actually, when the unit was 3 years old, the HV splitter went out and had to be replaced but it was under warranty at the time. I have found that the part I need is 205064 and runs around $40-$70
A post in another thread said that you could test to see if the HV splitter is really the problem by disconnecting the HV anode (big red wire) from the flyback (not the splitter since that will arc), plug the TV in, power it up, and if the power stays on and you hear sound, replace the HV splitter to fix the problem.
Dec 05, 2007 | Televison & Video
Televison & Video Logo
59 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
